I am unable to get Orin NX 8GB into force recovery mode.
It does not show up in the SDK manager when I pull the force recovery pin Low.
In normal mode, It is showing this error,
[0000.888] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.896] E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[0000.903] E> I2C: Failed to clear bus for instance 4.
[0000.908] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.916] E> I2C: Failed to clear bus for instance 4.
[0000.921] E> I2C_DEV: Failed to initialize instance 4.
[0000.926] E> pmic: Can't get handle to i2c device @4
[0000.932] E> PMIC_CONFIG: Failed to initialize Rail: SOC rail config.
[0000.938] C> Task 0x2b failed (err: 0x57571c1c)
[0000.943] E> Top caller module: PMIC_CONFIG, error module: PMIC_CONFIG, reason: 0x1c, aux_info: 0x1c
[0000.952] C> Boot Info Table status dump :
011111110011100011111111111111111111111111100000000000000000000000000000000000011111
