Can't flash image on micro-sd
Hello, i tried to flash the Zip as explained for the dev-kit for jetson nano but it never work.
I did erase and all, but when it come to use Etcher for flash the ZIP, it crash at ~ 70%.
I need help :p ! Thank you.
have you tried with a different SD card?
If it still does not help, please try flashing with SDK Manager:
(which requires a Ubuntu 18.04 host PC)
Thank you for your answer.
I tired with an other SD card and it didn’t worked neither.
I will try with SDK manager, i have an old Computer with linux on it, hope it is on 18.04… ^^
tried*
