Can't power up the jetson
Until now, inserting the power plug or pressing the powerON button would turn on the red LED and the computer would start up normally, but after shutting down, inserting the power plug or pressing the powerON button did not turn on the LED or spin the fan, and it became unresponsive.
I tried connecting in recovery mode using a jumper wire, but since the power was not turned on, it was obviously not recognized by the host PC. Looking back at the operations up until that point, I did not do anything special, and I executed the sudo shutdown -h now command from an SSH session, and did not perform an inappropriate power off, so I have no idea what the cause might be.
As a side note, when the power plug is connected, the LAN port LED is lit (green and orange).
Question:
Is there anything that can be done to recover from this state?
Is it necessary to request a repair?
Environment:
Board: jetson nano orin 8GB devkit
AC: INPUT 100-240V-50/60Hz 1.2A
OUTPUT 19.0V==2.37A 45.0W
Hello @paipuorgan,
Is it possible for you to use a different power supply to rule out a bad supply issue?
Also, can you try powering up the Jetson through USB?
Another thing would be nice to try would be to try to connect to the board via UART and see if you get boot logs.
best regards,
Andrew
@proventusnova
Thank you for your reply.
I don’t have any other 5.5mm barrel jacks, so I’ll buy a PD-compatible 5.5mm barrel jack to USBC later and check it out.
As for URAT, I don’t have a jumper to USB on hand, so I’ll check that out later as well.
Also, I understand that the Jetson Orin Nano does not support power startup via USB. I thought USB was only for data communication, but is there any way around it?
@paipuorgan,
Yeah, I think you are right. For some reason I thought it supported power over USB but does not seem to be the case.
I believe it supports PoE though, based on the devkit carrier specification.
Please keep us posted on how tests go.
best regards,
Andrew
@proventusnova
I connected the jetson’s UART1_TXD (Pin 8), UART_RXD (Pin 10), and GND (Pin 6) to the USB to TTL Adapter and plugged in the power plug, but I got no signal.
I’ll check again after I get a jack that can be used to detect the signal.
Hello @paipuorgan,
Thanks for the update.
Sadly it does not sound very good.
Hopefully the new power adapter does the trick, but if that doesn’t help, we might need to start thinking about RMA the unit.
best regards,
Andrew
@proventusnova
I got a new barrel jack and checked it, but the symptoms did not change.
I think I will go ahead and apply for an RMA.
Thank you for your cooperation.
@paipuorgan,
Sorry to hear that.
Yeah, I think that’s the way to go.
Sure, anytime!
Wish you the best with your project.
Please do not hesitate to reach out if you need further help.
best regards,
Andrew
