I use Linux and windows in dual boot. I got struck by BSOD with a GPU related issue I don’t remember the proper issue and since then my windows didn’t recognize my GPU. But i can still see my GPU in the device manager. I tried everything from installing new drivers to the factory drivers then i also made a fresh install of windows. Still no luck then I jumped to Linux and still, I can’t switch to Nvidia GPU. I tried LTS kernel to ZEN kernel still no luck and the latest kernel too.
Here are some snippets:
ls -l /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 Sep 7 03:31 /dev/nvidia0
crw-rw-rw- 1 root root 195, 255 Sep 7 03:31 /dev/nvidiactl
lspci | grep -i nvidia
01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
modprobe -D nvidia
insmod /lib/modules/5.8.7-zen1-1-zen/kernel/drivers/video/nvidia.ko.xz
lsmod | grep nvidia
nvidia_drm 61440 0
nvidia_modeset 1187840 1 nvidia_drm
nvidia 19755008 1 nvidia_modeset
drm_kms_helper 282624 2 nvidia_drm,i915
drm 643072 16 drm_kms_helper,nvidia_drm,i915
modinfo nvidia
filename: /lib/modules/5.8.7-zen1-1-zen/kernel/drivers/video/nvidia.ko.xz
alias: char-major-195-*
version: 450.66
supported: external
license: NVIDIA
srcversion: 219D06D2182255C617D8C66
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 5.8.7-zen1-1-zen SMP preempt mod_unload
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: nv_cap_enable_devfs:Enable (1) or disable (0) nv-caps devfs support. Default: 0 (int)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_MapRegistersEarly:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_EnableBacklightHandler:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_AssignGpus:charp
nvidia-smi
No devices were found
dmesg | grep NVRM
[ 188.575342] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 450.66 Wed Aug 12 19:42:48 UTC 2020
[ 192.638468] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 192.638512] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 744.623660] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 744.623688] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 752.154218] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 752.154259] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 785.962083] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 785.962109] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 808.291532] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 808.291581] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 977.873652] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 977.873698] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 3159.215751] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 3159.215773] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
