hi all,
I can’t seem to render the frames for the sun study sequence using Iray renderer, even a simple snapshot of an frame.
while RTX real time and Path-tracing work fine.
Which version are you on?
Works for me - but it only works with the clear sky environment.
Or are you talking about the movie Capture tool?
Then this might be a known issue.which is fixed in the last version I have
Hello everybody
effectively not having tested again if the updates were beneficial and it is indeed the case.
With version 2021.3.5 it works perfectly :)
