My TX2 carrier board connect 1080p display, it will not detect the right resolution only show 640x480 resolution, and the console show “tegra-i2c 3190000.i2c: rx dma timeout” error message for over 5mins, then the display will black and sho 1280x720 resolution and stop show i2c error message via console.
But TX2 devkit can show 1080p correctly, while I do following step to force TX2 devkit edid to my carrier board, it can show 1080p screen correctly and the error message is not show.
If I connect to 4K display, my carrier board doesn’t work, while TX2 devkit can show 4K correctly. If I force 4K edid of TX2 devkit to my carrier board, it works ok, but if I connect to 1080p display, it doesn’t work. It seems my carrier board can’t detect display resolution information, so can’t show screen correctly.
Attached is boot file, Xorg.0.log, xorg.conf and HDMI schmatics.
This ticket originate from Fan and HDMI display not working on Jetson TX2 - Jetson TX2 - NVIDIA Developer Forums
Prepare a known 256byte EDID.
set use_fallback = true; in tegra_edid_get_monspecs() under edid.c.
fill in the known EDID to default_720p_edid[256].
xorg.conf.txt (796 Bytes)
boot_log.txt (73.2 KB)
Xorg.0.log (122 KB)
