Hi all,
Ubuntu 18.04 LTS
I’m trying to create some data with segmentation masks for use in TAO. The default setting of colorize_semantic_segmentation=True returns a properly colorized mask. However, setting it to false returns images with a numpy.unique(mask) = [0]. I’d really like this to work out of the box instead of doing this manually so I’d appreciate any insight. I’m using BasicWriter. I’ve tried with several scripts that produce correct results when colorize is set to True. Just to be sure, I tried the following shapes position randomizer tutorial with the same results
with rep.new_layer():
sphere = rep.create.sphere(semantics=[('class', 'sphere')], position=(0, 100, 100))
cube = rep.create.cube(semantics=[('class', 'cube')], position=(200, 200 , 100) )
plane = rep.create.plane(scale=10, visible=True)
def get_shapes():
shapes = rep.get.prims(semantics=[('class', 'cube'), ('class', 'sphere')])
with shapes:
rep.modify.pose(
position=rep.distribution.uniform((-500, 50, -500), (500, 50, 500)),
rotation=rep.distribution.uniform((0,-180, 0), (0, 180, 0)),
scale=rep.distribution.normal(1, 0.5)
return shapes.node
rep.randomizer.register(get_shapes)
# Setup Camera
camera = rep.create.camera()
render_product = rep.create.render_product(camera, (512, 512))
# Setup randomization
with rep.trigger.on_frame(num_frames=30):
rep.randomizer.get_shapes()
with camera:
rep.modify.pose(
position=rep.distribution.uniform((0, 1500, 0), (0,1500, 0)),
look_at=(0,0,0))
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(
output_dir="/home/kjhyd/tao/replicator/output/test",
rgb=True,
semantic_segmentation=True,
colorize_semantic_segmentation=False,
writer.attach([render_product])
rep.orchestrator.preview()
