Hey guys,
I am developing the picking and placing of a robot depending on the results of an algorithm on a server (server on the local network). The robot and pick and place task is based on omni.isaac.manipulators. Also I have the USD scene file with a camera in it.
The ideal or final concept would be that the camera gets a frame, sends it to a local server and then the servers gives back the coordinates of picking (in a mqtt or rest communication). But as first step I want to being able to load a picture from Isaac Sim and then send it to server.
I was wondering which is the best path forward or methodology to use to achieve that goal.
- Can I directly send a file to localhost port or local server from Isaac Sim?
- Do I have to use an already created extension? (I have created a custom extension for the robot and the picking). Do I have to create a new one?
- Do I need a custom connector?
If any of those possibilities is possible, how exactly would be the process?
Lately, I would like to apply Isaac Gym to test and check different positions and patterns.
Thank you very much for all the support and insight on the forums and I am sorry for my lack of knowledge.
