Hi there,
In the screenshot you can see the exact same model exported from Vred, on the left it is running from the Nucleus server, on the right I loaded it from my local disk, in the middle (outlined in red) you can see the Nuclesus Navigator.
All three views should show the same things, but although the data is available on the Nucleus server, the Composer does not load it from the Nucleus server. Yet It has no problem with the local version.
In the Nucleus Navigator it is clear that the files are on the server, hence it is the composer that is having trouble.
Here are some Logs:
2024-09-27 10:15:43 [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of W:\ac88d7d902b57417\USD\pxr\usd\usd\stage.cpp – In </XYC_showcar_Root/ME_SHOWCAR/EXT_MODEL/_3_MODEL_LED/MODEL_PO_03/ME_EXT_BBCenterTrans/ME_EXT/A_SYS/WHEELS/ME_Showcar_WHEELS_PFA_20210426/EXT/E40_WHEELS/WHEEL_ASSYM/E43_RIM_FL_wings_Assym/N2_2>: Could not open asset @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/assets-XYC_showcar_Root/N2#2/N2%232.usd@ for reference introduced by @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/XYC_showcar_Root.usd@</XYC_showcar_Root/ME_SHOWCAR/EXT_MODEL/_3_MODEL_LED/MODEL_PO_03/ME_EXT_BBCenterTrans/ME_EXT/A_SYS/WHEELS/ME_Showcar_WHEELS_PFA_20210426/EXT/E40_WHEELS/WHEEL_ASSYM/E43_RIM_FL_wings_Assym/N2_2> – Cannot determine file format for @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/assets-XYC_showcar_Root/N2#2/N2%232.usd@. (instantiating stage on stage @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/XYC_showcar_Root.usd@ <000002829EE41030>)
2024-09-27 10:15:43 [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of W:\ac88d7d902b57417\USD\pxr\usd\usd\stage.cpp – In </XYC_showcar_Root/ME_SHOWCAR/EXT_MODEL/_3_MODEL_LED/MODEL_PO_03/ME_EXT_BBCenterTrans/ME_INT_EXPORT/ME_Show_CAR_Master_EXT_n_INT_210118/INTERIOR_MODEL/HEADLINER_SWTransform/ME_Showcar_EXT_INT_Missing_Parts_2_PFA_WIP_20210427_1500/I80_HEADLINER/node_44649127>: Could not open asset @assets-XYC_showcar_Root/node#44649127/node#44649127.usd@ for reference introduced by @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/XYC_showcar_Root.usd@</XYC_showcar_Root/ME_SHOWCAR/EXT_MODEL/_3_MODEL_LED/MODEL_PO_03/ME_EXT_BBCenterTrans/ME_INT_EXPORT/ME_Show_CAR_Master_EXT_n_INT_210118/INTERIOR_MODEL/HEADLINER_SWTransform/ME_Showcar_EXT_INT_Missing_Parts_2_PFA_WIP_20210427_1500/I80_HEADLINER/node_44649127>. (instantiating stage on stage @omniverse://nucleus.CUSTOMER.io/Projects/XYCShowcarTestRun_V01/XYC_showcar_Root.usd@ <000002829EE41030>)
THX jan
