How can I configure CAN bus baud rate in Aurix using EasyCan?
Dear ian.liu,
Could you please refer to the following link for your topic? Thanks
https://devtalk.nvidia.com/default/topic/1036761/drive-hardware/how-to-save-aurix-configuration-/
Hi Steve,
If I understand correctly. I just need to issue this command (cansetbr [a|b|c|d|e|f] [125|250|500|1000] [1000|2000]) in Aurix console to change the baud rate right?
Ian
Dear ian.liu,
Yes, please try to run “help” command on Aurix console.
You can get below info from the terminal.
cansetbr [a|b|c|d|e|f] [125|250|500|1000] [1000|2000] : Switch baudrate of requested CAN channel to supported baudrate
