Hi I am new to this forum and I didn’t find the search function…
barney@nano:~$ head -n 1 /etc/nv_tegra_release
R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64, DATE: Wed Mar 13 07:46:13 UTC 2019
Once I connect an old Sony Eye Cam to Jetson Nano it freezes the USB stack with the following messages:
Apr 7 20:57:27 nano kernel: [ 298.757487] usb 1-2.3: new high-speed USB device number 20 using tegra-xusb
Apr 7 20:57:27 nano kernel: [ 298.784112] usb 1-2.3: New USB device found, idVendor=1415, idProduct=2000
Apr 7 20:57:27 nano kernel: [ 298.784150] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 7 20:57:27 nano kernel: [ 298.784173] usb 1-2.3: Product: USB Camera-B4.09.24.1
Apr 7 20:57:27 nano kernel: [ 298.784193] usb 1-2.3: Manufacturer: OmniVision Technologies, Inc.
Apr 7 20:57:27 nano kernel: [ 298.792208] gspca_main: ov534-2.14.0 probing 1415:2000
Apr 7 20:57:29 nano kernel: [ 300.803632] usb 1-2.3: current rate 16865 is different from the runtime rate 16000
Apr 7 20:57:29 nano kernel: [ 300.814549] usb 1-2.3: 3:1: cannot get min/max values for control 2 (id 3)
Apr 7 20:57:29 nano mtp-probe: checking bus 1, device 20: “/sys/devices/70090000.xusb/usb1/1-2/1-2.3”
Apr 7 20:57:29 nano mtp-probe: bus: 1, device: 20 was not an MTP device
Apr 7 20:57:29 nano systemd-udevd[7438]: Process ‘/usr/sbin/alsactl -E HOME=/run/alsa restore 2’ failed with exit code 99.
Apr 7 20:57:29 nano kernel: [ 300.986590] usb 1-2.3: current rate 1464 is different from the runtime rate 16000
Apr 7 20:57:29 nano kernel: [ 300.996940] usb 1-2.3: 3:1: cannot get min/max values for control 2 (id 3)
Apr 7 20:57:29 nano pulseaudio[6087]: [pulseaudio] alsa-util.c: Unable to load mixer: Invalid argument
Apr 7 20:57:29 nano kernel: [ 301.069316] usb 1-2.3: current rate 661 is different from the runtime rate 16000
Apr 7 20:57:29 nano kernel: [ 301.079343] usb 1-2.3: 3:1: cannot get min/max values for control 2 (id 3)
Apr 7 20:57:29 nano rtkit-daemon[6088]: Supervising 0 threads of 0 processes of 0 users.
Apr 7 20:57:29 nano rtkit-daemon[6088]: Failed to make ourselves RT: Operation not permitted
Apr 7 20:57:29 nano rtkit-daemon[6088]: Supervising 0 threads of 0 processes of 1 users.
Apr 7 20:57:30 nano kernel: [ 301.131530] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
Apr 7 20:57:30 nano kernel: [ 301.138593] retire_capture_urb: 243 callbacks suppressed
Apr 7 20:57:30 nano kernel: [ 301.138611] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
Apr 7 20:57:30 nano kernel: [ 301.150958] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
