Here is the original:
[ 0.720434] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.720685] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.720914] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.721091] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.721373] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.721378] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.721815] NET: Registered protocol family 2
[ 0.722888] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.723099] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.723650] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.723797] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.723877] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.724292] NET: Registered protocol family 1
[ 0.725020] RPC: Registered named UNIX socket transport module.
[ 0.725026] RPC: Registered udp transport module.
[ 0.725030] RPC: Registered tcp transport module.
[ 0.725034] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.725047] PCI: CLS 0 bytes, default 64
[ 0.725300] Trying to unpack rootfs image as initramfs...
[ 0.957193] Freeing initrd memory: 5356K
[ 0.967336] host1x 50000000.host1x: initialized
[ 0.969179] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.972533] audit: initializing netlink subsys (disabled)
[ 0.972629] audit: type=2000 audit(0.819:1): initialized
[ 0.973438] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.983480] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.984974] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.985778] 9p: Installing v9fs 9p2000 file system support
[ 0.989115] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.989262] io scheduler noop registered
[ 0.989555] io scheduler cfq registered (default)
[ 0.992295] gic 702f9000.agic: GIC IRQ controller registered
[ 0.995455] iommu: Adding device 702ef000.adsp to group 33
[ 1.004570] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.004757] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.005426] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9248c13
[ 1.005435] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.007113] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.007228] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.007320] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.007507] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.007586] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.007669] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.007748] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.007837] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.007921] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.008011] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.014092] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.015903] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.017767] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.019089] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.019452] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.020690] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.020926] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.021164] Adding domain tsec-pd to PM domain host1x-pd
[ 1.023530] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.024466] tsec 54500000.tsec: initialized
[ 1.026069] tsec 54100000.tsecb: initialized
[ 1.026844] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.030455] nvdec 54480000.nvdec: initialized
[ 1.031612] Adding domain vic03-pd to PM domain host1x-pd
[ 1.031820] Adding domain msenc-pd to PM domain host1x-pd
[ 1.031982] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.036287] falcon 54340000.vic: initialized
[ 1.037564] falcon 544c0000.nvenc: initialized
[ 1.038940] falcon 54380000.nvjpg: initialized
[ 1.043458] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.043500] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.043541] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.043614] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.043744] display board info: id 0x0, fab 0x0
[ 1.043807] generic_infoframe_type: 0x87
[ 1.043828] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.043833] tegra_cec 70015000.tegra_cec: probed
[ 1.043963] tegradc tegradc.0: DT parsed successfully
[ 1.044014] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.044519] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.051879] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.052289] tegradc tegradc.0: probed
[ 1.058494] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.059967] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.059978] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.060403] kfuse 7000fc00.kfuse: initialized
[ 1.061983] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.063179] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.064815] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.064838] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.065330] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.067083] vdd-gpu: applied init 1000000uV constraint
[ 1.067094] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.067514] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.072823] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.072996] No Device Node present for smmu client: serial8250 !!
[ 1.073012] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.073080] iommu: Adding device serial8250 to group 35
[ 1.076815] console [ttyS0] disabled
[ 1.076942] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.077121] console [ttyS0] enabled
[ 1.078346] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.078657] serial-tegra 70006200.serial: RX in PIO mode
[ 1.078806] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.079747] [drm] Initialized
[ 1.084050] Console: switching to colour frame buffer device 240x67
[ 1.084175] tegradc tegradc.0: fb registered
[ 1.091534] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.091590] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.092084] brd: module loaded
[ 1.092124] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.092137] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.097818] loop: module loaded
[ 1.097930] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.098047] tegra_profiler: auth: init
[ 1.099482] THERMAL EST: found 2 subdevs
[ 1.099491] THERMAL EST num_resources: 0
[ 1.099497] [THERMAL EST subdev 0]
[ 1.099505] [THERMAL EST subdev 1]
[ 1.099967] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.099970] THERMAL EST: thz register success.
[ 1.100140] THERMAL EST: end of probe, return err: 0
[ 1.101360] sd: No Scsi addr parsed to reserve index
[ 1.101398] hisi_sas: driver version v1.6
[ 1.106665] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.107954] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.107965] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.111116] libphy: Fixed MDIO Bus: probed
[ 1.111849] tun: Universal TUN/TAP device driver, 1.6
[ 1.111853] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.112897] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.112903] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.112967] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.112970] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.113020] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.113024] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.113069] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.113073] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.114253] PPP generic driver version 2.4.2
[ 1.114456] PPP BSD Compression module registered
[ 1.114462] PPP Deflate Compression module registered
[ 1.114503] PPP MPPE Compression module registered
[ 1.114510] NET: Registered protocol family 24
[ 1.114594] usbcore: registered new interface driver r8152
[ 1.114641] usbcore: registered new interface driver asix
[ 1.114740] usbcore: registered new interface driver ax88179_178a
[ 1.114787] usbcore: registered new interface driver cdc_ether
[ 1.114825] usbcore: registered new interface driver net1080
[ 1.114860] usbcore: registered new interface driver cdc_subset
[ 1.114900] usbcore: registered new interface driver zaurus
[ 1.114960] usbcore: registered new interface driver cdc_ncm
[ 1.115154] VFIO - User Level meta-driver version: 0.3
[ 1.116471] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.116495] ehci-pci: EHCI PCI platform driver
[ 1.116540] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.116553] ohci-pci: OHCI PCI platform driver
[ 1.116592] ohci-platform: OHCI generic platform driver
[ 1.119058] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.119068] Extcon AUX1(HDMI) enable
[ 1.119832] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.120165] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.120245] tegradc tegradc.1: No lt-data, using default setting
[ 1.120279] tegradc tegradc.1: No hpd-gpio in DT
[ 1.120312] tegradc tegradc.1: DT parsed successfully
[ 1.120372] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.120480] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.121675] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90d8000 id
[ 1.121785] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.124462] usbcore: registered new interface driver uas
[ 1.124531] usbcore: registered new interface driver usb-storage
[ 1.124662] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.124715] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.124767] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.125559] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.125620] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.125819] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.125825] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.125829] usb usb1: Product: xHCI Host Controller
[ 1.125834] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.125837] usb usb1: SerialNumber: 70090000.xusb
[ 1.126123] usbcore: registered new interface driver usbserial
[ 1.126463] hub 1-0:1.0: USB hub found
[ 1.126507] hub 1-0:1.0: 5 ports detected
[ 1.127275] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.127289] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.127386] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.127510] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.127516] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.127522] usb usb2: Product: xHCI Host Controller
[ 1.127527] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.127531] usb usb2: SerialNumber: 70090000.xusb
[ 1.130421] hub 2-0:1.0: USB hub found
[ 1.130475] hub 2-0:1.0: 4 ports detected
[ 1.131083] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.132524] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.132540] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.132575] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.132838] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.134848] mousedev: PS/2 mouse device common for all mice
[ 1.134973] usbcore: registered new interface driver xpad
[ 1.137711] tegradc tegradc.1: probed
[ 1.138036] tegradc tegradc.1: fb registered
[ 1.141258] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.141265] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.141274] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.141288] tegradc tegradc.1: blank - powerdown
[ 1.141310] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.141314] Extcon DP: HPD disabled
[ 1.141319] hpd: hpd_switch 0
[ 1.141324] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.141333] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.141339] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.157028] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.222754] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.254150] tegradc tegradc.0: blank - powerdown
[ 1.263604] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.265745] rtc rtc1: alarm rtc device
[ 1.265757] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.265774] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.266145] i2c /dev entries driver
[ 1.267722] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.268016] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.268021] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.268501] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.290828] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.290831] Extcon AUX1(HDMI) disable
[ 1.291791] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.291870] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.291907] imx219 7-0010: board setup failed
[ 1.291970] imx219: probe of 7-0010 failed with error -121
[ 1.292393] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.315714] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.315804] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.315834] imx219 8-0010: board setup failed
[ 1.315939] imx219: probe of 8-0010 failed with error -121
[ 1.317652] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.320595] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.320601] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.321125] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.321141] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.321151] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.321286] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.321295] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.321302] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.321450] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.321460] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.321464] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.321645] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.322624] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.322708] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.322734] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.322751] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.322760] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.323811] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.323858] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.324072] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.324105] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.324529] parse_throttle_dt_data: Num cap clks = 6
[ 1.324535] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.324549] parse_throttle_dt_data: clk=gpu type=4
[ 1.324572] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.324593] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.324615] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.324618] parse_throttle_dt_data: clk=emc type=3
[ 1.325073] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.325184] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.325354] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.326195] FAN dev name: pwm-fan
[ 1.326290] FAN:gpio request success.
[ 1.326375] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.326857] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.327365] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.327373] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.327492] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.327497] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.327501] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.327505] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.327509] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.327513] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.327517] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.327521] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.327526] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.327530] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.328597] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.329024] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.330186] device-mapper: uevent: version 1.0.3
[ 1.330875] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.336436] tegra210-cpufreq cpufreq: probe()...completed
[ 1.337258] sdhci: Secure Digital Host Controller Interface driver
[ 1.337259] sdhci: Copyright(c) Pierre Ossman
[ 1.337261] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.337748] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.338090] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.338217] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.342400] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.342934] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.344093] usbcore: registered new interface driver usbhid
[ 1.344094] usbhid: USB HID core driver
[ 1.346196] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.346509] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.348408] nvpmodel: initialized successfully
[ 1.349386] usbcore: registered new interface driver snd-usb-audio
[ 1.349443] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.349447] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.349472] iommu: Adding device snd-soc-dummy to group 36
[ 1.355510] tegradc tegradc.0: unblank
[ 1.361994] OPE platform probe
[ 1.362839] OPE platform probe successful
[ 1.362873] OPE platform probe
[ 1.362952] OPE platform probe successful
[ 1.386206] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.386341] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.386469] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.386593] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.386812] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.386900] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.388148] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.390409] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.390543] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.390716] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.390883] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.395557] tegradc tegradc.0: nominal-pclk:319750000 parent:319750000 div:1.0 pclk:319750000 316552500~348527500
[ 1.395615] tegradc tegradc.0: hdmi: tmds rate:319750K prod-setting:prod_c_hdmi_300m_600m
[ 1.396454] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.396629] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.396636] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.405441] u32 classifier
[ 1.405442] Actions configured
[ 1.405515] Initializing XFRM netlink socket
[ 1.406240] NET: Registered protocol family 10
[ 1.406957] NET: Registered protocol family 17
[ 1.406968] NET: Registered protocol family 15
[ 1.407041] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.407090] Bluetooth: RFCOMM socket layer initialized
[ 1.407100] Bluetooth: RFCOMM ver 1.11
[ 1.407104] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.407108] Bluetooth: HIDP socket layer initialized
[ 1.407126] 9pnet: Installing 9P2000 support
[ 1.407159] Key type dns_resolver registered
[ 1.407594] Registered cp15_barrier emulation handler
[ 1.407608] Registered setend emulation handler
[ 1.408772] registered taskstats version 1
[ 1.409300] Adding domain ve2-pd to PM domain host1x-pd
[ 1.409552] Adding domain ve-pd to PM domain host1x-pd
[ 1.411637] isp 54600000.isp: initialized
[ 1.412609] isp 54680000.isp: initialized
[ 1.422732] last reset is due to power on reset
[ 1.422734] KERNEL: PMC reset status reg: 0x0
[ 1.422808] BL: PMC reset status reg: 0x0
[ 1.422810] BL: PMIC poweroff Event Recorder: 0x40
[ 1.424252] clk_cbus_recalc_rate: no gbus parent
[ 1.424256] clk_cbus_round_rate: no gbus parent
[ 1.424257] clk_cbus_round_rate: no gbus parent
[ 1.424264] clk_cbus_recalc_rate: no gbus parent
[ 1.424368] clk_cbus_recalc_rate: no gbus parent
[ 1.424371] clk_cbus_round_rate: no gbus parent
[ 1.424372] clk_cbus_round_rate: no gbus parent
[ 1.424375] clk_cbus_recalc_rate: no gbus parent
[ 1.425039] tegra_dvfs: GPU-cap: registered
[ 1.425093] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.425095] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.425097] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.426218] tegra_dvfs: vdd-gpu-vts: registered
[ 1.426570] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.427218] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.427747] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.431283] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.431285] Extcon AUX1(HDMI) enable
[ 1.431652] tegradc tegradc.0: sync windows ret = 250
[ 1.447888] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.450695] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.461943] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.463049] vi 54080000.vi: vi_probe: ++
[ 1.465835] vi 54080000.vi: initialized
[ 1.468831] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.468926] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.470419] Disable partitions left on by BL
[ 1.470421] disb
[ 1.470480] bwmgr: missing cdev-type property
[ 1.470572] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.470578] DRAM derating cdev registered.
[ 1.471635] vdd-fan: disabling
[ 1.471637] vdd-usb-vbus: disabling
[ 1.471639] vdd-usb-vbus2: disabling
[ 1.471648] vddio-sdmmc3-ap: disabling
[ 1.471747] avdd-io-edp-1v05: disabling
[ 1.471749] vdd-usb-hub-en: disabling
[ 1.471829] ALSA device list:
[ 1.471831] #0: tegra-hda at 0x70038000 irq 83
[ 1.471833] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.473929] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.473932] Extcon HDMI: HPD enabled
[ 1.473949] tegradc tegradc.0: hdmi: plugged
[ 1.477007] Freeing unused kernel memory: 8576K
[ 1.485143] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.485148] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.485152] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.485155] usb 1-2: Manufacturer: Generic
[ 1.487661] hub 1-2:1.0: USB hub found
[ 1.488749] hub 1-2:1.0: 4 ports detected
[ 1.501916] Root device found: mmcblk0p1
[ 1.588666] mmc0: hw tuning done ...
[ 1.588702] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.589116] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[ 1.593512] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.706647] Found dev node: /dev/mmcblk0p1
[ 1.782757] usb 1-2.1: new full-speed USB device number 3 using tegra-xusb
[ 1.806854] usb 1-2.1: New USB device found, idVendor=046d, idProduct=c52b
[ 1.806858] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.806861] usb 1-2.1: Product: USB Receiver
[ 1.806864] usb 1-2.1: Manufacturer: Logitech
[ 1.852706] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.865381] EXT4-fs (mmcblk0p1): 21 orphan inodes deleted
[ 1.865384] EXT4-fs (mmcblk0p1): recovery complete
[ 1.890756] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb
[ 1.895395] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.896173] Rootfs mounted over mmcblk0p1
[ 1.911394] usb 1-2.2: New USB device found, idVendor=0bda, idProduct=8179
[ 1.911400] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.911403] usb 1-2.2: Product: 802.11n NIC
[ 1.911407] usb 1-2.2: Manufacturer: Realtek
[ 1.911409] usb 1-2.2: SerialNumber: 00E04C0001
[ 1.918054] Switching from initrd to actual rootfs
[ 1.990705] usb 1-2.3: new full-speed USB device number 5 using tegra-xusb
[ 2.014457] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c52b
[ 2.014461] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.014464] usb 1-2.3: Product: USB Receiver
[ 2.014467] usb 1-2.3: Manufacturer: Logitech
[ 2.070749] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.110012] systemd[1]: System time before build time, advancing clock.
[ 2.135321] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.135326] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.137708] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.149907] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.176251] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.177012] systemd[1]: Detected architecture arm64.
[ 2.201217] systemd[1]: Set hostname to <tiago-desktop>.
[ 2.262686] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.264704] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.338541] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.338551] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.369107] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.369113] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.369117] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.369120] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.369124] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.369145] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.369205] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.369340] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.369441] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.369465] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.369494] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.369514] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.369646] pci 0000:01:00.0: supports D1 D2
[ 2.369649] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.382865] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.382890] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.382894] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.382900] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.382916] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.382931] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.382938] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.382941] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.382946] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.383186] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.383189] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.383194] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.383272] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.383424] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.383441] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.397908] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.397992] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e7:13:ee from device tree
[ 2.398401] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.398416] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.501972] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.503720] systemd[1]: Created slice User and Session Slice.
[ 2.503852] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.503874] systemd[1]: Reached target Swap.
[ 2.503916] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.503935] systemd[1]: Reached target User and Group Name Lookups.
[ 2.504071] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.506003] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.541599] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.575947] v4l2loopback_dc: loading out-of-tree module taints kernel.
[ 2.577870] v4l2loopback driver version 0.6.3 (droidcam) loaded
[ 2.717851] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.958339] systemd-journald[2058]: Received request to flush runtime journal from PID 1
[ 3.885436] random: crng init done
[ 3.888868] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.397647] using random self ethernet address
[ 4.410919] using random host ethernet address
[ 5.300081] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.300088] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.524687] Mass Storage Function, version: 2009/09/11
[ 5.524690] LUN: removable file: (no medium)
[ 5.532331] using random self ethernet address
[ 5.532333] using random host ethernet address
[ 5.644910] rndis0: HOST MAC 0e:4a:ff:dc:e8:bc
[ 5.645164] rndis0: MAC 0e:4a:ff:dc:e8:bd
[ 5.651121] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.665974] usb0: HOST MAC 0e:4a:ff:dc:e8:be
[ 5.666006] usb0: MAC 0e:4a:ff:dc:e8:bf
[ 5.666031] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.670935] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.670953] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.670984] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.671211] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.671224] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 5.671821] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 5.671841] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.672064] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.678519] l4tbr0: port 1(rndis0) entered blocking state
[ 5.678521] l4tbr0: port 1(rndis0) entered disabled state
[ 5.679844] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.679849] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.679852] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.679855] usb 2-1: Manufacturer: Generic
[ 5.681797] device rndis0 entered promiscuous mode
[ 5.683345] hub 2-1:1.0: USB hub found
[ 5.684134] hub 2-1:1.0: 4 ports detected
[ 5.736501] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.737612] eth0: 0xffffff800abe2000, 00:04:4b:e7:13:ee, IRQ 407
[ 5.866728] usb 2-1: usb_suspend_both: status 0
[ 5.866882] usb usb2: usb_suspend_both: status 0
[ 5.922549] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.925464] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.930459] l4tbr0: port 2(usb0) entered blocking state
[ 5.930462] l4tbr0: port 2(usb0) entered disabled state
[ 5.930935] device usb0 entered promiscuous mode
[ 5.950728] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.120372] zram: Added device: zram0
[ 6.124523] zram: Added device: zram1
[ 6.130404] zram: Added device: zram2
[ 6.136476] zram: Added device: zram3
[ 6.182931] zram0: detected capacity change from 0 to 518549504
[ 6.285629] Adding 506392k swap on /dev/zram0. Priority:5 extents:1 across:506392k SS
[ 6.295201] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.305007] zram1: detected capacity change from 0 to 518549504
[ 6.322667] Adding 506392k swap on /dev/zram1. Priority:5 extents:1 across:506392k SS
[ 6.325725] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 6.330248] zram2: detected capacity change from 0 to 518549504
[ 6.344044] Adding 506392k swap on /dev/zram2. Priority:5 extents:1 across:506392k SS
[ 6.354561] zram3: detected capacity change from 0 to 518549504
[ 6.381077] Adding 506392k swap on /dev/zram3. Priority:5 extents:1 across:506392k SS
[ 6.441917] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.1/input2
[ 6.505720] usbcore: registered new interface driver r8188eu
[ 6.566425] logitech-djreceiver 0003:046D:C52B.0006: hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.3/input2
[ 8.064150] tegradc tegradc.0: blank - powerdown
[ 8.094634] input: Logitech M505/B605 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/0003:046D:C52B.0003/0003:046D:101D.0007/input/input2
[ 8.095032] logitech-hidpp-device 0003:046D:101D.0007: input,hidraw2: USB HID v1.11 Mouse [Logitech M505/B605] on usb-70090000.xusb-2.1:1
[ 8.107172] input: Logitech K520 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:046D:C52B.0006/0003:046D:2011.0008/input/input3
[ 8.110931] logitech-hidpp-device 0003:046D:2011.0008: input,hidraw3: USB HID v1.11 Keyboard [Logitech K520] on usb-70090000.xusb-2.3:1
[ 8.116417] input: Logitech M310 as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:046D:C52B.0006/0003:046D:1024.0009/input/input4
[ 8.116618] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 8.116620] Extcon AUX1(HDMI) disable
[ 8.116734] logitech-hidpp-device 0003:046D:1024.0009: input,hidraw4: USB HID v1.11 Mouse [Logitech M310] on usb-70090000.xusb-2.3:2
[ 8.138483] tegradc tegradc.0: unblank
[ 8.149041] tegradc tegradc.0: nominal-pclk:319750000 parent:319750000 div:1.0 pclk:319750000 316552500~348527500
[ 8.149137] tegradc tegradc.0: hdmi: tmds rate:319750K prod-setting:prod_c_hdmi_300m_600m
[ 8.156055] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 8.156062] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 8.190910] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 8.190913] Extcon AUX1(HDMI) enable
[ 8.208018] tegradc tegradc.0: unblank
[ 8.208031] tegradc tegradc.1: blank - powerdown
[ 8.254058] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.811048] MAC Address = d0:37:45:63:39:a7
[ 8.813388] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.890946] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.711236] R8188EU: assoc success
[ 11.817141] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.029365] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.029379] Bluetooth: BNEP socket layer initialized
[ 13.490775] fuse init (API version 7.26)
[ 14.729687] tegradc tegradc.0: unblank
[ 14.729697] tegradc tegradc.1: blank - powerdown
[ 42.830747] usb 1-2.4: new high-speed USB device number 6 using tegra-xusb
[ 42.853644] usb 1-2.4: New USB device found, idVendor=1415, idProduct=2000
[ 42.853650] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 42.853653] usb 1-2.4: Product: USB Camera-B4.04.27.1
[ 42.853656] usb 1-2.4: Manufacturer: OmniVision Technologies, Inc.
[ 42.858188] usb 1-2.4: current rate 724 is different from the runtime rate 16000
[ 42.868032] usb 1-2.4: 3:1: cannot get min/max values for control 2 (id 3)
[ 43.046435] gspca_main: v2.14.0 registered
[ 43.048942] gspca_main: ov534-2.14.0 probing 1415:2000
[ 45.047985] usbcore: registered new interface driver ov534
[ 45.153963] usb 1-2.4: current rate 18339 is different from the runtime rate 16000
[ 45.164017] usb 1-2.4: 3:1: cannot get min/max values for control 2 (id 3)
[ 45.235304] usb 1-2.4: current rate 650 is different from the runtime rate 16000
[ 45.245200] usb 1-2.4: 3:1: cannot get min/max values for control 2 (id 3)
[ 45.264105] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.271172] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.278219] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.285262] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.292305] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.299383] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.306428] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.313512] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.320557] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.327630] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.334673] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.341716] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.348757] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.355829] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.362870] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.369912] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.376953] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.384026] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.391068] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.398109] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.405151] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.412224] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.419291] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.426332] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.433374] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.440446] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.447487] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.454529] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.461572] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.468643] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.475685] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.482726] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.489768] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.496841] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.503883] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.510927] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.517998] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.525070] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.532112] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.539153] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.546195] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.553264] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.560306] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.567347] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.574389] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.581459] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.588500] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.595542] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.602583] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.609656] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.616698] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.623765] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.630817] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.637889] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.644931] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.651973] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.659015] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.666087] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.673127] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.680168] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.687211] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.694282] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.701322] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.708364] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.715406] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.722535] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.729579] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.736621] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.743690] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.750764] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.757806] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.764848] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.771889] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.778961] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.786003] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.793045] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.800087] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.807160] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.814202] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.821244] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.828315] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.835391] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.842433] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.849477] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.856519] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.863688] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.870739] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.877780] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.884822] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.891915] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.898959] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.906004] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.913045] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.920148] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.927302] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.934349] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.941392] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.948464] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.955505] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.962546] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.969588] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.976659] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.983700] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.990743] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 45.997785] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.004857] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.011899] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.018941] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.025983] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.033056] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.040099] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.047140] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.054180] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.061253] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.068293] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.075335] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.082378] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.089451] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.096493] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.103535] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.110577] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.117649] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.124690] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.131760] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.138803] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.145876] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.152918] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.159959] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.167000] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.174074] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.181115] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.188156] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.195198] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.202270] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.209312] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.216354] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.223395] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.230466] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.237533] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.244575] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.251617] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.258689] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.265730] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.272771] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.279812] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.286883] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.293927] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.300969] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.308010] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.315082] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.322125] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.329165] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.336236] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.343310] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.350351] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.357394] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.364435] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.371506] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.378547] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.385589] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.392631] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.399702] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.406744] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.413785] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.420826] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.427897] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.434939] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.442047] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.449096] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.456196] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.463262] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.470304] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.477344] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.484402] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.491460] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.498501] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.505542] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.512599] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.519656] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.526696] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.533738] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.540828] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.547886] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.554927] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.561969] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.569026] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.576083] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.583125] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.590165] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.597221] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.604278] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.611321] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.618363] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.625419] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.632474] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.639514] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.646597] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.653655] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.660716] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.667759] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.674801] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.681858] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.688914] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.695957] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.702999] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.710056] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.717112] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.724154] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.731196] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.738253] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.745365] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.752410] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.759452] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.766509] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.773564] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.780605] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.787647] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.794702] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.801759] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.808801] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.815843] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.822900] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.829955] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.836996] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.844037] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.851094] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.858152] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.865193] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.872237] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.879294] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.886351] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.893392] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.900434] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.907487] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.914543] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.921585] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.928627] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.935684] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.942775] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.949818] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.956885] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.963944] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.970999] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.978041] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.985082] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.992139] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 46.999196] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.006323] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.013373] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.020432] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.027511] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.034560] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.041600] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.048648] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.055748] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.062799] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.069839] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.076883] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.083957] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.091008] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.098051] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.105100] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.112174] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.119225] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.126266] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.133316] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.140371] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.147421] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.154491] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.161541] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.168597] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.175646] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.182688] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.189738] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.196794] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.203842] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.210884] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.217933] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.224989] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.232038] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.239081] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.246130] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.253186] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.260263] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.267305] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.274353] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.281410] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.288459] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.295501] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.302549] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.309606] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.316654] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.323696] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.330746] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.337804] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.344853] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.351895] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.358942] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.366029] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.373080] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.380122] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.387172] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.394228] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.401278] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.408319] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.415368] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.422425] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.429473] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.436516] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.443565] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.450623] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.457670] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.464742] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.471794] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.478851] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.485900] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.492943] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.499993] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.507051] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.514100] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.521143] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.528192] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.535248] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.542297] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.549339] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.556389] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.563446] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.570524] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.577566] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.584652] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.591711] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.598759] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.605799] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.612846] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.619902] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.626951] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.633994] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.641042] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.648098] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.655146] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.662200] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.669286] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.676346] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.683394] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.690436] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.697486] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.704542] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.711591] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.718633] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.725682] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.732739] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.739788] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.746830] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.753879] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.760936] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.767985] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.775080] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.782131] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.789188] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.796236] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.803279] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.810328] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.817386] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.824434] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.831475] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.838524] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.845581] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.852631] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.859673] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.866721] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.873809] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.880862] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.887903] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.894954] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.902012] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.909061] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.916103] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.923153] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.930210] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.937259] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.944303] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.951352] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.958408] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.965457] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.972500] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.979627] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.986687] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 47.993736] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.000781] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.007832] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.014894] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.021945] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.028988] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.036036] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.043093] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.050141] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.057183] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.064231] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.071288] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.078337] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.085379] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.092428] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.099483] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.106532] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.113573] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.120621] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.127677] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.134726] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.141805] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.148858] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.155994] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.163053] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.170094] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.177143] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.184219] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.191269] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.198309] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.205356] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.212425] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.219474] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.226515] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.233563] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.240620] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.247670] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.254712] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.261761] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.268817] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.275867] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.282911] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.289962] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.297020] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.304070] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.311112] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.318160] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.325217] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.332267] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.339309] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.346359] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.353416] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.360466] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.367507] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.374556] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.381613] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.388663] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.395705] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.402754] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.409811] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.416860] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.423903] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.430953] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.438015] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.445064] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.452107] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.459156] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.466212] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.473262] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.480304] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.487352] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.494409] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.501459] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.508500] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.515549] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.522606] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.529656] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.536698] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.543747] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.550804] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.557855] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.564898] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.571947] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.579003] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.586052] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.593095] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.600144] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.607201] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.614250] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.621293] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.628342] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.635400] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.642450] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.649491] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.656540] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.663599] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.670648] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.677690] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.684739] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.691796] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.698845] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.705887] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.712936] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.719994] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.727043] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.734085] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.741133] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.748190] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.755336] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.762388] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.769439] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.776497] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.783569] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.790612] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.797690] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.804749] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.811813] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.818853] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.825900] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.832954] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.840019] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.847063] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.854113] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.861171] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.868236] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.875283] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.882333] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.889390] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.896475] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.903520] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.910570] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.917627] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.924677] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.931719] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.938770] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.945826] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.952875] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.959917] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.966968] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.974024] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.981074] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.988117] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 48.995166] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.002250] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.009301] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.016343] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.023391] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.030446] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.037496] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.044537] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.051586] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.058644] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.065693] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.072735] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.079784] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.086840] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.093888] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.100960] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.108011] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.115069] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.122119] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.129162] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.136212] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.143268] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.150317] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.157358] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.164406] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.171463] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.178513] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.185555] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.192604] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.199660] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.206738] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.213783] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.220833] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.227890] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.234939] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.241980] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.249030] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.256088] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.263136] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.270179] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.277228] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.284284] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.291335] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.298377] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.305454] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 49.521525] usb 1-2.4: USB disconnect, device number 6
[ 49.522105] usb 1-2.4: cannot submit urb (err = -19)
[ 49.534751] usb 1-2.4: 2:1: cannot set freq 16000 to ep 0x84
