connectx-6 lx teaming mlx5muxtool doesn't find adapters
Hello there,
i recently installed a connectx-6 lx card in a workstation running windows 10 21H2. i downloaded and installed the latest WINOF2-driver version 2.70.53000_all with all features.
in my device manager i can get the following information:
Driver version: 2.70.24739.0
Firmware version: 26.31.1014
Part number: MCX6311102AC-ADAT
I then ran the mlx5up.exe to ensure the latest firmware version is installed.
running “mlx5muxtool showlist” shows no results.
i checked the registry. the value for installed path unter HKEY_LOCAL_MACHINE_\SOFTWARE\MELLANOX\MLNX_WINOF2 is C:\Program Files\Mellanox\MLNX_WINOF2
so in theory I assume the muxtool should be able to find the mux drivers. What am i missing here? Can anybody help me in that case?
best regards,
Andreas Wolf
Dear Andreas,
I had the same issue, but I managed to find the IDs for the adapters using PowerShell:
Get-NetAdapter | Select InstanceID, Name
Regards,
Peter
Dear Peter,
until now I didn’t find a solution. There is a new driver version Win-OF-2 2.90 released. I might give that a try together with checking for the latest firmware on the cards.
It seems though that Mellanox isn’t updating the mlx5muxtool. But still worth a try. Other people seemed to have had success with Connectx-6 cards, as far as I remember.
Regards,
Andreas
Hi Peter,
with the updated Win-OF2 3.0 release mlx5muxtool.exe finds adapters and you can create a team normally.
best regards,
Andreas
