Hello, I just bought 3 SN2010 and I can not connect with the console port ! I use the right console cable, speed configured to 115200 but nothing on the screen. The switch works because I can connect on with Ethernet mgmt port with DHCP. Could you help me ? Bast regards,
What type of computer and serial port are you using? I recently had a similar issue with a SN2410 and . Macbook Pro/ USB-C->USB->Serial adapter. For the USB adapter, there were additional drivers that needed to be installed (twice) and reboot twice in order to get the USB serial port to work correctly.
