Hi.
While it was possible to manually change contact properties in URDF when using Isaac Gym, how can they be tuned in Isaac Sim?
What are the default contact properties?
Hi.
| Does URDF-link-contact_coefficient work for contact with IsaacGym ground? | 1 | 410 | December 22, 2023 | |
| Changing properties of objects during simulation in Isaac Gym | 0 | 232 | June 14, 2024 | |
| I want to know if there any Isaac API support setting body's/assert's stiffness to simulate the elastic contact progress | 0 | 518 | July 14, 2022 | |
| Would Isaac Sim support contact force tensor on rigid bodies? | 10 | 2556 | September 29, 2023 | |
| When will Isaac sim or Isaac lab support deformable object contact location/force info? | 4 | 279 | July 29, 2025 | |
| Problem reading the contact sensor on IsaacSim | 3 | 1241 | September 21, 2022 | |
| Get contact report for deformable object? | 5 | 655 | October 27, 2022 | |
| Isaac Sim crashes when importing URDF with many links | 5 | 637 | August 5, 2023 | |
| Contact Restitution with PhysX in IsaacGym | 11 | 2722 | March 18, 2024 | |
| Gap deformable body contacts | 3 | 1423 | December 20, 2021 |
