Contact sensor not working on cloned environments IsaacSim2023.1.0
I was trying to add contact sensors to my environments, cloned using the GridCloner.
To reproduce the issue, I modified the contact_sensor.py example to also clone the Ant and added the creation of a contact sensor one of the cloned ant.
Basically, I cannot create the sensor because “Contact Sensor needs to be created under another prim that has collision api enabled on.”. However, the base environment Ant has collision API enabled, since I am able to create and correctly read from the sensor. I tried to create a GeometryView of the prims and force the application of the collision_api() but nothing seems to work.
This is the modified contact_sensor.py example I am using:
# Copyright (c) 2021-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": False})
import argparse
import sys
import carb
import numpy as np
from omni.isaac.core import World
from omni.isaac.core.articulations import Articulation
from omni.isaac.core.utils.nucleus import get_assets_root_path
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.sensor import ContactSensor
from omni.isaac.cloner import GridCloner
import omni.isaac.core.utils.prims as prim_utils
parser = argparse.ArgumentParser()
parser.add_argument("--test", default=False, action="store_true", help="Run in test mode")
args, unknown = parser.parse_known_args()
assets_root_path = get_assets_root_path()
if assets_root_path is None:
    carb.log_error("Could not find Isaac Sim assets folder")
    simulation_app.close()
    sys.exit()
my_world = World(stage_units_in_meters=1.0)
my_world.scene.add_default_ground_plane()
asset_path = assets_root_path + "/Isaac/Robots/Ant/ant.usd"
add_reference_to_stage(usd_path=asset_path, prim_path="/World/envs/env_0/Ant")
ant = my_world.scene.add(Articulation(prim_path="/World/envs/env_0/Ant/torso", name="ant", translation=np.array([0, 0, 1.5])))
ant_foot_prim_names = ["right_back_foot", "left_back_foot", "front_right_foot", "front_left_foot"]
translations = np.array(
    [[0.38202, -0.40354, -0.0887], [-0.4, -0.40354, -0.0887], [-0.4, 0.4, -0.0887], [0.4, 0.4, -0.0887]]
# moving def prim
# move_prim(robot_prim_path_default, # from
#         robot_base_prim_path) # to
num_envs = 3
env_ns = "/World/envs"
env_spacing = 15 # [m]
template_env_ns = env_ns + "/env_0"
cloner = GridCloner(spacing=env_spacing)
cloner.define_base_env(env_ns)
envs_prim_paths = cloner.generate_paths(env_ns + "/env",
                                num_envs)
cloner.clone(
    source_prim_path=template_env_ns,
    prim_paths=envs_prim_paths,
    replicate_physics=True,
    position_offsets = None
ant_sensors = []
for i in range(4):
    ant_sensors.append(
        my_world.scene.add(
            ContactSensor(
                prim_path="/World/envs/env_0/Ant/" + ant_foot_prim_names[i] + "/contact_sensor",
                name="ant_contact_sensor_{}".format(i),
                min_threshold=0,
                max_threshold=10000000,
                radius=0.1,
                translation=translations[i],
ant_sensors[0].add_raw_contact_data_to_frame()
ant_sensors2 = []
for i in range(4):
    ant_sensors.append(
        my_world.scene.add(
            ContactSensor(
                prim_path="/World/envs/env_1/Ant/" + ant_foot_prim_names[i] + "/contact_sensor",
                min_threshold=0,
                radius=0.1,
ant_sensors2[0].add_raw_contact_data_to_frame()
my_world.reset()
while simulation_app.is_running():
    my_world.step(render=True)
    if my_world.is_playing():
        print(ant_sensors[0].get_current_frame())
        if my_world.current_time_step_index == 0:
            my_world.reset()
Update.
The following modified contact_sensor.py example works:
import argparse
import sys
import carb
import numpy as np
    sys.exit()
# moving def prim
num_envs = 3
                                num_envs)
ant_sensors = []
for i in range(4):
    ant_sensors.append(
        my_world.scene.add(
            ContactSensor(
                min_threshold=0,
                radius=0.1,
ant_sensors2 = []
for i in range(4):
    ant_sensors2.append(
        my_world.scene.add(
            ContactSensor(
                name="ant_contact_sensor2_{}".format(i),
                min_threshold=0,
                radius=0.1,
cloner.clone(
my_world.reset()
        print(ant_sensors2[0].get_current_frame())
            my_world.reset()
Basically, for reasons, you have to call the clone() method after creating the contact sensor.
