I am experiencing an issue where I cannot get the container built using any sort of config file template. No matter what I feed the builder I get the following message:
Does anybody have the same issue
**• Hardware Platform = RTX 3050 Geforce
Can you describe the steps of the Graph Composer container built you have done?
I have followed the steps over here:
https://docs.nvidia.com/metropolis/deepstream/6.4/dev-guide/graphtools-docs/docs/text/GraphComposer_Getting_Started.html
important to note i am doing this on windows with wsl configuration.
Except I am using version 4.1.0, so I type in the configuration key which is x86 and then i copy the builder config file for wsl into windows and use that to build the container in the composer app, using the build container button
Container build is not supported on WSL.
