Crash in carter_warehouse_apriltags_worker scene with deactivation of default Nova_Carter_ROS robot
Why is this happening?:)
Im trying to get the LIMO robot working in this environment but Im also trying to understand how the Nova_Carter_ROS robot is integrated into the scene, so I’m curious to the mechanism behind the bug.
Here’s the terminal output:
2024-12-08 01:07:20 [603,566ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'gpu_0' = 'NVIDIA GeForce RTX 4090'
2024-12-08 01:07:20 [603,567ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'gpu_1' = 'AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)'
2024-12-08 01:07:20 [603,568ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'kitRendererDriverVersion' = '560.35'
2024-12-08 01:07:20 [603,570ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lastCommand' = 'ToolbarPlayButtonClicked'
2024-12-08 01:07:20 [603,571ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lastCommands' = 'CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/Replicator_02_NodeWriterWriter_01,node_type=omni.isaac.ros2_bridge.ROS2PublishCameraInfo,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate_04,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),SetAttrCommand(attr=?,value=1,on_gpu=False,update_usd=False),ToolbarStopButtonClicked,SelectPrimsCommand(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),ToggleActivePrims(stage_or_context=?,prim_paths=?,active=False),Undo,SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),ToggleActivePrims(stage_or_context=?,prim_paths=?,active=False),ToolbarPlayButtonClicked'
2024-12-08 01:07:20 [603,573ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_isaacSim_buildBranch' = 'HEAD'
2024-12-08 01:07:20 [603,574ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_isaacSim_buildDate' = 'Wed Sep 18 06:06:37 2024 +0000'
2024-12-08 01:07:20 [603,576ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_isaacSim_buildHash' = 'c99988b'
2024-12-08 01:07:20 [603,577ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_isaacSim_buildRepo' = 'gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim'
2024-12-08 01:07:20 [603,578ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_isaacSim_buildVersion' = '4.2.0-rc.17'
2024-12-08 01:07:20 [603,580ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_physx_buildBranch' = 'HEAD'
2024-12-08 01:07:20 [603,581ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_physx_buildDate' = 'MISSING PHYSICS_BUILD_DATE'
2024-12-08 01:07:20 [603,583ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_physx_buildHash' = '48c0995'
2024-12-08 01:07:20 [603,584ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_physx_buildRepo' = 'gitlab-master.nvidia.com/omniverse/physics'
2024-12-08 01:07:20 [603,585ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'lib_physx_buildVersion' = '106.1.9'
2024-12-08 01:07:20 [603,587ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'memoryStats' = '(avail/total) RAM: 108.006/125.008GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB'
2024-12-08 01:07:20 [603,588ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'nvidia-smi' = '
==============NVSMI LOG==============
Timestamp                                 : Sat Dec  7 16:55:31 2024
Driver Version                            : 560.35.03
CUDA Version                              : 12.6
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Product Name                          : NVIDIA GeForce RTX 4090
    Product Brand                         : GeForce
    Product Architecture                  : Ada Lovelace
    Display Mode                          : Enabled
    Display Active                        : Enabled
    Persistence Mode                      : Disabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1322023037972
    GPU UUID                              : GPU-f9d8d3f8-5414-db6c-625b-2bef2e999128
    Minor Number                          : 0
    VBIOS Version                         : 95.02.47.00.01
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : 900-1G136-2530-000
    GPU Part Number                       : 2684-301-A1
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : G002.0000.00.03
        OEM Object                        : 2.0
        ECC Object                        : 6.16
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : No
    GSP Firmware Version                  : 560.35.03
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x0
        Device Id                         : 0x268410DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x16F410DE
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 4
                Device Current            : 4
                Device Max                : 4
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 8 KB/s
        Rx Throughput                     : 13 KB/s
        Atomic Caps Outbound              : N/A
        Atomic Caps Inbound               : N/A
    Fan Speed                             : 0 %
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 24564 MiB
        Reserved                          : 476 MiB
        Used                              : 789 MiB
        Free                              : 23301 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 29 MiB
        Free                              : 32739 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 3 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable Parity     : N/A
            SRAM Uncorrectable SEC-DED    : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
            SRAM Threshold Exceeded       : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM Microcontroller          : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 192 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 36 C
        GPU T.Limit Temp                  : 47 C
        GPU Shutdown T.Limit Temp         : -7 C
        GPU Slowdown T.Limit Temp         : -2 C
        GPU Max Operating T.Limit Temp    : 0 C
        GPU Target Temperature            : 83 C
        Memory Current Temp               : N/A
        Memory Max Operating T.Limit Temp : N/A
    GPU Power Readings
        Power Draw                        : 69.39 W
        Current Power Limit               : 450.00 W
        Requested Power Limit             : 450.00 W
        Default Power Limit               : 450.00 W
        Min Power Limit                   : 150.00 W
        Max Power Limit                   : 600.00 W
    GPU Memory Power Readings
        Power Draw                        : N/A
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 2520 MHz
        SM                                : 2520 MHz
        Memory                            : 10501 MHz
        Video                             : 1980 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Default Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 10501 MHz
        Video                             : 2415 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : 975.000 mV
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 2935
            Type                          : G
            Used GPU Memory               : 363 MiB
        Process ID                        : 3158
            Type                          : G
            Used GPU Memory               : 108 MiB
        Process ID                        : 3929
            Type                          : G
            Used GPU Memory               : 112 MiB
        Process ID                        : 4772
            Type                          : G
            Used GPU Memory               : 6 MiB
        Process ID                        : 300257
            Type                          : G
            Used GPU Memory               : 91 MiB
        Process ID                        : 332255
            Type                          : G
            Used GPU Memory               : 67 MiB
    Capabilities
        EGM                               : disabled
2024-12-08 01:07:20 [603,590ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osDistro' = 'ubuntu'
2024-12-08 01:07:20 [603,591ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osName' = '22.04.5 LTS (Jammy Jellyfish)'
2024-12-08 01:07:20 [603,592ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osVersion' = '22.04.5'
2024-12-08 01:07:20 [603,594ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'portableMode' = '0'
2024-12-08 01:07:20 [603,595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'primaryDisplayRes' = '1920x1200x32bit@60Hz'
2024-12-08 01:07:20 [603,596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'runEnvironment' = 'Individual'
2024-12-08 01:07:20 [603,598ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'runningInContainer' = '0'
2024-12-08 01:07:20 [603,599ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_debugSymbols' = '0'
2024-12-08 01:07:20 [603,600ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIncludeOverrides' = '0'
2024-12-08 01:07:20 [603,602ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIntermediates' = '0'
2024-12-08 01:07:20 [603,603ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_obfuscateCode' = '1'
2024-12-08 01:07:20 [603,604ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_optimizationLevel' = '1'
2024-12-08 01:07:20 [603,606ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'systemInfo' = '
| Driver Version: 560.35.03     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 4090          | Yes: 0 |     | 24564   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | f9d8d3f8.. |
|     |                                  |        |     |            | 1         |            |
| 1   | AMD Radeon Graphics (RADV RAPH.. |        |     | 43010   MB | 1002      | 0          |
|     |                                  |        |     |            | 164e      | 00000000.. |
|     |                                  |        |     |            | 6b        |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.9.3-76060903-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 9 7950X 16-Core Processor | Cores: 16 | Logical: 32
| Total Memory (MB): 128007 | Free Memory: 116081
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2024-12-08 01:07:20 [603,607ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'telemetrySessionId' = '11632655830688650253'
2024-12-08 01:07:20 [603,609ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'terminatedByAbort' = '0'
2024-12-08 01:07:20 [603,610ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'userId' = 'default'
2024-12-08 01:07:20 [603,611ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'workingDirectory' = '/home/<username>'
2024-12-08 01:07:20 [603,613ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-12-08 01:07:20 [603,614ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'upload_file_minidump' = '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip'
2024-12-08 01:07:21 [604,426ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip', code:200, response:
2024-12-08 01:07:21 [604,429ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]     c6d43c40-b500-11ef-b25c-0663cb1990b3
2024-12-08 01:07:21 [604,431ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save)
2024-12-08 01:07:21 [604,432ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip' with 10 retries remaining.
2024-12-08 01:07:21 [604,433ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip.toml'
2024-12-08 01:07:21 [604,435ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/brettpac/.local/share/ov/data/Kit/Isaac-Sim/4.2/02818b77-9872-4cf0-50ad068c-648df769.dmp.zip.toml' with 10 retries remaining.
terminate called recursively
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: 4090
  • Driver Version:
Thank you,
Hey @brettpac Sorry for my late reply! Thanks for bringing this issue up. I am able to replicate it on Isaac Sim 4.5 as well. Let me pass this to the internal team for investigation.
Hi @zhengwang, any update on this?
Also, can you share or cc whoever is on the internal team? I think it’s called for given that we’re basically dealing with the default testing scene for the vision pipeline in IsaacSim. - Thank you,
Hey @brettpac. Our internal team has already worked out a fix for this issue and it is expected to be released with Isaac Sim 5.0.0.
