Description
I am experiencing intermittent crashes when running the nvblox example with a ZED X Mini camera. The system environment is based on the latest JetPack 6.2.1 and Isaac ROS 3.2. The crash typically occurs during runtime while the voxel map is being integrated.
Environment & Hardware
Hardware: Jetson Orin NX 16GB
Camera: ZED X Mini
JetPack Version: 6.2.1 (L4T R36.4.4)
CUDA Version: 12.6.68
ROS 2 Distribution: Humble
ZED SDK Version: 5.0.7
Isaac ROS Version: 3.2
Context & Observed Behavior
The
nvbloxnode starts correctly and begins processing depth/color data from the ZED X Mini. -
After some time (or specific camera movements), the process terminates/crashes.
