Isaac Sim Version
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04 (Docker)
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: 2x4080SUPER
- Driver Version: 570.172.08
Topic Description
Detailed Description
I am trying to run the standalone example object_based_sdg.py with adaptive sampling. However, everytime I enables the adaptive sampling, the program will crash and from /isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/a7f36df4-9216-4bad-8d32d98b-4133d1f5.py.txt we can see that it is this line of code that is causing the crash: rep.orchestrator.step(delta_time=duration, pause_timeline=False)
Is this because the rep.orchestrator does not support adaptive sampling for some reason or the adaptive sampling naturally does not work with some other options?
Steps to Reproduce
run the docker with this command (I made some modifications so that the UI can show up on my computer’s screen):
docker run --name isaac-sim --entrypoint bash -it --runtime=nvidia --gpus all -e “ACCEPT_EULA=Y” --rm --network=host \-e "PRIVACY_CONSENT=Y" \\-e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-v $HOME/.Xauthority:/root/.Xauthority:ro \
-v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache:rw \
-v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw \
-v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw \
-v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw \
-v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw \
-v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw \
-v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw \
-v ~/docker/isaac-sim/documents:/root/Documents:rw \
-v $(pwd):/isaac-sim/workspace:ro \
run this command to enable the adaptiveSampling on launching:
./python.sh ./standalone_examples/replicator/object_based_sdg/object_based_sdg.py --kit_args “–/rtx/pathtracing/adaptiveSampling/enabled=True”
Error Messages
root@gps-gps:/isaac-sim# ./python.sh ./standalone_examples/replicator/object_based_sdg/object_based_sdg.py --kit_args “–/rtx/pathtracing/adaptiveSampling/enabled=True”
[Warning] [main] File None does not exist, will use default config
[SDG] Using config:
{‘launch_config’: {‘renderer’: ‘RaytracedLighting’, ‘headless’: False}, ‘env_url’: ‘’, ‘working_area_size’: (4, 4, 3), ‘rt_subframes’: 4, ‘num_frames’: 10, ‘num_cameras’: 3, ‘camera_collider_radius’: 0.5, ‘disable_render_products_between_captures’: False, ‘simulation_duration_between_captures’: 0.05, ‘resolution’: (640, 480), ‘camera_properties_kwargs’: {‘focalLength’: 24.0, ‘focusDistance’: 400, ‘fStop’: 0.0, ‘clippingRange’: (0.01, 10000)}, ‘camera_look_at_target_offset’: 0.15, ‘camera_distance_to_target_min_max’: (0.25, 0.75), ‘writer_type’: ‘PoseWriter’, ‘writer_kwargs’: {‘output_dir’: ‘_out_obj_based_sdg_pose_writer’, ‘format’: None, ‘use_subfolders’: False, ‘write_debug_images’: True, ‘skip_empty_frames’: False}, ‘labeled_assets_and_properties’: [{‘url’: ‘/Isaac/Props/YCB/Axis_Aligned/008_pudding_box.usd’, ‘label’: ‘pudding_box’, ‘count’: 5, ‘floating’: True, ‘scale_min_max’: (0.85, 1.25)}, {‘url’: ‘/Isaac/Props/YCB/Axis_Aligned_Physics/006_mustard_bottle.usd’, ‘label’: ‘mustard_bottle’, ‘count’: 7, ‘floating’: True, ‘scale_min_max’: (0.85, 1.25)}], ‘shape_distractors_types’: [‘capsule’, ‘cone’, ‘cylinder’, ‘sphere’, ‘cube’], ‘shape_distractors_scale_min_max’: (0.015, 0.15), ‘shape_distractors_num’: 350, ‘mesh_distractors_urls’: [‘/Isaac/Environments/Simple_Warehouse/Props/SM_CardBoxD_04_1847.usd’, ‘/Isaac/Environments/Simple_Warehouse/Props/SM_CardBoxA_01_414.usd’, ‘/Isaac/Environments/Simple_Warehouse/Props/S_TrafficCone.usd’], ‘mesh_distractors_scale_min_max’: (0.35, 1.35), ‘mesh_distractors_num’: 75}
Starting kit application with the following args: [‘/isaac-sim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py’, ‘/isaac-sim/apps/isaacsim.exp.base.python.kit’, ‘–/app/tokens/exe-path=/isaac-sim/kit’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True’, ‘–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–/app/fastShutdown=True’, ‘–/app/installSignalHandlers=0’, ‘–ext-folder’, ‘/isaac-sim/exts’, ‘–ext-folder’, ‘/isaac-sim/apps’, ‘–/physics/cudaDevice=0’, ‘–/plugins/carb.tasking.plugin/threadCount=32’, ‘–/plugins/omni.tbb.globalcontrol/maxThreadCount=32’, ‘–portable’, ‘–allow-root’]
Passing the following args to the base kit application: [‘–kit_args’, ‘–/rtx/pathtracing/adaptiveSampling/enabled=True’]
[Info] [carb] Logging to file: /isaac-sim/kit/logs/Kit/Isaac-Sim Python/5.0/kit_20250928_171041.log
2025-09-28T09:10:41Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘/isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/9b4ecd8d-e80d-4dc3-529aa791-4fe75458.dmp’
[0.033s] [ext: omni.kit.async_engine-0.0.3] startup
[0.361s] [ext: omni.metrics.core-0.0.3] startup
[0.361s] [ext: omni.client.lib-1.1.0] startup
[0.371s] [ext: omni.blobkey-1.1.2] startup
[0.371s] [ext: omni.stats-1.0.1] startup
[0.371s] [ext: omni.datastore-0.0.0] startup
[0.375s] [ext: omni.client-1.3.0] startup
[0.378s] [ext: omni.ujitso.default-1.0.0] startup
[0.379s] [ext: omni.hsscclient-1.1.2] startup
[0.381s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.382s] [ext: omni.assets.plugins-0.0.0] startup
[0.383s] [ext: omni.gpu_foundation-0.0.0] startup
[0.387s] [ext: carb.windowing.plugins-1.0.0] startup
[0.399s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 570.172.08 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4080 SUPER | Yes: 0 | | 16622 MB | 10de | 0 |
| | | | | | 2702 | 20a81fcf.. |
| | | | | | 1 | |
| 1 | NVIDIA GeForce RTX 4080 SUPER | Yes: 1 | | 16622 MB | 10de | 0 |
| | | | | | 2702 | 6682bb6d.. |
| | | | | | 5 | |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-83-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: Intel(R) Core™ i9-14900KF
| Bare Metal Cores: 24 | Bare Metal Logical Cores: 48
| Available Cores: 32 |
| Total Memory (MB): 64081 |
| Total Page/Swap (MB): 2047 |
| 2025-09-28T09:10:42Z [1,273ms] [Warning] [gpu.foundation.plugin] CPU performance profile is set to powersave. This profile sets the CPU to the lowest frequency reducing performance. |
| 2025-09-28T09:10:42Z [1,280ms] [Warning] [gpu.foundation.plugin] Device 0 PCIe link current width 16 anddevice 1 PCIe link current width 4 don’t match. |
| 2025-09-28T09:10:42Z [1,280ms] [Warning] [gpu.foundation.plugin] PCIe link width current (4) and maximum (16) for device 1 don’t match. |
| 2025-09-28T09:10:42Z [1,280ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. |
| 2025-09-28T09:10:42Z [1,280ms] [Warning] [gpu.foundation.plugin] Detected IOMMU is enabled. Running CUDA peer-to-peer bandwidth and latency validation. |
| Unidirectional P2P=Enabled Bandwidth (P2P Writes) Matrix (GB/s) |
| D\D 0 1 |
0 505.99 5.68
1 6.06 627.26
P2P=Enabled Latency (P2P Writes) Matrix (us)
GPU 0 1
0 1.25 18.50
1 18.45 1.22
CPU 0 1
0 1.21 3.12
1 2.95 1.07
2025-09-28T09:10:42Z [1,582ms] [Warning] [gpu.foundation.plugin] CUDA peer-to-peer observed bandwidth: 5.7 GB/s.
2025-09-28T09:10:42Z [1,582ms] [Warning] [gpu.foundation.plugin] CUDA peer-to-peer observed latency: 18.5 us.
2025-09-28T09:10:42Z [1,582ms] [Warning] [gpu.foundation.plugin] Please verify if observed bandwidth and latency are expected.
[1.827s] [ext: omni.kit.pipapi-0.0.0] startup
[1.828s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.828s] [ext: omni.materialx.libs-1.0.7] startup
[1.833s] [ext: omni.pip.compute-1.6.2] startup
[1.833s] [ext: omni.usd.config-1.0.6] startup
[1.835s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.836s] [ext: omni.usd.libs-1.0.1] startup
[1.879s] [ext: omni.mdl-56.0.3] startup
[1.944s] [ext: omni.iray.libs-0.0.0] startup
[1.948s] [ext: omni.mdl.neuraylib-0.2.12] startup
[1.951s] [ext: omni.kit.usd.mdl-1.1.4] startup
[2.020s] [ext: omni.pip.cloud-1.3.6] startup
[2.022s] [ext: omni.isaac.core_archive-2.6.1] startup
[2.023s] [ext: omni.kit.telemetry-0.5.2] startup
[2.041s] [ext: omni.kit.loop-isaac-1.3.7] startup
[2.041s] [ext: omni.kit.test-2.0.1] startup
[2.078s] [ext: omni.isaac.ml_archive-3.0.2] startup
[2.079s] [ext: omni.appwindow-1.1.10] startup
[2.267s] [ext: omni.kit.renderer.core-1.1.0] startup
[6.684s] [ext: omni.kit.renderer.capture-0.0.0] startup
[6.686s] [ext: omni.kit.renderer.imgui-2.0.5] startup
[6.908s] [ext: omni.ui-2.26.18] startup
[6.914s] [ext: omni.kit.mainwindow-1.0.3] startup
[6.914s] [ext: carb.audio-0.1.0] startup
[6.916s] [ext: omni.uiaudio-1.0.0] startup
[6.917s] [ext: omni.kit.uiapp-0.0.0] startup
[6.917s] [ext: omni.usd.schema.metrics.assembler-107.3.1] startup
[6.918s] [ext: omni.usd.schema.anim-0.0.0] startup
[6.930s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[6.934s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[6.935s] [ext: omni.anim.graph.schema-107.3.0] startup
[6.939s] [ext: omni.usd.schema.audio-0.0.0] startup
[6.940s] [ext: omni.usd.schema.semantics-0.0.0] startup
[6.942s] [ext: omni.usd_resolver-1.0.0] startup
[6.943s] [ext: usdrt.scenegraph-7.6.1] startup
[6.966s] [ext: omni.kit.actions.core-1.0.0] startup
[6.967s] [ext: omni.timeline-1.0.14] startup
[6.968s] [ext: omni.usd.core-1.5.3] startup
[6.969s] [ext: omni.resourcemonitor-107.0.1] startup
[6.971s] [ext: omni.activity.core-1.0.3] startup
[6.971s] [ext: omni.kit.audiodeviceenum-1.0.2] startup
[6.972s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[6.975s] [ext: omni.graph.exec-0.9.6] startup
[6.976s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[6.978s] [ext: omni.kit.exec.core-0.13.4] startup
[6.979s] [ext: omni.kit.widget.nucleus_connector-2.0.1] startup
[6.980s] [ext: omni.kit.usd_undo-0.1.8] startup
[6.980s] [ext: omni.kit.commands-1.4.10] startup
[6.983s] [ext: omni.hydra.scene_delegate-0.3.4] startup
[6.985s] [ext: omni.usd-1.13.10] startup
2025-09-28T09:10:48Z [6,985ms] [Warning] [omni.usd.audio] failed to subscribe to stage events
[7.005s] [ext: omni.inspect-1.0.2] startup
[7.005s] [ext: omni.kit.notification_manager-1.0.10] startup
[7.006s] [ext: omni.graph.core-2.184.3] startup
[7.008s] [ext: isaacsim.core.deprecation_manager-0.2.7] startup
[7.008s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[7.010s] [ext: omni.usd.schema.isaac-3.0.5] startup
[7.010s] [ext: isaacsim.robot.schema-3.5.1] startup
[7.015s] [ext: omni.usd.schema.omni_sensors-0.0.0] startup
[7.015s] [ext: omni.usd.schema.omni_lens_distortion-0.0.0] startup
[7.015s] [ext: omni.anim.navigation.schema-107.3.0] startup
[7.017s] [ext: omni.usd.schema.physx-107.3.18] startup
[7.036s] [ext: omni.usd.schema.flow-107.1.1] startup
[7.037s] [ext: omni.usd.schema.render_settings.rtx-0.0.0] startup
[7.037s] [ext: omni.kit.asset_converter-4.1.4] startup
[7.044s] [ext: omni.convexdecomposition-107.3.18] startup
[7.046s] [ext: omni.graph.tools-1.79.2] startup
[7.061s] [ext: omni.physx.foundation-107.3.18] startup
[7.062s] [ext: omni.kvdb-107.3.18] startup
[7.063s] [ext: omni.graph.action_core-1.1.7] startup
[7.064s] [ext: omni.graph-1.141.2] startup
[7.090s] [ext: omni.usdphysics-107.3.18] startup
[7.092s] [ext: omni.localcache-107.3.18] startup
[7.093s] [ext: omni.kit.menu.core-1.1.2] startup
[7.094s] [ext: omni.kit.widget.path_field-2.0.11] startup
[7.094s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[7.096s] [ext: omni.kit.widget.context_menu-1.2.5] startup
[7.097s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[7.098s] [ext: omni.kit.clipboard-1.0.5] startup
[7.099s] [ext: omni.kit.widget.options_button-1.0.3] startup
[7.099s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[7.100s] [ext: omni.kit.usd.layers-2.2.10] startup
[7.105s] [ext: omni.kit.menu.utils-2.0.3] startup
[7.109s] [ext: omni.ui.scene-1.11.4] startup
[7.112s] [ext: omni.kit.widget.filebrowser-2.12.2] startup
[7.115s] [ext: omni.kit.stage_template.core-1.1.22] startup
[7.115s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[7.118s] [ext: omni.kit.window.filepicker-2.13.3] startup
[7.126s] [ext: omni.kit.stage_templates-2.0.0] startup
[7.127s] [ext: omni.graph.action_nodes-1.50.4] startup
[7.132s] [ext: omni.physx.cooking-107.3.18] startup
[7.134s] [ext: omni.warp.core-1.7.1] startup
[7.258s] [ext: omni.usd.metrics.assembler-107.3.1] startup
[7.261s] [ext: omni.physx-107.3.18] startup
[7.266s] [ext: omni.physics-107.3.18] startup
[7.270s] [ext: isaacsim.core.experimental.utils-0.2.0] startup
[7.272s] [ext: omni.graph.action-1.130.0] startup
[7.274s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[7.275s] [ext: omni.physics.physx-107.3.18] startup
[7.277s] [ext: omni.physics.stageupdate-107.3.18] startup
[7.292s] [ext: omni.kit.numpy.common-0.1.2] startup
[7.295s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[7.299s] [ext: isaacsim.test.docstring-1.1.0] startup
[7.304s] [ext: omni.isaac.dynamic_control-2.0.7] startup
2025-09-28T09:10:48Z [7,295ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[7.310s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[7.312s] [ext: omni.hydra.engine.stats-1.0.3] startup
[7.314s] [ext: omni.physics.tensors-107.3.18] startup
[7.320s] [ext: omni.index.libs-380600.5717.0] startup
[7.320s] [ext: omni.volume-0.5.2] startup
[7.322s] [ext: omni.ujitso.client-0.0.0] startup
[7.323s] [ext: omni.index-1.0.1] startup
[7.323s] [ext: omni.usd.metrics.assembler.physics-107.3.18] startup
[7.324s] [ext: omni.hydra.rtx-1.0.0] startup
2025-09-28T09:10:48Z [7,320ms] [Warning] [omni.log] Source: omni.hydra was already registered.
[7.342s] [ext: omni.kit.viewport.registry-104.0.6] startup
[7.342s] [ext: omni.kit.viewport.legacy_gizmos-1.0.18] startup
[7.344s] [ext: omni.kit.raycast.query-1.1.0] startup
[7.346s] [ext: omni.kit.context_menu-1.8.6] startup
[7.348s] [ext: omni.kit.viewport.scene_camera_model-1.0.6] startup
[7.350s] [ext: omni.kit.hydra_texture-1.4.5] startup
[7.352s] [ext: omni.kit.window.file_importer-1.1.18] startup
[7.353s] [ext: isaacsim.core.version-2.0.6] startup
[7.354s] [ext: omni.kit.window.drop_support-1.0.5] startup
[7.355s] [ext: omni.kit.widget.viewport-107.1.3] startup
[7.358s] [ext: omni.kit.material.library-2.0.7] startup
[7.361s] [ext: isaacsim.storage.native-1.2.8] startup
[7.362s] [ext: omni.kit.viewport.window-107.0.12] startup
[7.374s] [ext: omni.physx.tensors-107.3.18] startup
[7.382s] [ext: isaacsim.core.utils-3.4.5] startup
[7.384s] [ext: omni.kit.viewport.utility-1.1.2] startup
[7.388s] [ext: omni.kit.menu.create-2.0.1] startup
[7.390s] [ext: isaacsim.core.simulation_manager-1.3.2] startup
[8.290s] [ext: omni.graph.visualization.nodes-2.1.3] startup
[8.295s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[8.297s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[8.299s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[8.300s] [ext: omni.kit.usd.collect-2.4.5] startup
[8.303s] [ext: omni.kit.window.file_exporter-1.0.33] startup
[8.304s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[8.306s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[8.307s] [ext: omni.kit.window.file-2.0.5] startup
[8.310s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[8.311s] [ext: omni.kit.widget.filter-1.1.4] startup
[8.312s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[8.312s] [ext: omni.kit.widget.stage_icons-1.0.8] startup
[8.313s] [ext: omni.kit.widget.stage-3.1.4] startup
[8.326s] [ext: omni.kit.window.property-1.12.1] startup
[8.328s] [ext: omni.kit.window.content_browser-3.1.1] startup
[8.337s] [ext: omni.kit.window.stage-2.6.1] startup
[8.340s] [ext: omni.kit.property.usd-4.5.11] startup
[8.348s] [ext: omni.ui_query-1.1.8] startup
[8.350s] [ext: omni.kit.widget.prompt-1.0.7] startup
[8.351s] [ext: omni.kit.ui_test-1.3.6] startup
[8.353s] [ext: omni.kit.tool.collect-2.2.18] startup
[8.355s] [ext: omni.kit.scripting-107.3.1] startup
[8.358s] [ext: isaacsim.core.experimental.prims-0.6.2] startup
[8.377s] [ext: omni.kit.widget.zoombar-1.0.6] startup
[8.380s] [ext: omni.kit.window.extensions-1.4.26] startup
[8.384s] [ext: isaacsim.replicator.behavior-1.1.14] startup
[8.384s] [ext: isaacsim.core.experimental.objects-0.2.4] startup
[8.387s] [ext: omni.kit.browser.core-2.3.13] startup
[8.391s] [ext: omni.kit.usdz_export-1.0.9] startup
[8.393s] [ext: omni.kit.menu.stage-1.2.7] startup
[8.394s] [ext: omni.kit.browser.folder.core-1.10.9] startup
[8.397s] [ext: omni.kit.tool.asset_importer-4.3.2] startup
[8.402s] [ext: isaacsim.gui.components-1.1.9] startup
[8.405s] [ext: isaacsim.examples.browser-0.1.12] startup
[8.408s] [ext: isaacsim.asset.importer.urdf-2.4.19] startup
[8.447s] [ext: isaacsim.simulation_app-2.9.2] startup
[8.448s] [ext: omni.graph.ui_nodes-1.50.5] startup
[8.453s] [ext: omni.isaac.kit-2.0.6] startup
2025-09-28T09:10:49Z [8,442ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[8.457s] [ext: omni.kit.widget.graph-2.0.0] startup
[8.463s] [ext: omni.graph.image.core-0.6.1] startup
[8.464s] [ext: omni.kit.widget.settings-1.2.3] startup
[8.466s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[8.466s] [ext: omni.graph.image.nodes-1.3.1] startup
[8.467s] [ext: omni.kit.window.preferences-1.8.0] startup
[8.472s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[8.474s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[8.475s] [ext: omni.graph.nodes-1.170.10] startup
[8.482s] [ext: omni.kit.viewport.menubar.core-107.1.5] startup
[8.502s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[8.504s] [ext: omni.videoencoding-0.1.2] startup
[8.505s] [ext: isaacsim.core.prims-0.5.1] startup
[8.517s] [ext: omni.warp-1.7.1] startup
[8.522s] [ext: omni.syntheticdata-0.6.13] startup
[8.545s] [ext: omni.kit.window.material_graph-1.8.23] startup
[8.596s] [ext: omni.graph.scriptnode-1.50.0] startup
[8.599s] [ext: isaacsim.core.api-4.6.10] startup
[8.675s] [ext: omni.replicator.core-1.12.16] startup
2025-09-28T09:10:50Z [8,671ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
Warp 1.7.1 initialized:
CUDA Toolkit 12.8, Driver 12.8
Devices:
“cpu” : “x86_64”
“cuda:0” : “NVIDIA GeForce RTX 4080 SUPER” (16 GiB, sm_89, mempool enabled)
“cuda:1” : “NVIDIA GeForce RTX 4080 SUPER” (16 GiB, sm_89, mempool enabled)
CUDA peer access:
Not supported
Kernel cache:
/root/.cache/warp/1.7.1
2025-09-28T09:10:50Z [8,744ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[8.761s] [ext: isaacsim.robot_motion.lula-4.0.8] startup
[8.767s] [ext: isaacsim.robot.surface_gripper-3.2.6] startup
[8.770s] [ext: isaacsim.core.nodes-3.2.16] startup
[8.781s] [ext: isaacsim.robot_motion.motion_generation-8.0.25] startup
[8.807s] [ext: isaacsim.robot.manipulators-3.3.5] startup
[8.822s] [ext: omni.isaac.core_nodes-2.0.6] startup
2025-09-28T09:10:50Z [8,813ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[8.833s] [ext: isaacsim.robot.manipulators.examples-1.0.17] startup
[8.840s] [ext: omni.kit.property.audio-1.0.16] startup
[8.852s] [ext: isaacsim.cortex.framework-1.0.12] startup
[8.862s] [ext: omni.kit.property.camera-1.0.10] startup
[8.876s] [ext: omni.hydra.scene_api-0.1.2] startup
[8.884s] [ext: omni.kit.property.geometry-2.0.4] startup
[8.895s] [ext: omni.kit.property.light-1.0.12] startup
[8.927s] [ext: isaacsim.cortex.behaviors-2.0.12] startup
[8.934s] [ext: omni.kit.property.material-1.11.9] startup
[8.973s] [ext: omni.kit.property.transform-1.5.12] startup
[8.987s] [ext: omni.kit.property.render-1.2.1] startup
[8.995s] [ext: omni.isaac.cortex-1.0.5] startup
2025-09-28T09:10:50Z [8,982ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
[8.997s] [ext: omni.isaac.cortex.sample_behaviors-2.0.5] startup
2025-09-28T09:10:50Z [8,987ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[9.002s] [ext: omni.anim.curve.core-1.3.1] startup
[9.018s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.12] startup
[9.022s] [ext: omni.kit.property.bundle-1.4.1] startup
[9.026s] [ext: omni.isaac.lula-4.0.6] startup
2025-09-28T09:10:50Z [9,013ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[9.028s] [ext: omni.isaac.manipulators-3.0.7] startup
2025-09-28T09:10:50Z [9,016ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,016ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,016ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,021ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,021ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,021ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,022ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,022ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,022ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-09-28T09:10:50Z [9,022ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[9.037s] [ext: omni.kit.viewport.menubar.lighting-107.3.1] startup
[9.052s] [ext: omni.isaac.lula_test_widget-1.0.6] startup
2025-09-28T09:10:50Z [9,049ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[9.064s] [ext: isaacsim.core.throttling-2.1.10] startup
[9.073s] [ext: isaacsim.asset.importer.mjcf-2.5.8] startup
[9.090s] [ext: omni.kit.selection-0.1.6] startup
[9.106s] [ext: omni.kit.widget.toolbar-2.0.1] startup
[9.219s] [ext: omni.kit.manipulator.transform-107.0.0] startup
[9.245s] [ext: isaacsim.gui.menu-2.3.17] startup
[9.371s] [ext: isaacsim.asset.browser-1.3.19] startup
[9.417s] [ext: omni.kit.manipulator.tool.snap-1.5.13] startup
[9.470s] [ext: omni.kit.manipulator.selector-1.1.3] startup
[9.471s] [ext: omni.isaac.menu-1.0.6] startup
2025-09-28T09:10:50Z [9,458ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[9.472s] [ext: omni.isaac.motion_generation-8.0.7] startup
2025-09-28T09:10:50Z [9,460ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,460ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,461ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,461ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,461ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,461ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,461ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,462ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-09-28T09:10:50Z [9,463ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[9.477s] [ext: omni.isaac.asset_browser-1.0.6] startup
2025-09-28T09:10:50Z [9,465ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[9.480s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[9.483s] [ext: omni.isaac.nucleus-1.0.6] startup
2025-09-28T09:10:50Z [9,471ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-09-28T09:10:50Z [9,471ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[9.486s] [ext: omni.fabric.commands-1.1.6] startup
[9.488s] [ext: omni.kit.manipulator.prim.core-107.0.8] startup
[9.511s] [ext: isaacsim.robot.wheeled_robots-4.0.23] startup
[9.524s] [ext: omni.isaac.utils-2.0.6] startup
[9.528s] [ext: omni.isaac.version-2.0.7] startup
2025-09-28T09:10:50Z [9,514ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[9.531s] [ext: omni.isaac.wheeled_robots-3.0.7] startup
2025-09-28T09:10:50Z [9,518ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,519ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,519ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,520ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,521ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,525ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,526ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,528ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,528ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,531ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,533ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-09-28T09:10:50Z [9,537ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[9.552s] [ext: omni.sensors.nv.common-2.7.0-coreapi] startup
[9.561s] [ext: isaacsim.app.about-2.0.11] startup
[9.563s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[9.566s] [ext: isaacsim.sensors.physics-0.3.27] startup
[9.571s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[9.574s] [ext: omni.sensors.net-0.4.0-coreapi] startup
[9.578s] [ext: omni.sensors.nv.materials-1.6.0-coreapi] startup
[9.582s] [ext: omni.isaac.window.about-2.0.7] startup
2025-09-28T09:10:50Z [9,573ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-09-28T09:10:50Z [9,573ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[9.588s] [ext: omni.kit.manipulator.camera-106.0.4] startup
[9.594s] [ext: isaacsim.robot.policy.examples-4.1.11] startup
[9.594s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[9.594s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[9.597s] [ext: omni.sensors.nv.ids-1.5.0-coreapi] startup
[9.600s] [ext: omni.sensors.nv.wpm-2.5.0-coreapi] startup
[9.601s] [ext: omni.sensors.nv.lidar-2.7.0-coreapi] startup
[9.605s] [ext: omni.isaac.quadruped-3.0.7] startup
2025-09-28T09:10:50Z [9,591ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[9.606s] [ext: omni.isaac.assets_check-0.3.13] startup
2025-09-28T09:10:50Z [9,593ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[9.608s] [ext: isaacsim.gui.content_browser-0.1.9] startup
[9.612s] [ext: isaacsim.util.debug_draw-3.1.0] startup
[9.616s] [ext: omni.sensors.nv.radar-2.8.0-coreapi] startup
[9.619s] [ext: omni.isaac.franka-1.0.7] startup
2025-09-28T09:10:50Z [9,606ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-09-28T09:10:50Z [9,607ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-09-28T09:10:50Z [9,607ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[9.622s] [ext: isaacsim.gui.property-1.1.3] startup
[9.625s] [ext: isaacsim.sensors.physx-2.2.27] startup
[9.628s] [ext: isaacsim.sensors.camera-1.3.1] startup
[9.637s] [ext: isaacsim.sensors.rtx-15.5.0] startup
[9.648s] [ext: isaacsim.core.cloner-1.4.9] startup
[9.652s] [ext: omni.kit.property.isaac-1.0.6] startup
2025-09-28T09:10:51Z [9,639ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-09-28T09:10:51Z [9,640ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[9.654s] [ext: omni.isaac.range_sensor-4.0.6] startup
2025-09-28T09:10:51Z [9,641ms] [Warning] [omni.isaac.range_sensor] omni.isaac.range_sensor has been deprecated in favor of isaacsim.sensors.physx. Please update your code accordingly.
2025-09-28T09:10:51Z [9,644ms] [Warning] [omni.isaac.range_sensor.commands] omni.isaac.range_sensor.commands has been deprecated in favor of isaacsim.sensors.physx.commands. Please update your code accordingly.
[9.661s] [ext: omni.kit.viewport.menubar.camera-107.0.3] startup
[9.673s] [ext: omni.isaac.sensor-13.0.7] startup
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-09-28T09:10:51Z [9,660ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-09-28T09:10:51Z [9,661ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-09-28T09:10:51Z [9,661ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-09-28T09:10:51Z [9,661ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[9.676s] [ext: omni.isaac.cloner-1.0.7] startup
2025-09-28T09:10:51Z [9,663ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[9.678s] [ext: omni.kit.viewport.menubar.render-107.0.9] startup
[9.693s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[9.698s] [ext: isaacsim.replicator.writers-1.0.15] startup
[9.711s] [ext: omni.kit.window.console-1.1.4] startup
[9.714s] [ext: omni.kit.window.status_bar-0.1.8] startup
[9.718s] [ext: omni.kit.viewport.actions-107.0.2] startup
[9.723s] [ext: isaacsim.replicator.domain_randomization-1.0.16] startup
[9.725s] [ext: isaacsim.replicator.examples-1.1.31] startup
[9.727s] [ext: omni.ocio-0.1.1] startup
[9.729s] [ext: omni.rtx.window.settings-0.6.19] startup
[9.735s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[9.739s] [ext: omni.kit.window.toolbar-2.0.0] startup
[9.744s] [ext: omni.replicator.isaac-2.0.8] startup
2025-09-28T09:10:51Z [9,731ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[9.746s] [ext: omni.replicator.replicator_yaml-2.0.11] startup
[9.757s] [ext: omni.rtx.settings.core-0.6.5] startup
[9.766s] [ext: omni.usd.metrics.assembler.ui-107.3.1] startup
[9.787s] [ext: omni.isaac.surface_gripper-2.0.6] startup
2025-09-28T09:10:51Z [9,775ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[9.790s] [ext: semantics.schema.editor-2.0.1] startup
[9.798s] [ext: omni.kit.ui.actions-1.0.5] startup
[9.800s] [ext: semantics.schema.property-2.0.1] startup
[9.802s] [ext: omni.isaac.universal_robots-1.0.6] startup
2025-09-28T09:10:51Z [9,790ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-09-28T09:10:51Z [9,790ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-09-28T09:10:51Z [9,790ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[9.804s] [ext: omni.isaac.core-4.0.7] startup
2025-09-28T09:10:51Z [9,792ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-09-28T09:10:51Z [9,792ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-09-28T09:10:51Z [9,793ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-09-28T09:10:51Z [9,793ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[9.807s] [ext: isaacsim.gui.sensors.icon-2.0.3] startup
[9.812s] [ext: isaacsim.core.experimental.materials-0.3.0] startup
[9.816s] [ext: omni.kit.menu.common-2.0.0] startup
[9.819s] [ext: isaacsim.exp.base-5.0.0] startup
[9.820s] [ext: isaacsim.exp.base.python-5.0.0] startup
[9.821s] Simulation App Starting
2025-09-28T09:10:51Z [9,954ms] [Warning] [usdrt.population.plugin] using high frequency span is disabled
2025-09-28T09:10:51Z [9,976ms] [Warning] [omni.fabric.plugin] Warning: attribute viewportHandle not found for bucket id 9
2025-09-28T09:10:51Z [9,998ms] [Warning] [omni.kit.window.filepicker.collections.collection_item] Failed to add ‘/root/Documents’: ‘/root/Documents/’ as dupliated path in ‘Documents’
[10.064s] app ready
2025-09-28T09:10:51Z [10,060ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [carb::dictionary::ISerializer v1.1] (plugin: carb.dictionary.serializer-json.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
2025-09-28T09:10:53Z [11,681ms] [Warning] [usdrt.hydra.fabric_scene_delegate.plugin] using high frequency span is disabled
2025-09-28T09:10:53Z [11,682ms] [Warning] [usdrt.hydra.fabric_scene_delegate.plugin] using high frequency span with attrs is disabled
2025-09-28T09:10:53Z [11,713ms] [Warning] [usdrt.hydra.fabric_scene_delegate.plugin] using high frequency span is disabled
[12.199s] Simulation App Startup Complete
2025-09-28T09:10:58Z [17,276ms] [Warning] [usdrt.hydra.fabric_scene_delegate.plugin] using high frequency span with attrs is disabled
[SDG] Writing data to: /isaac-sim/_out_obj_based_sdg_pose_writer
2025-09-28T09:11:09Z [28,256ms] [Warning] [omni.fabric.plugin] Warning: attribute outputs_bundle not found for path /Replicator/SDGPipeline/OnCustomEvent
2025-09-28T09:11:10Z [29,011ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2025-09-28T09:11:13Z [32,103ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
2025-09-28T09:11:13Z [32,105ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
2025-09-28T09:11:13Z [32,107ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
Randomizing camera poses
Applying velocity towards the origin
Randomizing lights
Randomizing shape distractors colors
Randomizing dome background
Randomizing shape distractors velocities
[SDG] Capturing frame 0/10, at simulation time: 0.08
[SDG] Changing physics FPS from 60 to 320.0
2025-09-28T09:11:13Z [32,387ms] [Warning] [rtx.raytracing.plugin] Samples per pixel clamped to 64! Set /rtx/pathtracing/clampSpp to override clamp value, or 0 to disable clamping.
2025-09-28T09:11:14Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-09-28T09:11:14Z [35ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui’ exited with code 2
2025-09-28T09:11:14Z [38ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/a7f36df4-9216-4bad-8d32d98b-4133d1f5.dmp’
2025-09-28T09:11:14Z [39ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘/isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/a7f36df4-9216-4bad-8d32d98b-4133d1f5.dmp’
2025-09-28T09:11:14Z [40ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 4115840 bytes, file is readable.
2025-09-28T09:11:14Z [41ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 490 thread 516
2025-09-28T09:11:14Z [41ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-09-28T09:11:14Z [42ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] BuildGitlabJobID = ‘182268558’
2025-09-28T09:11:14Z [42ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-09-28T09:11:14Z [43ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Sun Sep 28 09:11:14 2025 GMT’
2025-09-28T09:11:14Z [45ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2025-09-28T09:11:14Z [46ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘a7f36df4-9216-4bad-8d32d98b-4133d1f5’
2025-09-28T09:11:14Z [47ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] LastUploadStatus = ‘0’
2025-09-28T09:11:14Z [47ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2025-09-28T09:11:14Z [48ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/a7f36df4-9216-4bad-8d32d98b-4133d1f5.py.txt’’
2025-09-28T09:11:14Z [48ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2025-09-28T09:11:14Z [49ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1759050641’
2025-09-28T09:11:14Z [49ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2025-09-28T09:11:14Z [50ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘33’
2025-09-28T09:11:14Z [50ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2025-09-28T09:11:14Z [51ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 2’
2025-09-28T09:11:14Z [52ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘107.3.1+production.206797.8131b85d.gl’
2025-09-28T09:11:14Z [52ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2025-09-28T09:11:14Z [53ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2025-09-28T09:11:14Z [53ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2025-09-28T09:11:14Z [54ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2024.1’
2025-09-28T09:11:14Z [54ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim Python’
2025-09-28T09:11:14Z [55ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘started’
2025-09-28T09:11:14Z [55ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘5.0.0’
2025-09-28T09:11:14Z [56ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2025-09-28T09:11:14Z [57ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘production’
2025-09-28T09:11:14Z [57ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘gl’
2025-09-28T09:11:14Z [58ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildConfig = ‘release’
2025-09-28T09:11:14Z [59ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobName = ‘kit-build-release-linux-x86_64’
2025-09-28T09:11:14Z [59ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobStage = ‘kit-build’
2025-09-28T09:11:14Z [60ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabPipelineID = ‘30713850’
2025-09-28T09:11:14Z [60ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘8131b85d’
2025-09-28T09:11:14Z [61ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘107’
2025-09-28T09:11:14Z [62ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘3’
2025-09-28T09:11:14Z [62ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘206797’
2025-09-28T09:11:14Z [63ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘1’
2025-09-28T09:11:14Z [64ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘107.3.1’
2025-09-28T09:11:14Z [64ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteFrameworkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-09-28T09:11:14Z [65ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-09-28T09:11:14Z [66ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘/isaac-sim/kit/python/bin/python3 ./standalone_examples/replicator/object_based_sdg/object_based_sdg.py --kit_args --/rtx/pathtracing/adaptiveSampling/enabled=True’
2025-09-28T09:11:14Z [66ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuCoreLimited = ‘32’
2025-09-28T09:11:14Z [67ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 6 Model 183 Stepping 1’
2025-09-28T09:11:14Z [67ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuLogicalCoresBareMetal = ‘48’
2025-09-28T09:11:14Z [68ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘Intel(R) Core™ i9-14900KF’
2025-09-28T09:11:14Z [68ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuPhysicalCoresBareMetal = ‘24’
2025-09-28T09:11:14Z [69ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuUsageQuota = ‘-1.000000’
2025-09-28T09:11:14Z [69ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘GenuineIntel’
2025-09-28T09:11:14Z [70ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2025-09-28T09:11:14Z [70ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘7680x2160’
2025-09-28T09:11:14Z [71ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘2’
2025-09-28T09:11:14Z [72ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_0 = ‘3840x2160x32bit@60Hz’
2025-09-28T09:11:14Z [72ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_1 = ‘1920x1080x32bit@60Hz’
2025-09-28T09:11:14Z [73ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2025-09-28T09:11:14Z [73ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2025-09-28T09:11:14Z [74ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘570.172’
2025-09-28T09:11:14Z [74ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘570.172’
2025-09-28T09:11:14Z [75ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘17429430272’
2025-09-28T09:11:14Z [76ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘17429430272’
2025-09-28T09:11:14Z [77ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA GeForce RTX 4080 SUPER’
2025-09-28T09:11:14Z [77ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘NVIDIA GeForce RTX 4080 SUPER’
2025-09-28T09:11:14Z [78ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘570.172’
2025-09-28T09:11:14Z [78ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘CreateNodeCommand(graph=?,node_path=/Orchestrator/OgnReadFabricTime,node_type=omni.replicator.core.ReadFabricTime,create_usd=True)’
2025-09-28T09:11:14Z [79ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnGroup_04,node_type=omni.replicator.core.OgnGroup,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnArray,node_type=omni.replicator.core.OgnArray,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnSampleChoice,node_type=omni.replicator.core.OgnSampleChoice,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/WritePrimAttribute_inputs_texture_file,node_type=omni.replicator.core.OgnWritePrimAttribute,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnCount_07,node_type=omni.replicator.core.OgnCount,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnSampleRotation,node_type=omni.replicator.core.OgnSampleRotation,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/SyncGate_04,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),Group,CreateGraphAsNodeCommand(graph_path=/Orchestrator,node_name=Orchestrator,evaluator_name=push,is_global_graph=True,backed_by_usd=True,fc_backing_type=?,pipeline_stage=?,evaluation_mode=?,graph=?),CreateNodeCommand(graph=?,node_path=/Orchestrator/OgnReadFabricTime,node_type=omni.replicator.core.ReadFabricTime,create_usd=True)’
2025-09-28T09:11:14Z [79ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildBranch = ‘HEAD’
2025-09-28T09:11:14Z [80ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildDate = ‘Thu Jul 31 02:50:55 2025 +0000’
2025-09-28T09:11:14Z [81ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildHash = ‘184afb1’
2025-09-28T09:11:14Z [81ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildRepo = ‘https://gitlab-ci-token:glcbt-64_VDfMLKcrxVTx6vasJknB@gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim.git’
2025-09-28T09:11:14Z [82ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildVersion = ‘5.0.0-rc.45’
2025-09-28T09:11:14Z [82ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildBranch = ‘HEAD’
2025-09-28T09:11:14Z [83ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildDate = ‘Jul-23-2025’
2025-09-28T09:11:14Z [83ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildHash = ‘214216c’
2025-09-28T09:11:14Z [84ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildRepo = ‘gitlab-master.nvidia.com/omniverse/physics’
2025-09-28T09:11:14Z [85ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildVersion = ‘107.3.18’
2025-09-28T09:11:14Z [85ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 38.4914/62.5794GB, Swap: 1.14697/2GB, VM: 1.71799e+10/1.71799e+10GB’
2025-09-28T09:11:14Z [86ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Sun Sep 28 17:10:41 2025
Driver Version : 570.172.08
CUDA Version : 12.8
Attached GPUs : 2
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 4080 SUPER
Product Brand : GeForce
Product Architecture : Ada Lovelace
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-20a81fcf-780c-1382-cfab-66b490ca77dc
Minor Number : 0
VBIOS Version : 95.03.44.40.8A
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 2702-400-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
GPU Fabric GUID : N/A
Inforom Version
Image Version : G002.0000.00.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : Requested functionality has been deprecated
Drain and Reset Recommended : Requested functionality has been deprecated
GPU Recovery Action : None
GSP Firmware Version : 570.172.08
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x270210DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x10DE1771
GPU Link Info
PCIe Generation
Max : 4
Current : 4
Device Current : 4
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 3651400 KB/s
Rx Throughput : 30550 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Performance State : P0
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 16376 MiB
Reserved : 425 MiB
Used : 2194 MiB
Free : 13759 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 40 MiB
Free : 216 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
GPU : 17 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 48 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 101 C
GPU Slowdown Temp : 96 C
GPU Max Operating Temp : 90 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Average Power Draw : 29.80 W
Instantaneous Power Draw : 43.06 W
Current Power Limit : 320.00 W
Requested Power Limit : 320.00 W
Default Power Limit : 320.00 W
Min Power Limit : 150.00 W
Max Power Limit : 320.00 W
GPU Memory Power Readings
Average Power Draw : N/A
Instantaneous Power Draw : N/A
Module Power Readings
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
Clocks
Graphics : 1650 MHz
SM : 1650 MHz
Memory : 11501 MHz
Video : 1440 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3105 MHz
SM : 3105 MHz
Memory : 11501 MHz
Video : 2415 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2765
Type : G
Name :
Used GPU Memory : 1399 MiB
Process ID : 2924
Type : G
Name :
Used GPU Memory : 50 MiB
Process ID : 3159
Type : G
Name :
Used GPU Memory : 13 MiB
Process ID : 3518
Type : G
Name :
Used GPU Memory : 4 MiB
Process ID : 3605
Type : G
Name :
Used GPU Memory : 21 MiB
Process ID : 6644
Type : G
Name :
Used GPU Memory : 199 MiB
Process ID : 81670
Type : G
Name :
Used GPU Memory : 105 MiB
Process ID : 1096063
Type : G
Name :
Used GPU Memory : 263 MiB
Capabilities
EGM : disabled
GPU 00000000:05:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-6682bb6d-98a9-c7b8-e33a-78b71bdd584e
Minor Number : 1
MultiGPU Board : No
Board ID : 0x500
Platform Info
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
Inforom Version
OEM Object : 2.0
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Reset Status
IBMNPU
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
Sub Classcode : 0x0
Bus Id : 00000000:05:00.0
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 4x
Bridge Chip
Type : N/A
Firmware : N/A
Tx Throughput : 3850 KB/s
Rx Throughput : 1600 KB/s
Fan Speed : 0 %
Performance State : P8
Idle : Active
FB Memory Usage
Total : 16376 MiB
Reserved : 422 MiB
Used : 95 MiB
Free : 15860 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 12 MiB
Free : 244 MiB
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Utilization
GPU : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Current : N/A
Pending : N/A
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Aggregate
SRAM L2 : N/A
SRAM SM : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Remapped Rows : N/A
Temperature
GPU Current Temp : 45 C
GPU Power Readings
Average Power Draw : 11.42 W
Instantaneous Power Draw : 11.42 W
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 1185 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3105 MHz
SM : 3105 MHz
Memory : 11501 MHz
Video : 2415 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Processes
Process ID : 2765
Type : G
Name :
Used GPU Memory : 67 MiB
Capabilities
EGM : disabled
2025-09-28T09:11:14Z [87ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2025-09-28T09:11:14Z [88ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.5 LTS (Jammy Jellyfish)’
2025-09-28T09:11:14Z [88ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.5’
2025-09-28T09:11:14Z [89ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘1’
2025-09-28T09:11:14Z [89ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘1920x1080x32bit@60Hz’
2025-09-28T09:11:14Z [90ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2025-09-28T09:11:14Z [90ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘1’
2025-09-28T09:11:14Z [91ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2025-09-28T09:11:14Z [91ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2025-09-28T09:11:14Z [92ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2025-09-28T09:11:14Z [93ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2025-09-28T09:11:14Z [93ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2025-09-28T09:11:14Z [94ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 2702 | 20a81fcf.. |
| | | | | | 1 | |
| | | | | | 2702 | 6682bb6d.. |
| | | | | | 5 | |
| 2025-09-28T09:11:14Z [94ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘4600195561051343481’ |
| 2025-09-28T09:11:14Z [95ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’ |
| 2025-09-28T09:11:14Z [95ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = ‘64081’ |
| 2025-09-28T09:11:14Z [96ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = ‘64081’ |
| 2025-09-28T09:11:14Z [96ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = ‘2047’ |
| 2025-09-28T09:11:14Z [97ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = ‘2047’ |
| 2025-09-28T09:11:14Z [97ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’ |
| 2025-09-28T09:11:14Z [98ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/isaac-sim’ |
| 2025-09-28T09:11:14Z [99ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 516 backtrace follows: |
| 2025-09-28T09:11:14Z [107ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 |
| 2025-09-28T09:11:14Z [115ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator >::_M_default_append(unsigned long)+0x927a |
| 2025-09-28T09:11:14Z [120ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libgpu.foundation.plugin.so!void std::_Destroy_aux::__destroyrtx::rendergraph::ResourceDebug*(rtx::rendergraph::ResourceDebug*, rtx::rendergraph::ResourceDebug*)+0x26d7 |
| 2025-09-28T09:11:14Z [122ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: librtx.raytracing.plugin.so!+0x21994 |
| 2025-09-28T09:11:14Z [124ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: librtx.raytracing.plugin.so!+0x21c3a |
| 2025-09-28T09:11:14Z [126ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: librtx.raytracing.plugin.so!std::__cxx11::basic_string<char, std::char_traits, std::allocator > std::operator+<char, std::char_traits, std::allocator >(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, char const*)+0x1d376 |
| 2025-09-28T09:11:14Z [127ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libcarb.scenerenderer-rtx.plugin.so!+0x6d21c |
| 2025-09-28T09:11:14Z [129ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned int, unsigned int, std::hash, std::equal_to, std::allocator<std::pair<unsigned int const, unsigned int> > >::~unordered_map()+0x4fe34 |
| 2025-09-28T09:11:14Z [131ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned int, unsigned int, std::hash, std::equal_to, std::allocator<std::pair<unsigned int const, unsigned int> > >::~unordered_map()+0x516b3 |
| 2025-09-28T09:11:14Z [133ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned int, unsigned int, std::hash, std::equal_to, std::allocator<std::pair<unsigned int const, unsigned int> > >::~unordered_map()+0x54132 |
| 2025-09-28T09:11:14Z [135ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libcarb.scenerenderer-rtx.plugin.so!std::vector<unsigned long, std::allocator >::~vector()+0x5ed |
| 2025-09-28T09:11:14Z [139ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0x3edd |
| 2025-09-28T09:11:14Z [143ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0xfc53 |
| 2025-09-28T09:11:14Z [147ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::)(carb::tasking::Fiber, carb::tasking::Scheduler::TrackedThread*), carb::tasking::Scheduler*, carb::tasking::Fiber*, carb::tasking::Scheduler::TrackedThread*> > >::_M_run()+0xa3a7 |
| 2025-09-28T09:11:14Z [150ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0xb6bc |
| 2025-09-28T09:11:14Z [152ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libcarb.tasking.plugin.so!void std::vector<int, std::allocator >::_M_realloc_insert<int const&>(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator > >, int const&)+0xb6df |
| 2025-09-28T09:11:14Z [155ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.tasking.plugin.so!make_fcontext+0x39 |
| ./python.sh: line 55: 490 Segmentation fault (core dumped) $python_exe “$@” $args |
| There was an error running python |
root@gps-gps:/isaac-sim# cat ‘/isaac-sim/kit/data/Kit/Isaac-Sim Python/5.0/a7f36df4-9216-4bad-8d32d98b-4133d1f5.py.txt’
Process 490: /isaac-sim/kit/python/bin/python3 ./standalone_examples/replicator/object_based_sdg/object_based_sdg.py --kit_args --/rtx/pathtracing/adaptiveSampling/enabled=True
Python v3.11.13 (/isaac-sim/kit/python/bin/python3.11)
Thread 490 (idle): “MainThread”
_initialize (/isaac-sim/extscache/omni.replicator.core-1.12.16+107.3.1.lx64.r.cp311/omni/replicator/core/scripts/orchestrator.py:646)
step (/isaac-sim/extscache/omni.replicator.core-1.12.16+107.3.1.lx64.r.cp311/omni/replicator/core/scripts/orchestrator.py:1498)
capture_with_motion_blur_and_pathtracing (/isaac-sim/./standalone_examples/replicator/object_based_sdg/object_based_sdg.py:476)
(/isaac-sim/./standalone_examples/replicator/object_based_sdg/object_based_sdg.py:582)
Thread 697 (idle): “ThreadPoolExecutor-0_0”
_worker (/isaac-sim/kit/python/lib/python3.11/concurrent/futures/thread.py:81)
run (/isaac-sim/kit/python/lib/python3.11/threading.py:982)
_bootstrap_inner (/isaac-sim/kit/python/lib/python3.11/threading.py:1045)
_bootstrap (/isaac-sim/kit/python/lib/python3.11/threading.py:1002)
Thread 699 (idle): “ThreadPoolExecutor-0_1”
Thread 798 (idle): “ThreadPoolExecutor-0_2”
Thread 809 (idle): “ThreadPoolExecutor-0_3”
Thread 810 (idle): “ThreadPoolExecutor-0_4”
Thread 898 (idle): “asyncio_0”
