I’m trying to create a deformable object using my URDF/Converted USD file.
The urdf file looks like this:
<?xml version="1.0" encoding="utf-8"?>
<robot name="box_0">
<link name="box_0">
<fem>
<origin rpy="0.0 0.0 0.0" xyz="0 0 0" />
<density value="100" />
<youngs value="1005"/>
<poissons value="0.3"/>
<damping value="0.0" />
<attachDistance value="0.0"/>
<tetmesh filename="../../meshes/box_0.tet"/>
<scale value="1.0"/>
</fem>
</link>
</robot>
I converted this URDF file to USD file using convert_urdf.py script. Then I load this USD file using XFormPrim. By just loading this file to the simulator seems not to work, I can’t see anything inside. Should I assign a material to it? The code I’m using is:
deformable_prim_path = "/World/deformable"
stage.add_reference_to_stage(deformable_usd, deformable_prim_path)
deformable_prim = XFormPrim(
prim_path=deformable_prim_path,
position=torch.tensor(np.array([0.0, 0.5, 0.0])).to(device),
scale=torch.tensor(np.array([0.2, 0.1, 0.02])).to(device),
world.scene.add(deformable_prim)
I know there’s a way to create deformable objects (following the same structure given by the Deformable Body in the Physics/Demo Scenes), but I mainly want to use my own urdfs and meshes.
I also notice that there are DeformablePrim, DeformablePrimView, deformableMeshUtils, DeformableMaterial, DeformableMaterialView in the source code but not in the documentation and I don’t know how to utilize these functions to implement my application.
