When trying to cross-compile Driveworks samples after runing cmake with
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=$HOME/nvidia/nvidia_sdk/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux -DTRT_VERSION:STRING=6.5.0.7 /usr/local/driveworks-4.0/samples/
make fails because libbsd.so.0 is not found:
... warning: libbsd.so.0, needed by /usr/lib/aarch64-linux-gnu/libXdmcp.so.6, not found (try using -rpath or -rpath-link)
/usr/lib/aarch64-linux-gnu/libXdmcp.so.6: undefined reference to `arc4random_buf@LIBBSD_0.2'
Even if libbsd is is nstalled on the host machine
$ dpkg -L libbsd0:arm64
/lib
/lib/aarch64-linux-gnu/libbsd.so.0.8.7
/usr
/usr/share
/usr/share/doc
/usr/share/doc/libbsd0
/usr/share/doc/libbsd0/changelog.Debian.gz
/usr/share/doc/libbsd0/copyright
I was able to circumvent the issue by linking libbsd.so.0 from /drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libbsd.so.0 to /drive-t186ref-linux/lib-target/ thanks to https://forums.developer.nvidia.com/t/building-driveworks-4-0-samples-for-the-target-system/195452, but this seems to be a bug in the SDK.
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
