CUDA Config on Windows 7 w/ION 330
Hello:
I recently purchased an ASRock ION 330 Nettop to be a PS3 media streamer. I installed WIndows 7 and used DriverSweeper to remove all indows 7 NVidia drivers with the latest NVidia driver with CUDA support.
I then installed the toolkit and the SDK, but when I run the 64-bit (I am running Win7-64 bit) I get the following error:
C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\bin\win64\Release>b
andwidthtest
Running on…
device 0:Device Emulation (CPU)
Quick Mode
Host to Device Bandwidth for Pageable memory
cudaSafeCall() Runtime API error in file <d:/devtools/SDK10/CUDA_2.3/SDK10/Compu
te/C/src/bandwidthTest/bandwidthTest.cu>, line 643 : no CUDA-capable device is a
vailable.
I also attempted to run transpose.exe and I recieved this message
cudaSafeCall() Runtime API error in file <transpose.cu>, line 90 : no CUDA-capab
le device is available.
Can anyone help me resolve this issue?
Regards,
Hello there :)
I reactivated this thread, because my error message is exactly the same.
Because of my master thesis, i want to run some code on my
Quadro NVS 135M
it’s listed as CUDA capable, so i installed the CUDA driver and SDK 2.2.
It’s possible for me to compile the sample projects in Visual Studio 2008.
I am running Win7 64-bit on a Dell Latitude D830.
As soon as i try to run the project, above error message is shown to me.
Any ideas?
Thanks in advance…
Hello folks,
problem is solved.
Solution was: Keep your system up to date ;)
Old driver: 185.smth
New driver: 195.62
There’s still a memory problem, but at least, i am able to use the GPU.
Have a nice day…
