CUDA error 801: cudaErrorNotSupported - operation not supported
Isaac Sim Version: 4.0.0
I am getting cuda error when trying to create cameras and correspoding action graph with multi-gpu setup.
Following steps( in isaac-sim container) are followed:
  1. Open Headless webrtc
    $ export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
    $ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/isaac-sim/exts/omni.isaac.ros2_bridge/humble/lib
    $ /isaac-sim/isaac-sim.headless.webrtc.sh --allow-root
  2. Open script editor and paste following script
    import omni
    import time
    import omni.isaac.core.utils.extensions as extensions_utils  # noqa: E402
    import omni.graph.core as og
    from omni.isaac.sensor import Camera
    from omni.isaac.core_nodes.scripts.utils import set_target_prims
    def create_graph(cam_name: str, rgb: bool= False, depth: bool= False):
        graph_path = f"/World/realsense_{cam_name}"
        width = 240
        height = 425
        camera_prims = []
        nodes = []
        nodes_with_values = []
        connection = []
        if depth:
            camera_prims.append(f"/World/{cam_name}_depth")
        if rgb:
            camera_prims.append(f"/World/{cam_name}_rgb")
        for cam in camera_prims:
            camera = Camera(
                prim_path=cam,
                # frequency=20,
                resolution=(width, height),
            camera.initialize()
            nodes_common = [('OnPlaybackTick', 'omni.graph.action.OnPlaybackTick'),
                            ('ROS2Context', 'omni.isaac.ros2_bridge.ROS2Context'),
                            ('IsaacReadSimTime', 'omni.isaac.core_nodes.IsaacReadSimulationTime')
            nodes_depth = [
            (f'render_{cam_name}_depth', 'omni.isaac.core_nodes.IsaacCreateRenderProduct'),
            (f'ros2_{cam_name}_depth', 'omni.isaac.ros2_bridge.ROS2CameraHelper'),
            (f'read_{cam_name}_info_depth', 'omni.isaac.core_nodes.IsaacReadCameraInfo'),
            (f'ros2_{cam_name}_info_depth', 'omni.isaac.ros2_bridge.ROS2PublishCameraInfo')]
            nodes_rgb = [
            (f'render_{cam_name}_rgb', 'omni.isaac.core_nodes.IsaacCreateRenderProduct'),
            (f'ros2_{cam_name}_rgb', 'omni.isaac.ros2_bridge.ROS2CameraHelper'),
            (f'read_{cam_name}_info_rgb', 'omni.isaac.core_nodes.IsaacReadCameraInfo'),
            (f'ros2_{cam_name}_info_rgb', 'omni.isaac.ros2_bridge.ROS2PublishCameraInfo'),
            nodes_with_values_common = [('ROS2Context.inputs:useDomainIDEnvVar', True)]
            nodes_with_values_depth = [
                    (f'render_{cam_name}_depth.inputs:width', height),
                    (f'render_{cam_name}_depth.inputs:height', width),
                    (f'ros2_{cam_name}_depth.inputs:topicName', f'/{cam_name}_depth/depth/image_raw'),
                    (f'ros2_{cam_name}_depth.inputs:frameId', f'{cam_name}_depth_link'),
                    (f'ros2_{cam_name}_depth.inputs:type', 'depth'),
                    (f'ros2_{cam_name}_info_depth.inputs:topicName', f'/{cam_name}_depth/depth/camera_info'),
                    (f'ros2_{cam_name}_info_depth.inputs:frameId', f'{cam_name}_depth_link')
            nodes_with_values_rgb = [
                    (f'render_{cam_name}_rgb.inputs:width', height),
                    (f'render_{cam_name}_rgb.inputs:height', width),
                    (f'ros2_{cam_name}_rgb.inputs:topicName', f'/{cam_name}_rgb/image_raw'),
                    (f'ros2_{cam_name}_rgb.inputs:frameId', f'{cam_name}_rgb_link'),
                    (f'ros2_{cam_name}_rgb.inputs:type', 'rgb'),
                    (f'ros2_{cam_name}_info_rgb.inputs:topicName', f'/{cam_name}_rgb/camera_info'),
                    (f'ros2_{cam_name}_info_rgb.inputs:frameId', f'{cam_name}_rgb_link'),
            connection_with_rgb = [
                        ('OnPlaybackTick.outputs:tick', f'render_{cam_name}_rgb.inputs:execIn'),
                        (f'render_{cam_name}_rgb.outputs:execOut', f'ros2_{cam_name}_rgb.inputs:execIn'),
                        (f'render_{cam_name}_rgb.outputs:renderProductPath', f'ros2_{cam_name}_rgb.inputs:renderProductPath'),
                        ('ROS2Context.outputs:context', f'ros2_{cam_name}_rgb.inputs:context'),
                        (f'render_{cam_name}_rgb.outputs:renderProductPath', f'read_{cam_name}_info_rgb.inputs:renderProductPath'),
                        ('IsaacReadSimTime.outputs:simulationTime', f'ros2_{cam_name}_info_rgb.inputs:timeStamp'),
                        ('OnPlaybackTick.outputs:tick', f'ros2_{cam_name}_info_rgb.inputs:execIn'),
                        ('ROS2Context.outputs:context', f'ros2_{cam_name}_info_rgb.inputs:context'),
                        (f'read_{cam_name}_info_rgb.outputs:focalLength', f'ros2_{cam_name}_info_rgb.inputs:focalLength'),
                        (f'read_{cam_name}_info_rgb.outputs:height', f'ros2_{cam_name}_info_rgb.inputs:height'),
                        (f'read_{cam_name}_info_rgb.outputs:width', f'ros2_{cam_name}_info_rgb.inputs:width'),
                        (f'read_{cam_name}_info_rgb.outputs:horizontalAperture', f'ros2_{cam_name}_info_rgb.inputs:horizontalAperture'),
                        (f'read_{cam_name}_info_rgb.outputs:horizontalOffset', f'ros2_{cam_name}_info_rgb.inputs:horizontalOffset'),
                        (f'read_{cam_name}_info_rgb.outputs:physicalDistortionCoefficients', f'ros2_{cam_name}_info_rgb.inputs:physicalDistortionCoefficients'),
                        (f'read_{cam_name}_info_rgb.outputs:physicalDistortionModel', f'ros2_{cam_name}_info_rgb.inputs:physicalDistortionModel'),
                        (f'read_{cam_name}_info_rgb.outputs:projectionType', f'ros2_{cam_name}_info_rgb.inputs:projectionType'),
                        (f'read_{cam_name}_info_rgb.outputs:verticalAperture', f'ros2_{cam_name}_info_rgb.inputs:verticalAperture'),
                        (f'read_{cam_name}_info_rgb.outputs:verticalOffset', f'ros2_{cam_name}_info_rgb.inputs:verticalOffset'),
            connection_with_depth = [
                        ('OnPlaybackTick.outputs:tick', f'render_{cam_name}_depth.inputs:execIn'),
                        (f'render_{cam_name}_depth.outputs:execOut', f'ros2_{cam_name}_depth.inputs:execIn'),
                        (f'render_{cam_name}_depth.outputs:renderProductPath', f'ros2_{cam_name}_depth.inputs:renderProductPath'),
                        (f'ROS2Context.outputs:context', f'ros2_{cam_name}_depth.inputs:context'),
                        (f'render_{cam_name}_depth.outputs:renderProductPath', f'read_{cam_name}_info_depth.inputs:renderProductPath'),
                        ('IsaacReadSimTime.outputs:simulationTime', f'ros2_{cam_name}_info_depth.inputs:timeStamp'),
                        ('OnPlaybackTick.outputs:tick', f'ros2_{cam_name}_info_depth.inputs:execIn'),
                        ('ROS2Context.outputs:context', f'ros2_{cam_name}_info_depth.inputs:context'),
                        (f'read_{cam_name}_info_depth.outputs:focalLength', f'ros2_{cam_name}_info_depth.inputs:focalLength'),
                        (f'read_{cam_name}_info_depth.outputs:height', f'ros2_{cam_name}_info_depth.inputs:height'),
                        (f'read_{cam_name}_info_depth.outputs:width', f'ros2_{cam_name}_info_depth.inputs:width'),
                        (f'read_{cam_name}_info_depth.outputs:horizontalAperture', f'ros2_{cam_name}_info_depth.inputs:horizontalAperture'),
                        (f'read_{cam_name}_info_depth.outputs:horizontalOffset', f'ros2_{cam_name}_info_depth.inputs:horizontalOffset'),
                        (f'read_{cam_name}_info_depth.outputs:physicalDistortionCoefficients', f'ros2_{cam_name}_info_depth.inputs:physicalDistortionCoefficients'),
                        (f'read_{cam_name}_info_depth.outputs:physicalDistortionModel', f'ros2_{cam_name}_info_depth.inputs:physicalDistortionModel'),
                        (f'read_{cam_name}_info_depth.outputs:projectionType', f'ros2_{cam_name}_info_depth.inputs:projectionType'),
                        (f'read_{cam_name}_info_depth.outputs:verticalAperture', f'ros2_{cam_name}_info_depth.inputs:verticalAperture'),
                        (f'read_{cam_name}_info_depth.outputs:verticalOffset', f'ros2_{cam_name}_info_depth.inputs:verticalOffset')
            nodes = nodes_common
            nodes_with_values = nodes_with_values_common
            if rgb:
                nodes += nodes_rgb
                nodes_with_values += nodes_with_values_rgb
                connection += connection_with_rgb
            if depth:
                nodes += nodes_depth
                nodes_with_values += nodes_with_values_depth
                connection += connection_with_depth
        if len(connection) != 0:
            keys = og.Controller.Keys
            og.Controller.edit(
                    {"graph_path": graph_path, "evaluator_name": "execution"},
                        keys.CREATE_NODES: nodes,
                        keys.SET_VALUES: nodes_with_values,
                        keys.CONNECT: connection,
                set_target_prims(
                    primPath=graph_path + "/" + f"render_{cam.split('/')[-1]}",
                    inputName="inputs:cameraPrim",
                    targetPrimPaths=[cam],
    if __name__ == "__main__":
        is_depth=True
        is_rgb=False
        number_of_cameras=2
        for cam_num in range(number_of_cameras):
            create_graph(cam_name=f"cam{cam_num}", depth=is_depth, rgb=is_rgb)
  3. Start Timeline (Play)
  4. Start the Script (Ctrl-Enter)
Error:
(this happens when atleast 2 cameras are created)
2024-10-04 09:05:36 [265,128ms] [Error] [omni.syntheticdata.plugin] CUDA error 801: cudaErrorNotSupported - operation not supported)
2024-10-04 09:05:36 [265,128ms] [Error] [omni.syntheticdata.plugin] OgnSdUtils::copyTextureToBufferNoStride : cannot access input texture.
2024-10-04 09:05:36 [265,128ms] [Error] [omni.syntheticdata.plugin] CUDA ERROR at ../../../source/extensions/omni.syntheticdata/nodes/OgnSdCopyCuda.cu:197
and when I tried to open the generated graph in GUI, following error is seen on terminal:
[295,574ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2024-10-04 09:06:07 [295,574ms] [Error] [carb.cudainterop.plugin] Failed to allocate CUDA device memory (size: 408000).
2024-10-04 09:06:07 [295,574ms] [Error] [omni.syntheticdata.plugin] SdRenderVarToRawArray cannot allocate working cuda buffer of size (408000)
2024-10-04 09:06:07 [295,597ms] [Error] [carb.livestream-rtc.plugin] nvstPushStreamData error for eye 0, stream 0x7f7af808a9c0: 0x800b0000
2024-10-04 09:06:07 [295,602ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2024-10-04 09:06:07 [295,602ms] [Error] [carb.cudainterop.plugin] Failed to wait on external semaphore in CUDA.
2024-10-04 09:06:07 [295,602ms] [Error] [gpu.foundation.plugin] Wait for external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 0, frame submission index 0)"
2024-10-04 09:06:07 [295,604ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2024-10-04 09:06:07 [295,604ms] [Error] [carb.cudainterop.plugin] Failed to wait on external semaphore in CUDA.
2024-10-04 09:06:07 [295,604ms] [Error] [gpu.foundation.plugin] Wait for external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 1, frame submission index 2)"
 2024-10-04 09:06:37 [325,604ms] [Error] [gpu.foundation.plugin] Submission barrier "CUDA event dependency in MGPU resource" timeout in command list "Render graph command list (Render queue 0, device 0, frame submission index 2)"!
2024-10-04 09:06:37 [325,604ms] [Error] [gpu.foundation.plugin] Wait count: 1, Received signals: 0:
2024-10-04 09:06:37 [325,604ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
 2024-10-04 09:06:37 [325,604ms] [Error] [carb.cudainterop.plugin] Failed to wait on CUDA event          .
Note:
Same script works when isaac sim is launched by adding following flag:
--/renderer/multiGpu/enabled=False
Logs
multigpu disabled:
multigpu_enabled_kit_20241004_093327.log (1.2 MB)
multigpu enabled:
So are there any settings that i need to ensure to run in multi gpu setup ?
Thank you for providing detailed information about the issue you’re experiencing with CUDA errors in Isaac Sim 4.0.0. I’d like to suggest trying the latest version of Isaac Sim, which is 4.2.0.
