Hi, I’m just trying to get up to speed with ROS2 lidar sensors in Isaac sim, and Isaac sim crashes reliably with a simple scene following the Isaac sim ROS2 lidar example: 7.2.5. RTX Lidar Sensors — Omniverse IsaacSim latest documentation
Running the builtin ROS2 in Isaac sim (I’d prefer to be using my built-from-source ROS2 humble - but that’s another thread).
I also have issues where none of the sensors apart from the RTX Rotating lidar will work at all.
OS: Ubuntu 20.04
Isaac sim build: 2023.1.0-hotfix.1
ROS2: Humble
| NVIDIA-SMI 535.129.03 Driver Version: 535.129.03 CUDA Version: 12.2 |
NVIDIA GeForce RTX 4080 80W 12282MiB
Steps to reproduce:
- source the isaac sim internal version of ros2
ROS_DOMAIN_ID=11
export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
export PYTHONPATH=$PYTHONPATH:$HOME/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.ros2_bridge/humble/rclpy/
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.ros2_bridge/humble/rclpy/rclpy
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/.local/share/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.ros2_bridge/humble/lib
- open isaac sim with ROS2 bridge, and launch
./isaac-sim.selector.sh
- Create > isaac > sensors > RTX lidar > Rotating
- Window > visual scripting > action graph
- new action graph
- add on playback tick node
- add isaac create render product
- add ros2 rtx lidar helper
- connect playback tick to render product
- connect render product tick to ros2 lidar helper
- connect render product and ros2 lidar helper render product path
- modify the render product input: select target rotating ldiar
/World/Rotating - modify ros2 lidar helper output
- type: point_cloud
- topic: cloud
- Now I play around, I haven’t found a reproducible set of steps (in any order, I only do the following) and at some point, it’ll crash, usually after less than a minute. But If I don’t touch the sim and just leave it, it appears to be stable. I.e. If I try to do anything, I can pretty well guarantee it’ll crash in a minute or so
- open rviz2 and display the cloud
- play and stop the simulation over and over
- move the lidar
- add object
- save scene
This is the error:
2023-11-08 02:22:46 [380,154ms] [Warning] [omni.syntheticdata.plugin] SdRenderVarPtr missing valid input renderVar RtxSensorCpu
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:37:an illegal memory access was encountered (cudaMemcpyAsync( &bufferParam->async, ¶meter->async, sizeof(LidarAsyncParameter), cudaMemcpyHostToHost, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:47:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, ticks.azimuths, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:50:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, ticks.states, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:53:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, ticks.timestamps, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:57:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.azimuths, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:59:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.elevations, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:61:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.distances, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:63:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.intensities, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:66:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.velocities, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:68:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.hitPointNormals, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:71:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.deltaTimes, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:73:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.emitterIds, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:75:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.beamIds, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:77:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.materialIds, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:79:an illegal memory access was encountered (cudaMemcpyAsync(buffer + offset, returns.objectIds, sizeInBytes, kind, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:137:an illegal memory access was encountered (cudaMemsetAsync(returns.azimuths, 0, sizeof(float) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:138:an illegal memory access was encountered (cudaMemsetAsync(returns.elevations, 0, sizeof(float) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:139:an illegal memory access was encountered (cudaMemsetAsync(returns.distances, 0, sizeof(float) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:140:an illegal memory access was encountered (cudaMemsetAsync(returns.intensities, 0, sizeof(float) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:141:an illegal memory access was encountered (cudaMemsetAsync(returns.velocities, 0, sizeof(float) * numReturns * 3, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:142:an illegal memory access was encountered (cudaMemsetAsync(returns.hitPointNormals, 0, sizeof(float) * numReturns * 3, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:143:an illegal memory access was encountered (cudaMemsetAsync(returns.deltaTimes, 0, sizeof(uint32_t) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:144:an illegal memory access was encountered (cudaMemsetAsync(returns.emitterIds, 0, sizeof(uint32_t) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:145:an illegal memory access was encountered (cudaMemsetAsync(returns.beamIds, 0, sizeof(uint32_t) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:146:an illegal memory access was encountered (cudaMemsetAsync(returns.materialIds, 0, sizeof(uint32_t) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [omni.sensors.nv.lidar.lidar_core.plugin] CUDA error 700 in ../../../source/include/internal/omni/sensors/lidar/LidarReturnHelper.h:147:an illegal memory access was encountered (cudaMemsetAsync(returns.objectIds, 0, sizeof(uint32_t) * numReturns, stream))
2023-11-08 02:22:47 [380,409ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2023-11-08 02:22:47 [380,409ms] [Error] [carb.cudainterop.plugin] Failed to signal external semaphore in CUDA.
2023-11-08 02:22:47 [380,409ms] [Error] [gpu.foundation.plugin] Signal external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 0, frame submission index 2)"
2023-11-08 02:22:47 [380,413ms] [Error] [omni.physx.plugin] PhysX error: PhysX Internal CUDA error. Simulation can not continue! Error code 700!
, FILE /buildAgent/work/74336105e89c4a74/source/physx/src/NpScene.cpp, LINE 2982
2023-11-08 02:22:47 [380,413ms] [Error] [omni.physx.plugin] Cuda context manager error, simulation will be stopped and new cuda context manager will be created.
2023-11-08 02:22:47 [380,413ms] [Error] [omni.physx.plugin] PhysX error: prepareGpuNarrowphase GPU error! code 700
, FILE /buildAgent/work/74336105e89c4a74/source/gpunarrowphase/src/PxgNarrowphaseCore.cpp, LINE 9199
2023-11-08 02:22:47 [380,413ms] [Error] [omni.physx.plugin] PhysX error: GPU kernel 'bpSignalComplete' failed to launch with error 700!!
, FILE /buildAgent/work/74336105e89c4a74/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 472
2023-11-08 02:22:47 [380,513ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuEventRecord failed with error 700
, FILE /buildAgent/work/74336105e89c4a74/source/gpucommon/include/PxgCudaUtils.h, LINE 53
2023-11-08 02:22:47 [380,513ms] [Error] [omni.physx.plugin] Cuda context manager error, simulation will be stopped and new cuda context manager will be created.
2023-11-08 02:22:47 [380,513ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuStreamWaitEvent failed with error 700
, FILE /buildAgent/work/74336105e89c4a74/source/gpucommon/include/PxgCudaUtils.h, LINE 59
2023-11-08 02:22:47 [380,513ms] [Error] [omni.physx.plugin] PhysX error: memcpy failed fail!
700, FILE /buildAgent/work/74336105e89c4a74/source/gpunarrowphase/src/PxgNarrowphaseCore.cpp, LINE 1444
2023-11-08 02:22:47 [380,514ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuEventRecord failed with error 700
2023-11-08 02:22:47 [380,514ms] [Error] [omni.physx.plugin] Cuda context manager error, simulation will be stopped and new cuda context manager will be created.
2023-11-08 02:22:47 [380,514ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuStreamWaitEvent failed with error 700
, FILE /buildAgent/work/74336105e89c4a74/source/gpucommon/include/PxgCudaUtils.h, LINE 75
, FILE /buildAgent/work/74336105e89c4a74/source/gpucommon/include/PxgCudaUtils.h, LINE 81
2023-11-08 02:22:47 [380,514ms] [Error] [omni.physx.plugin] PhysX error: PhysX Internal CUDA error. Simulation can not continue! Error code 700!
, FILE /buildAgent/work/74336105e89c4a74/source/physx/src/NpSceneFetchResults.cpp, LINE 182
2023-11-08 02:22:47 [380,521ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2023-11-08 02:22:47 [380,521ms] [Error] [carb.cudainterop.plugin] Failed to wait on external semaphore in CUDA.
2023-11-08 02:22:47 [380,521ms] [Error] [gpu.foundation.plugin] Wait for external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 0, frame submission index 0)"
