Thank you for reporting this issue. To help us better understand and potentially reproduce the problem, could you please provide the following information:
Isaac Sim Version: Please specify which version of Isaac Sim you’re using. This is crucial as different versions may have different compatibility issues or known bugs.
NVIDIA Driver Information: Run the nvidia-smi command in your terminal or command prompt and share the output.
Steps to Reproduce: Could you provide a detailed, step-by-step description of how to reproduce this issue? Include information such as:
The specific robot model you’re trying to simulate
Any particular settings or configurations you’re using
The exact actions you take before the crash occurs
Log Files: If possible, please provide the full log file, not just the snippet you’ve shared. This can often contain additional useful information.
With this information, we’ll be better equipped to investigate and potentially reproduce the issue on our end. This will help us provide more accurate assistance or, if necessary, escalate the issue to our development team.
Thank you for your response.
The Version i am currently using is isaac-sim-4.2.
Driver version of PC is 535.183.01
kelo@Simulation:~/Simulation/ros_workspace$ nvidia-smi
Wed Oct 9 12:59:34 2024
| NVIDIA-SMI 535.183.01 Driver Version: 535.183.01 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4070 ... Off | 00000000:01:00.0 On | N/A |
| 31% 35C P8 10W / 285W | 818MiB / 16376MiB | 33% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2448 G /usr/lib/xorg/Xorg 118MiB |
| 0 N/A N/A 2548 C+G ...libexec/gnome-remote-desktop-daemon 211MiB |
| 0 N/A N/A 2597 G /usr/bin/gnome-shell 34MiB |
| 0 N/A N/A 3236 G ...ures=SpareRendererForSitePerProcess 45MiB |
| 0 N/A N/A 4234 G /opt/teamviewer/tv_bin/TeamViewer 15MiB |
| 0 N/A N/A 4675 C+G ...hare/ov/pkg/isaac-sim-4.2.0/kit/kit 349MiB |
The model i am trying to simulate is a mecanum wheel conveyer belt which consists of 112 mecanum wheels and each mecanum wheel has six rollers. I load the URDF of the model in isaac sim. I have checked all the joint connections in the rviz before loading into the isaac sim and it was perfect. When i load model and click on play button in the simulation. The app is crashed.
I also provided a log file for you use. kit_20241009_125408.log (2.3 MB)
@chaitanyagumudala961 If this is still an issue, please share a reproducing USD. @omairsiddiquer Could you create another with the “Reply as a linked topic” option for your issue and also provide a repo USD and complete log?
TBB Warning: Exact exception propagation is requested by application but the linked library is built without support for it
2025-04-09 12:30:51 [84,514ms] [Error] [omni.hydra] Exception in HdEngine::Execute: Used 'Xform' prim </World/xxx/knee_p_link> on stage with rootLayer @anon:0x582353e0:World0.usd@, sessionLayer @anon:0x5846f020:World0-session.usda@
2025-04-09 12:30:51 [84,514ms] [Error] [omni.usd] HydraEngine::render failed to end the compute graph: error code 6
Hi @chaitanyagumudala961, thank you for reporting this! We’re happy to let you know that the GPU memory access crash you encountered during robot simulation has been fixed and the fix is included in Isaac Sim 5.1.0. But We recommend upgrading to the latest version (6.0.0 GA) to resolve the issue. If you continue to experience problems after upgrading, please open a new topic and reference this one (The App is Crashing when i try to simulate my Robot). Thanks again!
