I have flashed an SD card with 4.4 on my NX.
Everything seems to be running find and I can SSH into it via my wifi router using a local LAN address. I can also access if via a public IP address from my host PC.
I am attempting to load Jetson SDK Components from a virtual machine (that was used to flash NX) via the local IP address. It connects OK but cuda always fails. Please see attached for the exported logs from SDKM.
SDKM_logs_JetPack_4.4_Linux_for_Jetson_Xavier_NX_2020-12-16_17-50-26.zip (234.1 KB)
Here are the filtered cuda errors
18:21:56 ERROR: CUDA Toolkit for L4T: E: Unable to correct problems, you have held broken packages.
18:21:56 ERROR: CUDA Toolkit for L4T: [error]: dpkg install on target failed; [exec_command]: safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb” 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-10-2 " 5; safe_apt_install “sudo apt-get purge -y cuda-repo-l4t-10-2-local-10.2.89” 5; [deb_path]: /home/ubuntu/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
18:21:56 ERROR: CUDA Toolkit for L4T: command terminated with error
