I am unable to install cupy or pycuda on Jetson Xavier NX. I would like to be able to do cuda based fft in python and numpy convolve. Any suggestions would be much appreciated.
I got pycuda and cupa to install with the following:
- pip3 install --global-option=build_ext --global-option="-I/usr/local/cuda/include" --global-option="-L/usr/local/cuda/lib64" pycuda
- pip3 install cupy
However now whenever I make a cupy array in python 3.6.9 it hangs indefinitely. For example:
a = cp.random.random(100).astype(cp.complex64)
just hangs forever it won’t execute .
Thanks for reporting this.
Confirmed that we can reproduce the same issue in our environment.
We will share more information with you after more investigation.
I think there is something in cupy that is not optimized for transferring data to GPU on the Jetson NX. In a script I finally got it to go thru but it was painfully slow.
The root cause is that cupy source doesn’t include Xavier GPU architecture(sm_72).
So the library needs to re-generate it with the correct architecture at runtime.
We try to install it from the source with sm_72 config and don’t see this issue anymore.
Below are the steps for your reference:
$ git clone -b v9.6.0 --recursive https://github.com/cupy/cupy.git
$ cd cupy/
# appy following changes
$ pip3 install .
Changes:
1. Under {cupy_root}/cupy/_core/include/cupy/cub/tune
diff --git a/common.mk b/common.mk
index 82893ab9..e3bc8027 100644
--- a/common.mk
+++ b/common.mk
@@ -40,6 +40,11 @@ else
SM_ARCH = 200
endif
+ifeq (720, $(findstring 720, $(SM_ARCH)))
+ SM_TARGETS += -gencode=arch=compute_72,code=\"sm_72,compute_72\"
+ SM_DEF += -DSM720
+ TEST_ARCH = 720
+endif
ifeq (700, $(findstring 700, $(SM_ARCH)))
SM_TARGETS += -gencode=arch=compute_70,code=\"sm_70,compute_70\"
SM_DEF += -DSM700
diff --git a/tune/Makefile b/tune/Makefile
index 926b340f..524139cd 100644
--- a/tune/Makefile
+++ b/tune/Makefile
@@ -70,6 +70,10 @@ else
endif
# Only one arch per tuning binary
+ SM_TARGETS = -arch=sm_72
+ SM_ARCH = 720
+endif
ifeq (350, $(findstring 350, $(SM_ARCH)))
SM_TARGETS = -arch=sm_35
SM_ARCH = 350
2. Under{cupy_root}/
diff --git a/cupy_setup_build.py b/cupy_setup_build.py
index b363c1026..660a61df2 100644
--- a/cupy_setup_build.py
+++ b/cupy_setup_build.py
@@ -1038,8 +1038,9 @@ def _nvcc_gencode_options(cuda_version):
('compute_60', 'sm_60'),
('compute_61', 'sm_61'),
('compute_70', 'sm_70'),
+ ('compute_72', 'sm_72'),
('compute_75', 'sm_75'),
- 'compute_70']
+ 'compute_72']
elif cuda_version >= 9020:
arch_list = ['compute_30',
'compute_50',
Awesome. Thank you. I will give this a try.
Do I need to uninstall the previous version? I installed with pip3 install cupy. Can I uninstall with pip3 uninstall cupy?
Yes. please uninstall it with pip3 first.
