Current comsuption for Jetson AGX Orion Industrial
Please let me know the max current taken by 5V for JAOi ( Jetson AGX Orin Industrial).
And please confirm if i am using 12V for HV rail then my IDDMAX will be 20*5.4/12=9A
Antonio Carlos
If you are designing a custom base board, then it means some adaptation configurations are needed.
Otherwise, your board may not work fine.
For Orin AGX series, you could refer to below document
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=universal%20serial%20bus#jetson-agx-orin-platform-adaptation-and-bring-up
(please be aware that above link is for rel-36.3/jetpack6.0)
This document includes below configuration
  1. pinmux change & GPIO configuration
  2. EEPROM change as most custom boards do not have an EEPROM on it.
  3. Kernel porting
  4. PCIe configuration
  5. USB configuration
  6. MGBE configuration
  7. RGMII configuration
As you had seen in data sheet, IDDmax of 5V MV is 6A, and 5.4A for 20V HV. So it is 9A for 12V HV.
