I created a custom 3D LiDAR using Create -> Isaac -> Sensor -> PhysXLidar -> Rotating
in Isaac Sim. I want to set an asymmetric vertical FOV (e.g., -10° to +30°), but it seems to only allow symmetric FOV (like -30° to +30°).
Is there a way to configure separate min and max vertical angles for the rotating PhysX LiDAR?
Hi @shailesh.pawar. Yes you are right. According to the API documentation for RangeSensorCreateLidar, it only takes in one value for vertical_fov
. So you will not be able to set asymmetric vertical FOV. Is there a reason that you want to do asymmetric vertical FOV?
Hi @zhengwang ,
Thanks for the clarification earlier. I understand the current limitation with symmetric vertical FOV in PhysX Rotating LiDAR
. However, I’d like to point out that there are multiple 3D LiDARs available—such as the Vanjee 722WLR—that have asymmetric vertical FOVs (e.g., from +50° to -12°). Is there any recommended approach in Isaac Sim to simulate such configurations?
Additionally, I would like to expose the PhysX LiDAR data over ROS 2. Could you please share any references or examples for this?
Also, I’d like to know how to simulate a custom 3D LiDAR with asymmetric vertical FOV using RTX LiDAR, and how to expose that data over ROS 2 as well.
Appreciate your help!
Thanks! Have you checked out this tutorial PhysX SDK Generic Sensor — Isaac Sim Documentation? This should allow you customize lidar pattern.
Hello!
Best regards,
