Hi all!
In order to simulate our sensor, the Scanning Laser Range Finder, we need to establish multiple patterns of ranges on a sensor using x and y coordinates (as shown in the diagram with different colors), we use this pattern to detect if any object is inside this area.According to the current Ridar documentation we found, the range size can be changed by horizontal FOV 、vertical FOV and range. Other APIs are for reading data. We are not sure if the direction we are looking for is correct or if you can provide any instructional materials
my sensor area detection pattern:
other customized patterns example:
this is the Ridar documentation I found
Range Based Sensor Simulation [omni.isaac.range_sensor] — isaac_sim 4.2.0-rc.17 documentation (nvidia.com)
