Hi, is there any way to debug the friction parameters? I suspect something is fishy with the friction simulation. It seems like on larger objects it corresponds more to reality than on small objects. Would this be possible? How are the forces computed? However the small objects are not too much smaller in this case, the difference is 60 cm vs 30 cm length.
Are there any parameters of the physics engine to which I should pay attention in order to get as realistic contact friction behavior as possible? Thanks.
