Default Display is not loading - have to enable via host everytime
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Based on the instructions given in the sample Camera Setup and Configuration | NVIDIA Docs I had done below steps:
1. systemctl disable gdm
2. systemctl stop gdm
But after doing these steps, everytime when i boot the Drive Orin, it is not taking display by default, I have to do the below steps in order to turn on the display.
  1. systemctl enable gdm
  2. systemctl start gdm
So, need a permanent solution for this issue so that i can have the display on by default.
Dear @arpit.agarkar,
How about adding the commands in a start up script
Can you please guide me with steps
@SivaRamaKrishnaNV any update on this?
It should be like a start up job in Linux. You may check in Linux forums
Need help here, I tried to do the same, but its not working
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
I reflashed the Orin :-)
