Default joint configuration for manipulator
In the images I have a UR10e and a Franka manipulator. Where is the starting configuration for the joints defined so that Franka shows vertical while UR starts horizontal. The second image is after starting the simulation and in this case Franka achieves a different config. where are these settings defined?
The joints are defined within block with rpy values.
