Hello all,
When I spawn a robot.usd into Isaac Lab and give it the initial joint positions, it fights with the default positions set in robot.usd.
Can I set Isaac Lab’s simulation settings to take precedence?
Hello all,
| Setting joint positions while sim is not running or paused | 5 | 3703 | December 4, 2023 | |
| Specific Joint Not Moving in Isaac Lab While Working in Isaac Sim with the Same USD File | 4 | 179 | July 29, 2025 | |
| Set initial position of robot / articulation before simulation starts in Python | 2 | 1122 | March 26, 2024 | |
| Changed Robot orientation while spawning from USD in Isaac Sim | 5 | 607 | November 9, 2023 | |
| Joint match problems in scripts | 10 | 260 | November 14, 2025 | |
| Is there a way to freely define joint axes in Isaac Sim? | 2 | 135 | June 24, 2025 | |
| Interacting with Original Articulation at Isaac Lab | 2 | 405 | July 5, 2024 | |
| Apply joint position for Fetch robot | 3 | 1136 | September 28, 2023 | |
| JointState jitter/bouncing when pressing Play in Isaac Sim (ROS integration) | 3 | 32 | December 23, 2025 | |
| Maintain joint positions when simulation is started | 3 | 1314 | March 28, 2023 |
