JointState jitter/bouncing when pressing Play in Isaac Sim (ROS integration)
Hi everyone. I’m working on a project using Isaac Sim and ROS. I have linked the JointStates to the Isaac joints using an OmniGraph. Everything works fine so far, except when I press Play: the robotic arms behave erratically for a second. I’m attaching a video of the issue. I would like to know if there is a way to eliminate those bounces/jitter at the start
Thanks in advance .
Hey, I had the same issue, solved by putting both Joint state and Target position (params for joints) to the same value. I guess what’s happening is robot initially start from Joint state and that’s when jitter happens. Additionally, I had to align it with link transforms but guess that’s not your case.
Thanks, in the end I found the error, the joints had initial position and velocity values that were not set to 0, and that’s what caused that weird behavior.
