I recognized that the behavior changes if I load the UR10 model which comes directly with Isaac Sim.
So, I think the .usd file which I use to load my UR5e isn’t the problem.
So this precises my question further:
How do I need to design the robot_descriptor.yaml and ur5e_rmpflow_common.yaml files to improve the behavior of the UR5e.
I didn’t create these files myself because I had no clue what each entry means and couldn’t find a documentation about it.
Currently they look as follows:
robot_descriptor.yaml:
api_version: 1.0
# Defines the generalized coordinates. Each generalized coordinate is assumed
# to have an entry in the URDF, except when otherwise specified below under
# cspace_urdf_bridge.
cspace:
- shoulder_pan_joint
- shoulder_lift_joint
- elbow_joint
- wrist_1_joint
- wrist_2_joint
- wrist_3_joint
root_link: world
subtree_root_link: base_link
default_q: [-1.57, -1.57, -1.57, -1.57, 1.57, 0]
# Most dimensions of the cspace have a direct corresponding element
# in the URDF. This list of rules defines how unspecified coordinates
# should be extracted.
cspace_to_urdf_rules:
# Example:
# - {name: robot_finger_joint1, rule: fixed, value: 0.025}
composite_task_spaces: []
collision_spheres:
- upper_arm_link:
- center: [0.0, -0.045, 0.01]
radius: 0.1
- center: [0.0, -0.045, 0.06]
radius: 0.09
- center: [0.0, -0.045, 0.12]
radius: 0.06
- center: [0.0, -0.045, 0.18]
radius: 0.06
- center: [0.0, -0.045, 0.24]
radius: 0.06
- center: [0.0, -0.045, 0.3]
radius: 0.06
- center: [0.0, -0.045, 0.36]
radius: 0.06
- center: [0.0, -0.045, 0.42]
radius: 0.06
- center: [0.0, -0.045, 0.48]
radius: 0.06
- center: [0.0, -0.045, 0.54]
radius: 0.06
- center: [0.0, -0.045, 0.6]
radius: 0.08
- forearm_link:
- center: [0.0, 0.0, 0.0]
radius: 0.08
- center: [0.0, 0.0, 0.06]
radius: 0.07
- center: [0.0, 0.0, 0.12]
radius: 0.05
- center: [0.0, 0.0, 0.18]
radius: 0.05
- center: [0.0, 0.0, 0.24]
radius: 0.05
- center: [0.0, 0.0, 0.30]
radius: 0.05
- center: [0.0, 0.0, 0.36]
radius: 0.05
- center: [0.0, 0.0, 0.42]
radius: 0.05
- center: [0.0, 0.0, 0.48]
radius: 0.05
- center: [0.0, 0.0, 0.54]
radius: 0.05
- center: [0.0, 0.0, 0.57]
radius: 0.065
- wrist_1_link:
radius: 0.05
- center: [0.0, 0.055, 0.0]
radius: 0.05
- center: [0.0, 0.11, 0.0]
radius: 0.065
- wrist_2_link:
radius: 0.05
- center: [0.0, 0.0, 0.055]
radius: 0.05
- center: [0.0, 0, 0.11]
radius: 0.065
- wrist_3_link:
radius: 0.045
- center: [0.0, 0.05, 0.0]
radius: 0.05
ur5e_rmpflow_common.yaml:
api_version: 1.0
joint_limit_buffers: [.01, .01, .01, .01, .01, .01]
rmp_params:
cspace_target_rmp:
metric_scalar: 50.
position_gain: 100.
damping_gain: 50.
robust_position_term_thresh: .5
inertia: 1.
cspace_trajectory_rmp:
p_gain: 80.
d_gain: 10.
ff_gain: .25
weight: 50.
cspace_affine_rmp:
final_handover_time_std_dev: .25
weight: 2000.
joint_limit_rmp:
metric_scalar: 1000.
metric_length_scale: .01
metric_exploder_eps: 1e-3
metric_velocity_gate_length_scale: .01
accel_damper_gain: 200.
accel_potential_gain: 1.
accel_potential_exploder_length_scale: .1
accel_potential_exploder_eps: 1e-2
joint_velocity_cap_rmp:
max_velocity: 2.15
velocity_damping_region: 0.5
damping_gain: 300.
metric_weight: 100.
target_rmp:
accel_p_gain: 80.
accel_d_gain: 120.
accel_norm_eps: .075
metric_alpha_length_scale: .05
min_metric_alpha: .01
max_metric_scalar: 10000.
min_metric_scalar: 2500.
proximity_metric_boost_scalar: 20.
proximity_metric_boost_length_scale: .02
accept_user_weights: false
axis_target_rmp:
accel_p_gain: 200.
accel_d_gain: 40.
metric_scalar: 10.
proximity_metric_boost_scalar: 3000.
proximity_metric_boost_length_scale: .05
collision_rmp:
damping_gain: 50.
damping_std_dev: .04
damping_robustness_eps: 1e-2
damping_velocity_gate_length_scale: .01
repulsion_gain: 1200.
repulsion_std_dev: .01
metric_modulation_radius: .5
metric_exploder_std_dev: .02
metric_exploder_eps: .001
damping_rmp:
accel_d_gain: 30.
metric_scalar: 50.
inertia: 100.
canonical_resolve:
max_acceleration_norm: 50.
projection_tolerance: .01
verbose: false
body_cylinders:
- name: base_link
pt1: [0, 0, 0.22]
pt2: [0, 0, 0]
radius: .09
body_collision_controllers:
- name: wrist_2_link
radius: .04
- name: wrist_3_link
radius: .04
- name: tool0
radius: .04
