Default Username/Password for UFM Docker Container
I’ve recently installed a UFM docker container in my lab environment from mellanox/ufm-enterprise on docker hub. The installation went well but I’m unable to log into the web interface using admin/admin as the username and password. Should I be using different credentials?
In case someone reads this down the road, I ended up resolving the issue by accessing the Docker package via console and removing the admin user from /opt/ufm/conf/ufm.passwd and replacing it with the password I wanted using htpasswd.
Hi Jakef,
Thanks for writing us.
The default user/password for the deployment you’ve installed is admin/123456
https://docs.nvidia.com/networking/display/ufmenterpriseumv6190/running+ufm+server+software#src-3315017530_RunningUFMServerSoftware-UserAuthentication
After logging in you should be able to change the permissions or add users to the .
Ilan Pavis,
NVIDIA Support
