After updating the drivers as prompted in the command-line interface, I got this screen when I boot up every time: https://youtu.be/_vEGhCDQ_rE The desktop is missing the top menu bar and I am also unable to drag a window around. Do I need to flash Jetson to fix it or is there some other way? Sorry for the shaky hand in the video. Thank you!
I saw a bug listed for this for other Ubuntu systems (not just Jetsons). Some of the workarounds don’t exist in this version, but this may do what you need:
dconf reset -f /org/compiz/
setsid unity
…I don’t know if you need to be logged in as that user, or if sudo is required. I suggest trying first with that user, and then with sudo if it refuses.
When I do “dconf reset -f /org/compiz/”, I get an error message saying “error: Cannot launch D-Bus without X11 $DISPLAY”. When I do “setsid unity” after it, I get a “WARNING: no DISPLAY variable set, setting it to :0”.
I’m not using Jetpack yet. I’m still working only on the Jetson.
When you say things are failing it isn’t clear if you are reporting the same failure of the toolbar or just the GUI as a whole. This thread is about the toolbar, so that’s mostly how I’m approaching this.
If the problems show up with users other than “nvidia” or “ubuntu” you’ll want to be sure that user is in group “video”:
grep video /etc/group
Normal upgrade (not upgrade of release, just packages) should be done normally. If “sha1sum -c /etc/nv_tegra” fails after that, then you can unpack the driver package “nv_tegra/nvidia_drivers.tbz2” (the driver package is downloaded by JetPack, or you can just download the driver package from the web site) into “/” of the Jetson (make sure to use sudo).
If the file which is bad after an update is “/usr/lib/xorg/modules/extensions/libglx.so”, then just copy the good one at “/usr/lib/aarch64-linux-gnu/tegra/libglx.so” over the bad one.
This should probably be in the TX2 forum, but mostly it is the same as a TX1. What release are you using (see “head -n 1 /etc/nv_tegra_release”)? Did you try all of the suggestions in this particular thread for compiz?
