Hi
How to get the length of “Differential pair length matching” from PCIE layout guide? What’s the +/- tolerance mils?
Plus, what’s “Differential pair uncoupled length?”
Thank you,
Hi
Thank you,
You can get the length by converting from time as the words you marked in yellow. No +/- tolerance for it. You should write the value into the EDA tool as constraint rule.
Hi Trumany,
Thank you for your prompt support.
