I noticed for a lot of people this was solved a few releases ago, however on my 980Ti with 2x DisplayPort 2560x1440 displays they will not power off the backlight.
Any help or chance for a release to include this support? Running Xorg 1.18:
[ 14.478324] nvidia: module license 'NVIDIA' taints kernel.
[ 14.505113] nvidia-nvlink: Nvlink Core is being initialized, major device number 244
[ 14.505165] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 0
[ 24.801826] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 361.18 Sat Jan 9 20:45:38 PST 2016
[ 24.802120] nvidia-modeset: Allocated GPU:0 (GPU-6b9a0386-820c-8e8f-4ede-c5bb479a9005) @ PCI:0000:01:00.0
[ 52.818030] nvidia-uvm: Loaded the UVM driver in lite mode, major device number 243
Verifying model:
[ 42.952] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 980 Ti (GM200-A) at PCI:1:0:0 (GPU-0)
[ 42.952] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 42.952] (--) NVIDIA(0): VideoBIOS: 84.00.36.00.07
[ 42.952] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 42.952] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 42.952] (**) NVIDIA(0): device Ancor Communications Inc ASUS PB278 (DFP-4) (Using
[ 42.952] (**) NVIDIA(0): EDID frequencies has been enabled on all display
[ 42.952] (**) NVIDIA(0): devices.)
[ 42.953] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 42.953] (**) NVIDIA(0): device Ancor Communications Inc ASUS PB278 (DFP-6) (Using
[ 42.953] (**) NVIDIA(0): EDID frequencies has been enabled on all display
[ 42.953] (**) NVIDIA(0): devices.)
Xorg during attempt to switch off backlight (the ‘disconnected’ messages are because each time I have to physically power them off)
[ 80038.310] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 80038.483] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-2: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 80038.728] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 80038.728] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 80038.731] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80038.731] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80038.731] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80038.731] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 80038.731] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 80038.731] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 80038.732] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80038.732] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80038.732] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 80038.733] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80038.733] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80038.733] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 80038.733] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 80038.733] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 80038.733] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): 960.0 MHz maximum pixel clock
[ 80038.733] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 80038.733] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 80038.733] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 80038.734] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): connected
[ 80038.734] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): Internal DisplayPort
[ 80038.734] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): 960.0 MHz maximum pixel clock
[ 80038.734] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 80038.734] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 80038.734] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 80039.105] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 80039.105] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 80039.107] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80039.107] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80039.107] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80039.107] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 80039.107] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 80039.107] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 80039.107] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80039.107] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80039.107] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 80039.107] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80039.107] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80039.107] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): 960.0 MHz maximum pixel clock
[ 80039.108] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 80039.108] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 80039.108] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): connected
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): Internal DisplayPort
[ 80039.108] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): 960.0 MHz maximum pixel clock
[ 80039.109] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 80039.109] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 80039.109] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 80046.532] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 80046.708] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, DP-4: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 80046.973] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 80046.973] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 80046.975] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80046.975] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80046.975] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80046.975] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 80046.975] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 80046.975] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 80046.975] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80046.975] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80046.975] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 80046.975] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80046.975] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80046.975] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): 960.0 MHz maximum pixel clock
[ 80046.976] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 80046.976] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 80046.976] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): connected
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): Internal DisplayPort
[ 80046.976] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): 960.0 MHz maximum pixel clock
[ 80046.976] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 80046.976] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 80046.976] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 80047.343] (II) SYN_DROPPED event from "Logitech Gaming Mouse G302" - some input events have been lost.
[ 80047.398] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 80047.398] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 80047.401] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80047.401] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80047.401] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80047.401] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 80047.401] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 80047.401] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 80047.401] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80047.401] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80047.401] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 80047.401] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80047.401] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80047.401] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 80047.401] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 80047.402] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 80047.402] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): 960.0 MHz maximum pixel clock
[ 80047.402] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 80047.402] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 80047.402] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 80047.402] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): connected
[ 80047.402] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): Internal DisplayPort
[ 80047.402] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): 960.0 MHz maximum pixel clock
[ 80047.403] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 80047.403] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 80047.403] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
[ 80048.979] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 80048.979] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 80048.982] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80048.982] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80048.982] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80048.982] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 80048.982] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 80048.982] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 80048.982] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80048.982] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80048.982] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 80048.982] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80048.982] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80048.982] (--) NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
[ 80048.982] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): connected
[ 80048.982] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): Internal DisplayPort
[ 80048.982] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-4): 960.0 MHz maximum pixel clock
[ 80048.983] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 80048.983] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 80048.983] (--) NVIDIA(GPU-0): DFP-5: 330.0 MHz maximum pixel clock
[ 80048.983] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): connected
[ 80048.983] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): Internal DisplayPort
[ 80048.983] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS PB278 (DFP-6): 960.0 MHz maximum pixel clock
[ 80048.983] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 80048.983] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 80048.983] (--) NVIDIA(GPU-0): DFP-7: 330.0 MHz maximum pixel clock
