Drive-agx-orin-linux-aarch64-sdk-build-x86 download error
hi,
I am attempting to download the nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86 image using the permissions of a regular developer. However, I encountered an error after logging in. Could it be that I need to be an authenticated enterprise user?
log:
sudo docker login nvcr.io
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /home/jiangyinghao/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
jiangyinghao@mogo:~$ sudo docker pull nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86
Using default tag: latest
Error response from daemon: Head "https://nvcr.io/v2/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86/manifests/latest": denied: A Denied
Dear @jiangyinghao ,
Could you check https://developer.nvidia.com/docs/drive/drive-os/6.0.10/public/drive-os-linux-installation/common/topics/installation/docker-ngc/download-install-docker-linux-devzone.html .
Also, do you see DRIVE OS docker image in NGC portal?
Check logout and login again with credentials to see if it works or try accessing for other machine
~0822
Could you provide any update on this issue?
