Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I am not pull docker image: drive-agx-orin-qnx-aarch64-sdk-build-x86
With properly generated NCG API key, I can docker login without issue:
**username@hostmachine**:**~**$ docker login nvcr.io
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /home/wayve/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
I can even docker pull docker image for linux:
docker pull nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
latest: Pulling from drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86
Digest: sha256:12fe44782f5c8202344bf5252611395ad6f4ae1d52049ce107beee92eb986a89
Status: Image is up to date for nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
However, I cannot docker pull image for qnx
$ docker pull nvcr.io/drive/driveos-sdk/drive-agx-orin-qnx-aarch64-sdk-build-x86:latest
Error response from daemon: manifest for nvcr.io/drive/driveos-sdk/drive-agx-orin-qnx-aarch64-sdk-build-x86:latest not found: manifest unknown: manifest unknown
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
