No containers in private registry and failed to pull docker images
Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.0.10816
other
Host Machine Version
other
I’m in the drive group, however there is no containers in private registry, I can’t pull the drive OS images either.
I’ve tried the “use alternate method” and regenerate the API KEY, nothing changed.
Dear @bill_ye,
Please confirm if you have followed Set Up Docker and NVIDIA GPU Cloud Access ?
Please check the discussion on NGC Private repository is empty if it helps?
Hi @bill_ye
Please also share your command line to pull the image and its output messages for any clues. Thanks.
the containers appeared and the docker commands worked, thanks a lot for your support!
