Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
other
I’m trying to download the docker for cross compilation from NVIDIA NGC , however the private repository never loads.
I have got the welcome email and accepted it.
Please, see picture attached.
Can you please help me with this topic?
Hi, I managed to see the repository internals, by switching between tabs couple times all containers → organization… → … → all containers.
However now I have another problem.
When I want to connect to cli or connecting thru docker I get rejected.
Please take a look:
Using CLI:
ngc config set
Enter API key [no-apikey]. Choices: [<VALID_APIKEY>, ‘no-apikey’]: my-private-key
Enter CLI output format type [ascii]. Choices: [ascii, csv, json]: csv
Enter org [no-org]. Choices: [‘drive’]: drive
Enter team [no-team]. Choices: [‘driveos-sdk’, ‘no-team’]: driveos-sdk Access denied retrieving ace list.
Enter ace [no-ace]. Choices: [‘no-ace’]: no-ace
Successfully saved NGC configuration to /home/nikolaychernuha/.ngc/config
Connecting with docker:
docker login nvcr.io
Username: nikolay.chernuha@imagry.co
Password:
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/auth”: dial unix /var/run/docker.sock: connect: permission denied
In password section I type the password from the setup page.
So, basically the question is now: why don’t I have access to the repository?
