Docker pull image not working
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
I want to download the OS from the docker. The log in sudo docker login nvcr.io was a success.
The sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v ${WORKSPACE}:/home/nvidia/nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-knext-x86:latest doesn’t work.
I got “docker run” requires at least 1 argument.
See ‘docker run --help’.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG…]
Create and run a new container from an image
I assume that I have to define ${WORKSPACE}.
I tried WORKSPACE=/home/had/
I tried sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v /home/had:/home/nvidiadocker/nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-knext-x86:latest from Set Up DRIVE OS Linux with NVIDIA GPU Cloud (NGC) | NVIDIA Docs
Please review your command carefully and ensure there are no typos. For example, the correct image should be:
nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
dia/nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
"docker run" requires at least 1 argument.
See 'docker run --help'.
Usage:  docker run [OPTIONS] IMAGE [COMMAND] [ARG...]
I just copy and paste from the documentation and it didn’t worked.
Why is there no space before the image name?
What do you mean?Where?
should be like:
dia/ nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
oh yes this was the solution. I didn’t saw the space. Thank you.
