Drive orin devloper kit flashing error 6.0.6
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
[^] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[^] Linux
QNX
other
Hardware Platform
[^] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We want to flash the drive orin through the host PC (Nuvo-7160GC-6021 neousys), we have been pulled the container SDK 6.0.6 succesfully
And we connected the C type cable on orin board next to recovery button, other side USB on the host PC
followed recovery mode procedure as below
  1. Plugged in the USB Type-C cable next to recovery button
  2. A USB 3.0 port on the host PC
  3. Press and hold the RECOVERY (REC) button on the Orin.
  4. While holding REC: Press and release the POWER button, and plugged in the 12V power
  5. Wait 2 seconds, release REC.
Next we tried with command "<ls /dev/ttyACM*> command to check port connections
output is /dev/ttyACM0
So, we tried to flash with <./flash.py /dev/ttyACM0 p3710> inside the container. Getting error as attached in the image
And attaching the drive orin connections image for your reference
Please help me to resolve this issue or i’m missing anything guide me
Dear @sudhirkumar.avv ,
I notice connection to debug port is missing
Please see Hardware Quick start guide document in NVIDIA DRIVE Documentation | NVIDIA Developer
Keep the board in normal mode when you try to flash using flash.py.
Thank you for the reply
We have connected micro-USB to debug port & facing the error while flashin (<./flash.py /dev/ttyACM1 p3710>) as mentioned below
Attaching orin board & host pc connection (another 2 ports are connected to mouse & keyboard) images for your reference
Please check & provide the solution
I notice at Drive orin developer kit display is not appearing after flashing SDK that you could flash using docker container. Let us know if you need support on this topic?
