[ 1.726566] DC OR NODE connected to /host1x/dsi
here is the full log.
thanks
nvidia@tegra-ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.15 (buchholz@buchholz-Latitude-7390-2-in-1) (gcc version 4.9.4 (Linaro GCC 4.9-2017.01) ) #2 SMP PREEMPT Fri Aug 10 11:28:46 CEST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000f2000000
[ 0.000000] On node 0 totalpages: 2051584
[ 0.000000] DMA zone: 7488 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 479232 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572352 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1ffcaa000 s31104 r8192 d30336 u69632
[ 0.000000] pcpu-alloc: s31104 r8192 d30336 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019520
[ 0.000000] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7286268K/8206336K available (10208K kernel code, 1664K rwdata, 5436K rodata, 1128K init, 679K bss, 166404K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdca000000 ( 128 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
.init : 0xffffffc000fc8000 - 0xffffffc0010e2000 ( 1128 KB)
.text : 0xffffffc000080000 - 0xffffffc000fc8000 ( 15648 KB)
.data : 0xffffffc001101000 - 0xffffffc0012a12b0 ( 1665 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008871] tegra-id: chipid=21817.
[ 0.012696] tegra-id: opt_subrevision=1.
[ 0.017471] Console: colour dummy device 80x25
[ 0.022441] console [tty0] enabled
[ 0.025973] kmemleak: Kernel memory leak detector disabled
[ 0.031668] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.042422] pid_max: default: 32768 minimum: 301
[ 0.047246] Security Framework initialized
[ 0.051521] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058660] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.066610] Initializing cgroup subsys freezer
[ 0.071234] Initializing cgroup subsys debug
[ 0.075793] CPU0 ipc=752
[ 0.078432] CPU1 ipc=1024
[ 0.081155] CPU2 ipc=1024
[ 0.083871] CPU3 ipc=752
[ 0.086504] CPU4 ipc=752
[ 0.089138] CPU5 ipc=752
[ 0.091788] ASID allocator initialised with 65536 entries
[ 0.133946] CPU1: Booted secondary processor [4e0f0030]
[ 0.145524] CPU2: Booted secondary processor [4e0f0030]
[ 0.157383] CPU3: Booted secondary processor [411fd073]
[ 0.169356] CPU4: Booted secondary processor [411fd073]
[ 0.181347] CPU5: Booted secondary processor [411fd073]
[ 0.181386] Brought up 6 CPUs
[ 0.211589] SMP: Total of 6 processors activated.
[ 0.216473] CPU: All CPU(s) started at EL2
[ 0.221093] devtmpfs: initialized
[ 0.248125] Initilizing CustomIPI irq domain
[ 0.252776] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.272399] pinctrl core: initialized pinctrl subsystem
[ 0.278186] OS set in device tree is L4T.
[ 0.282850] regulator-dummy: no parameters
[ 0.287336] Initializing plugin-manager
[ 0.291407] Plugin module not found
[ 0.295445] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.303385] node /plugin-manager/fragement@0 match with odm-data enable-tegra-wdt
[ 0.311653] node /plugin-manager/fragement@4 match with odm-data enable-tegra-wdt
[ 0.320210] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.329892] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.339258] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.348540] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.356850] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.365822] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.374704] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.383362] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.392097] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.400398] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.409662] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.421413] Adding domain adsp-pd to PM domain ape-pd
[ 0.430687] NET: Registered protocol family 16
[ 0.436833] console [pstore-1] enabled
[ 0.440778] pstore: Registered ramoops as persistent store backend
[ 0.447230] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.461577] cpuidle: using governor ladder
[ 0.473560] cpuidle: using governor menu
[ 0.479275] bpmp: waiting for handshake
[ 0.483309] bpmp: handshake completed
[ 0.487177] bpmp: synchronizing channels
[ 0.491278] bpmp: channels synchronized
[ 0.495283] bpmp: connect returned 0
[ 0.499526] tegra186-pmc device create success
[ 0.504204] scratch reg offset dts data not present
[ 0.509406] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.516951] PMC: configuring io pad defaults
[ 0.521435] T186 pmc padctrl driver initialized
[ 0.526166] ### PMC reset source: Power on reset
[ 0.530984] ### PMC reset level: L0
[ 0.534626] ### PMC reset status reg: 0x0
[ 0.539663] vdso: 2 pages (1 code @ ffffffc001109000, 1 data @ ffffffc001108000)
[ 0.547465] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.556022] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.566200] tegra_powergate_init: DONE
[ 0.570303] DTS File Name: /home/buchholz/Develop/L4T27_1/kernel_source/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.590330] DTB Build time: Aug 10 2018 11:38:52
[ 0.596636] Tegra reboot handler registered.
[ 0.602478] Registering Tegra186 clocks (this may take a while)...done
[ 0.610967] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.617817] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.622729] arm-smmu 12000000.iommu: stage 1 translation
[ 0.628362] arm-smmu 12000000.iommu: stage 2 translation
[ 0.633992] arm-smmu 12000000.iommu: nested translation
[ 0.639545] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.648285] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.659300] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.666218] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.673046] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.718454] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.728919] iommu: Adding device 3460000.sdhci to group 0
[ 0.735243] iommu: Adding device 3400000.sdhci to group 1
[ 0.743742] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.750156] iommu: Adding device 3160000.i2c to group 3
[ 0.755950] iommu: Adding device c240000.i2c to group 4
[ 0.761768] iommu: Adding device 3180000.i2c to group 5
[ 0.767506] iommu: Adding device 3190000.i2c to group 6
[ 0.773450] iommu: Adding device 31b0000.i2c to group 7
[ 0.779190] iommu: Adding device 31c0000.i2c to group 8
[ 0.784969] iommu: Adding device c250000.i2c to group 9
[ 0.790737] iommu: Adding device 31e0000.i2c to group 10
[ 0.798027] iommu: Adding device 3210000.spi to group 11
[ 0.803881] iommu: Adding device c260000.spi to group 12
[ 0.809723] iommu: Adding device 3240000.spi to group 13
[ 0.815922] iommu: Adding device 3100000.serial to group 14
[ 0.822036] iommu: Adding device 3110000.serial to group 15
[ 0.828141] iommu: Adding device 3130000.serial to group 16
[ 0.834918] iommu: Adding device 2490000.ether_qos to group 17
[ 0.841494] iommu: Adding device b000000.rtcpu to group 18
[ 0.848021] Wake73 for irq=42
[ 0.851418] iommu: Adding device smmu_test to group 19
[ 0.857269] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.863924] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.870572] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.877216] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.883856] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.890499] mc-err: Set intmask: 0xf3140
[ 0.894788] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.901693] Wake76 for irq=199
[ 0.904885] Wake77 for irq=199
[ 0.908072] Wake78 for irq=199
[ 0.911257] Wake79 for irq=199
[ 0.914442] Wake80 for irq=199
[ 0.917629] Wake81 for irq=199
[ 0.920817] Wake82 for irq=199
[ 0.924133] iommu: Adding device 3530000.xhci to group 20
[ 0.930115] iommu: Adding device 3550000.xudc to group 21
[ 0.936515] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.942703] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.950476] iommu: Adding device 13e10000.host1x to group 22
[ 0.956625] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.963184] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.969733] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.976325] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.982907] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.989482] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.996081] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 1.002647] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 1.009416] iommu: Adding device 150c0000.nvcsi to group 31
[ 1.015681] iommu: Adding device 15700000.vi to group 32
[ 1.021511] iommu: Adding device 15600000.isp to group 33
[ 1.027477] iommu: Adding device 15200000.nvdisplay to group 34
[ 1.036982] platform 15200000.nvdisplay: IOVA linear map 0x00000000ae000000(2a000000)
[ 1.045583] iommu: Adding device 15210000.nvdisplay to group 35
[ 1.052091] iommu: Adding device 15340000.vic to group 36
[ 1.057944] iommu: Adding device 154c0000.nvenc to group 37
[ 1.063941] iommu: Adding device 15480000.nvdec to group 38
[ 1.070042] iommu: Adding device 15380000.nvjpg to group 39
[ 1.076058] iommu: Adding device 15500000.tsec to group 40
[ 1.081970] iommu: Adding device 15100000.tsecb to group 41
[ 1.088407] iommu: Adding device 15810000.se to group 42
[ 1.094153] iommu: Adding device 15820000.se to group 43
[ 1.099875] iommu: Adding device 15830000.se to group 44
[ 1.105610] iommu: Adding device 15840000.se to group 45
[ 1.111592] iommu: Adding device 17000000.gp10b to group 46
[ 1.118600] tegra-reset 5000000.clock: registered 193 resets.
[ 1.125969] iommu: Adding device d000000.bpmp to group 47
[ 1.131817] bpmp: ping status is 0
[ 1.135529] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed830
[ 1.146214] iommu: Adding device 2600000.dma to group 48
[ 1.152515] GPIO line 461 (cam0-rst) hogged as output/high
[ 1.158290] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.164327] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 1.170270] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 1.176824] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.186136] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.191804] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.200693] iommu: Adding device 10003000.pcie-controller to group 49
[ 1.207641] iommu: Adding device sound to group 50
[ 1.214172] iommu: Adding device 3510000.hda to group 51
[ 1.220725] iommu: Adding device adsp_audio to group 52
[ 1.227397] iommu: Adding device 2993000.adsp to group 53
[ 1.238428] iommu: Adding device c160000.aon to group 54
[ 1.246116] vdd-ac-bat: 5000 mV
[ 1.251304] vdd-1v8-ap: 1800 mV
[ 1.255604] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.261443] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.283916] SCSI subsystem initialized
[ 1.288009] libata version 3.00 loaded.
[ 1.288154] usbcore: registered new interface driver usbfs
[ 1.293920] usbcore: registered new interface driver hub
[ 1.299655] usbcore: registered new device driver usb
[ 1.307380] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 1.314338] pca953x 0-0074: failed reading register
[ 1.319506] pca953x: probe of 0-0074 failed with error -121
[ 1.325629] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 1.332613] pca953x 0-0077: failed reading register
[ 1.337786] pca953x: probe of 0-0077 failed with error -121
[ 1.343789] tps65132 0-003e: No active discharge gpio for regulator tps65132-outp
[ 1.351761] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.358860] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.365836] outp: 4000 <--> 6000 mV
[ 1.369601] tps65132 0-003e: No active discharge gpio for regulator tps65132-outn
[ 1.377561] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.384649] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.391594] outn: 4000 <--> 6000 mV
[ 1.406120] media: Linux media interface: v0.10
[ 1.410904] Linux video capture interface: v2.00
[ 1.419449] pps_core: LinuxPPS API ver. 1 registered
[ 1.424646] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.434194] PTP clock support registered
[ 1.440035] Tegra WDT setup timeout = 120 seconds.
[ 1.445072] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.453311] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.461100] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 1.467357] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 1.473587] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 1.485697] vddio-ddr: at 1125 mV
[ 1.493546] avdd_dsi_csi: 1200 mV
[ 1.501547] vdd-1v8: 1800 mV
[ 1.509549] vdd-3v3-sys: 3300 mV
[ 1.514053] spmic-ldo0: at 1800 mV
[ 1.518457] spmic-ldo1: at 800 mV
[ 1.525550] vddio-3v3: 3300 mV
[ 1.529589] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 1.537547] vdd-rtc: 1000 mV
[ 1.541555] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 1.549551] spmic-ldo6: at 1500 mV
[ 1.553931] vdd-pex-1v05: 1000 mV
[ 1.558366] dvdd-pex: 1000 mV
[ 1.561923] max77620 4-003c: max77620 probe successful
[ 1.567567] Advanced Linux Sound Architecture Driver Initialized.
[ 1.575349] en-vdd-sd: 3300 mV
[ 1.579009] vdd-usb0-5v: 5000 mV
[ 1.582700] vdd-usb1-5v: 5000 mV
[ 1.586671] vdd-3v3: 3300 mV
[ 1.589986] en-vdd-vcm-2v8: 2800 mV
[ 1.593927] vdd-sys-bl: 3300 mV
[ 1.598257] gpio tegra-gpio wake53 for gpio=159(X:5)
[ 1.605206] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 1.612793] clocksource: Switched to clocksource arch_sys_counter
[ 1.649229] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.656302] dma_declare_coherent_resizable_cma_memory:288: resizable heap=vpr, base=0x00000000ae000000, size=0x2a000000
[ 1.664548] Wake76 for irq=199
[ 1.664551] Wake77 for irq=199
[ 1.664553] Wake78 for irq=199
[ 1.664554] Wake79 for irq=199
[ 1.664556] Wake80 for irq=199
[ 1.664558] Wake81 for irq=199
[ 1.664560] Wake82 for irq=199
[ 1.665737] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 1.665945] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 1.666058] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 1.666134] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 1.666552] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 1.666736] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.666883] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.667026] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 1.667060] isomgr_init(): iso emc max clk=1866000KHz
[ 1.667063] isomgr_init(): max_iso_bw=26870400KB
[ 1.667283] tegra186-pmc-iopower pmc-iopower: Rail iopower-sys is having fixed voltage 1800000
[ 1.667375] tegra186-pmc-iopower pmc-iopower: Rail iopower-uart is having fixed voltage 1800000
[ 1.667446] tegra186-pmc-iopower pmc-iopower: Rail iopower-conn is having fixed voltage 1800000
[ 1.667508] tegra186-pmc-iopower pmc-iopower: Rail iopower-edp is having fixed voltage 1800000
[ 1.667570] tegra186-pmc-iopower pmc-iopower: Rail iopower-pex-ctrl-audio is having fixed voltage 1800000
[ 1.667646] tegra186-pmc-iopower pmc-iopower: Rail iopower-ufs is having fixed voltage 1800000
[ 1.667722] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr0 is having fixed voltage 0
[ 1.667770] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr1 is having fixed voltage 0
[ 1.667825] tegra186-pmc-iopower pmc-iopower: Rail iopower-csi-dsi is having fixed voltage 1200000
[ 1.667885] tegra186-pmc-iopower pmc-iopower: Rail iopower-cam is having fixed voltage 1800000
[ 1.667944] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 1.667997] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc1-hv is having voltages: 1800000:3300000
[ 1.668068] tegra186-pmc-iopower pmc-iopower: Rail iopower-audio-hv is having fixed voltage 1800000
[ 1.668126] tegra186-pmc-iopower pmc-iopower: Rail iopower-dbg is having fixed voltage 1800000
[ 1.668191] tegra186-pmc-iopower pmc-iopower: Rail iopower-spi is having fixed voltage 1800000
[ 1.668254] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao is having fixed voltage 1800000
[ 1.668304] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao-hv is having fixed voltage 3300000
[ 1.668361] tegra186-pmc-iopower pmc-iopower: Rail iopower-dmic-hv is having fixed voltage 1800000
[ 1.668409] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc2-hv is having fixed voltage 3300000
[ 1.668476] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc3-hv is having voltages: 1800000:3300000
[ 1.668486] tegra186-pmc-iopower pmc-iopower: NO_IO_POWER setting 0x00000000
[ 1.668806] NET: Registered protocol family 2
[ 1.669347] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.670210] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.671188] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.671230] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.671366] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.671665] NET: Registered protocol family 1
[ 1.672004] RPC: Registered named UNIX socket transport module.
[ 1.672006] RPC: Registered udp transport module.
[ 1.672008] RPC: Registered tcp transport module.
[ 1.672011] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.672053] PCI: CLS 0 bytes, default 128
[ 1.688433] host1x 13e10000.host1x: initialized
[ 1.689755] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.690850] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 1.691008] audit: initializing netlink subsys (disabled)
[ 1.691034] audit: type=2000 audit(1.652:1): initialized
[ 1.699785] io scheduler noop registered (default)
[ 1.705805] Adding domain tsec-pd to PM domain host-pd
[ 1.708453] tsec 15500000.tsec: initialized
[ 1.709815] tsec 15100000.tsecb: initialized
[ 1.710235] Adding domain nvdec-pd to PM domain host-pd
[ 1.712132] nvdec 15480000.nvdec: initialized
[ 1.712720] Adding domain vic03-pd to PM domain host-pd
[ 1.712741] Adding domain msenc-pd to PM domain host-pd
[ 1.712793] Adding domain nvjpg-pd to PM domain host-pd
[ 1.716362] falcon 15340000.vic: initialized
[ 1.717600] falcon 154c0000.nvenc: initialized
[ 1.718812] falcon 15380000.nvjpg: initialized
[ 1.719876] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.720616] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.721358] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.722068] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.722921] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.723602] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.724306] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.725032] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.726558] tegradc 15200000.nvdisplay: Display dc.15200000 registered with id=0
[ 1.726644] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.726651] specified ganged swapped links, but no ganged type
[ 1.726652] specified ganged write to all links, but no ganged type
[ 1.726763] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1250000, vi_iso_bw=1500000, max_bw=1500000
[ 1.726893] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.734063] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.734065] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.734066] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.734097] tegradc 15200000.nvdisplay: vblank syncpt # 7 for dc 0
[ 1.734101] tegradc 15200000.nvdisplay: vpulse3 syncpt # 8 for dc 0
[ 1.735775] tegradc 15200000.nvdisplay: DSI: HS clock rate is 184500
[ 1.736076] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 1.736719] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.737139] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.737407] tegradc 15200000.nvdisplay: probed
[ 1.739797] console [ttyS0] disabled
[ 2.302659] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 2.302782] cma: enabled page replacement for spfn=ae000, epfn=d8000
[ 2.302793] dma_declare_coherent_resizable_cma_memory:335: resizable cma heap=vpr create successful
[ 2.302794] nvmap_page_pool_init: Total RAM pages: 2009983
[ 2.302798] nvmap_page_pool_init: nvmap page pool size: 251247 pages (981 MB)
[ 2.302880] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.303372] misc nvmap: created heap vpr base 0x00000000ae000000 size (688128KiB)
[ 2.304302] Console: switching to colour frame buffer device 60x50
[ 2.365335] tegradc 15200000.nvdisplay: fb registered
[ 2.365566] PD DISP0 index2 UP
[ 2.366002] PD DISP1 index3 UP
[ 2.372905] rate get on hub 408000000
[ 2.398376] dc clk 30743989
[ 2.402400] rate get on compclk 30666015
[ 2.409114] rate get on compclk 30666015
[ 2.412186] tegradc 15200000.nvdisplay: Link compression not supported by the panel
[ 2.413056] rate get on compclk 30666015
[ 2.416376] rate get on compclk 30666015
[ 2.481237] console [ttyS0] enabled
[ 2.490736] bootconsole [uart0] disabled
[ 2.502961] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 2.516617] serial-tegra 3130000.serial: RX in PIO mode
[ 2.518165] rate get on compclk 30666015
[ 2.531483] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.544993] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.551792] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.560924] nct1008_nct72 7-004c: starting parse dt
[ 2.567355] nct1008_nct72 7-004c: success parsing dt
[ 2.573906] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.618434] tmp451: Enabled overheat logging at 104.00C
[ 2.625199] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.631818] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.643072] THERMAL EST: found 3 subdevs
[ 2.648383] THERMAL EST num_resources: 0
[ 2.653612] [THERMAL EST subdev 0]
[ 2.658247] [THERMAL EST subdev 1]
[ 2.662854] [THERMAL EST subdev 2]
[ 2.667748] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.679032] THERMAL EST: thz register success.
[ 2.684801] THERMAL EST: end of probe, return err: 0
[ 2.691675] tegra_profiler: Branch: Dev
[ 2.696650] tegra_profiler: Version: 1.109
[ 2.701952] tegra_profiler: Samples version: 37
[ 2.707643] tegra_profiler: IO version: 20
[ 2.712888] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.718384] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.727356] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.732902] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.741984] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.747548] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.756677] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.762261] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.771335] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.776964] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.786104] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.791739] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.801129] tegra_profiler: auth: init
[ 2.809583] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.821556] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.822945] rate get on compclk 30666015
[ 2.826327] rate get on compclk 30666015
[ 2.826342] rate get on compclk 30666015
[ 2.842795] tegradc 15200000.nvdisplay: Window 0 assigned to head 0
[ 2.858823] scsi host0: tegra_ahci
[ 2.859515] tegradc 15200000.nvdisplay: Window 1 assigned to head 0
[ 2.872439] scsi host1: tegra_ahci
[ 2.876233] tegradc 15200000.nvdisplay: Window 2 assigned to head 0
[ 2.876431] tegradc 15210000.nvdisplay: Display dc.15210000 registered with id=1
[ 2.876440] DC OR NODE connected to /host1x/sor1
[ 2.876510] parse_tmds_config: No tmds-config node
[ 2.876590] tegradc 15210000.nvdisplay: DT parsed successfully
[ 2.876812] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 2.876819] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 2.877183] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 2.878810] PD DISP2 index4 UP
[ 2.906276] PD DISP2 index4 DOWN
[ 2.907632] tegradc 15210000.nvdisplay: probed
[ 2.957362] tegradc 15210000.nvdisplay: fb registered
[ 2.957518] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 2.957522] ata2: DUMMY
[ 2.958631] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.959067] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.959473] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.960162] tun: Universal TUN/TAP device driver, 1.6
[ 2.960165] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.960284] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.960286] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.960354] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.960356] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.960509] PPP generic driver version 2.4.2
[ 2.960642] PPP BSD Compression module registered
[ 2.960648] PPP Deflate Compression module registered
[ 2.960667] PPP MPPE Compression module registered
[ 2.960678] NET: Registered protocol family 24
[ 2.960724] usbcore: registered new interface driver asix
[ 2.960749] usbcore: registered new interface driver ax88179_178a
[ 2.960797] usbcore: registered new interface driver cdc_ether
[ 2.960828] usbcore: registered new interface driver smsc95xx
[ 2.960857] usbcore: registered new interface driver net1080
[ 2.960880] usbcore: registered new interface driver cdc_subset
[ 2.960903] usbcore: registered new interface driver zaurus
[ 2.960942] usbcore: registered new interface driver cdc_ncm
[ 2.961221] usbcore: registered new interface driver usb-storage
[ 2.961277] usbcore: registered new interface driver usbserial
[ 2.961307] usbcore: registered new interface driver ftdi_sio
[ 2.961326] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.961374] usbcore: registered new interface driver option
[ 2.961390] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.961414] usbcore: registered new interface driver pl2303
[ 2.961430] usbserial: USB Serial support registered for pl2303
[ 2.961604] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.963684] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.096148] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.098688] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.098703] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.098885] i2c /dev entries driver
[ 3.099674] gspca_main: v2.14.0 registered
[ 3.099720] usbcore: registered new interface driver gspca_zc3xx
[ 3.099962] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.101558] FAN: coudln't get the regulator
[ 3.101961] device-mapper: uevent: version 1.0.3
[ 3.102133] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.102286] sdhci: Secure Digital Host Controller Interface driver
[ 3.102287] sdhci: Copyright(c) Pierre Ossman
[ 3.102290] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.102554] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.102837] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.103238] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.103305] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.103719] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.105073] usbcore: registered new interface driver usbhid
[ 3.105075] usbhid: USB HID core driver
[ 3.105224] sdhci-tegra 3460000.sdhci: voltage switch failed in probe, err: -524
[ 3.106539] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.106881] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.106988] ina3221x: probe of 0-0042 failed with error -121
[ 3.107226] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.107558] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.107646] ina3221x: probe of 0-0043 failed with error -121
[ 3.107944] nvadsp 2993000.adsp: in probe()...
[ 3.108782] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.108806] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.108924] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.109348] tegra_central_actmon d230000.actmon: in probe()...
[ 3.111447] tegra_central_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.111877] kfuse 3830000.kfuse: initialized
[ 3.115787] Denver: backdoor interface is NOT available.
[ 3.116774] coresight-tmc 8030000.etf: TMC initialized
[ 3.117087] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.117515] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.117871] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.118235] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.118772] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.119271] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.119765] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.120264] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.120288] Module initialized successfully
[ 3.123655] camchar: rtcpu character device driver loaded
[ 3.125372] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.125495] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.125559] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.126090] **** A57 ECC: Enabled
[ 3.126092] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 3.126223] parse_throttle_dt_data: Num cap clks = 4
[ 3.126226] parse_throttle_dt_data: clk=mcpu type=1
[ 3.126228] parse_throttle_dt_data: clk=bcpu type=2
[ 3.126233] parse_throttle_dt_data: clk=gpu type=4
[ 3.126235] parse_throttle_dt_data: clk=emc type=3
[ 3.126679] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.126863] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.127270] Adding domain se-pd to PM domain host-pd
[ 3.136786] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.136995] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.137304] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.139237] sdhci-tegra 3440000.sdhci: voltage switch failed in probe, err: -524
[ 3.176786] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.176787] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.177000] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.177047] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.177126] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.177216] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 248
[ 3.177426] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.179310] sdhci-tegra 3400000.sdhci: voltage switch failed in probe, err: -524
[ 3.210747] mmc0: MAN_BKOPS_EN bit is not set
[ 3.216828] gpio tegra-gpio wake71 for gpio=125(P:6)
[ 3.216860] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.217981] mmc0: Skipping tuning since strobe enabled
[ 3.225389] mmc0: periodic cache flush enabled
[ 3.225396] mmc0: new HS400 MMC card at address 0001
[ 3.225675] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.225781] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.226868] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.265178] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.265178] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.280792] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.462298] mmc1 tuning done saved tap delay=19
[ 3.462302] mmc1: hw tuning done ...
[ 3.462309] mmc1: tuning_window[0]: 0xffffffff
[ 3.462314] mmc1: tuning_window[1]: 0xfffff8ff
[ 3.462318] mmc1: tuning_window[2]: 0xffc7ffff
[ 3.462322] mmc1: tuning_window[3]: 0x3fffffff
[ 3.462327] mmc1: tuning_window[4]: 0x0
[ 3.462331] mmc1: tuning_window[5]: 0x0
[ 3.462335] mmc1: tuning_window[6]: 0x0
[ 3.462339] mmc1: tuning_window[7]: 0x0
[ 3.462369] sdhci: Tap value: 19 | Trim value: 5
[ 3.462373] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.468006] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.468050] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.017875] gpio tegra-gpio wake21 for gpio=121(P:2)
[ 4.023944] PD DISP2 index4 UP
[ 4.028338] rate get on hub 408000000
[ 4.033490] Parent Clock set for DC plld2
[ 4.039913] random: nonblocking pool is initialized
[ 4.046710] dc clk 154128046
[ 4.053771] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 4.063507] rate get on compclk 154128046
[ 4.069008] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 4.085680] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 4.102361] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 4.111769] tegra-se-nvhost 15810000.se: initialized
[ 4.118189] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.126662] tegra-se-nvhost 15820000.se: initialized
[ 4.133233] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.141670] tegra-se-nvhost 15830000.se: initialized
[ 4.147982] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.156478] tegra-se-nvhost 15840000.se: initialized
[ 4.162839] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.174726] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.185905] cpufreq: platform driver Initialization: pass
[ 4.192420] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.203603] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.214556] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ca415
[ 4.223252] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.233102] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.242890] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.253773] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.256180] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 b9 b7
[ 4.256620] libphy: dwc_phy: probed
[ 4.275410] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.275562] tegradc 15210000.nvdisplay: vrr_setup failed
[ 4.290021] tegradc 15210000.nvdisplay: hdmi: plugged
[ 4.291134] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.291139] Tachometer driver initialized with pulse_per_rev: 1 and win_len: 1
[ 4.294184] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.295340] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.296848] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.297140] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.297380] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.297667] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.297670] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.297672] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.300299] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.300300] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.300450] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.306787] OPE platform probe
[ 4.306854] OPE platform probe successful
[ 4.318022] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 4.318185] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 4.319098] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 4.394617] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.394789] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.394877] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.394966] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.395051] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.395136] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.395222] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.395306] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.395416] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.395505] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.395592] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.395677] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.395782] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.395878] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.395961] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.396044] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.396130] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.396216] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.396316] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.396400] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.397717] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.397811] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.397859] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.397883] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.438905] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.439538] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 4.439542] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.439979] GACT probability NOT on
[ 4.439988] Mirror/redirect action on
[ 4.440000] u32 classifier
[ 4.440001] Actions configured
[ 4.440017] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.441336] Initializing XFRM netlink socket
[ 4.441633] NET: Registered protocol family 10
[ 4.442311] NET: Registered protocol family 17
[ 4.442325] NET: Registered protocol family 15
[ 4.442331] 8021q: 802.1Q VLAN Support v1.8
[ 4.447742] Registered cp15_barrier emulation handler
[ 4.457233] Registered setend emulation handler
[ 4.458685] registered taskstats version 1
[ 4.459261] Adding domain ispa-pd to PM domain host-pd
[ 4.461893] isp 15600000.isp: initialized
[ 4.462303] Adding domain ve-pd to PM domain host-pd
[ 4.465130] nvcsi 150c0000.nvcsi: initialized
[ 4.466839] Wake76 for irq=199
[ 4.466840] Wake77 for irq=199
[ 4.466841] Wake78 for irq=199
[ 4.466842] Wake79 for irq=199
[ 4.466842] Wake80 for irq=199
[ 4.466843] Wake81 for irq=199
[ 4.466844] Wake82 for irq=199
[ 4.467119] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.467121] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.469123] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.469248] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.469250] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.469652] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.470202] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.473028] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.473616] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.476200] tegra186-cam-rtcpu b000000.rtcpu: booting sce with Camera RTCPU FW
[ 4.476219] tegra186-cam-rtcpu b000000.rtcpu: sce gets unhalted
[ 4.476956] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 4.477748] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 4.477902] tegra186-cam-rtcpu b000000.rtcpu: enabling tracing
[ 4.477927] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.478179] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=2 ivc=2 sha1=fb16914d17f56e81ad21e716791045b9ac83064a
[ 4.479955] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.480013] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.480058] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.480172] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.514036] tegra_rtc c2a0000.rtc: setting system clock to 2018-08-15 04:51:30 UTC (1534308690)
[ 4.528636] tegra-vi4 15700000.vi: initialized
[ 4.544127] bpmp: mounted debugfs mirror
[ 4.544492] [dram-timers] DRAM derating cdev registered.
[ 4.547290] outp: disabling
[ 4.547293] outn: disabling
[ 4.547300] spmic-ldo0: disabling
[ 4.547476] spmic-ldo1: disabling
[ 4.547623] en-vdd-sd: disabling
[ 4.547624] vdd-usb0-5v: disabling
[ 4.547626] vdd-3v3: disabling
[ 4.547628] en-vdd-vcm-2v8: disabling
[ 4.547629] vdd-sys-bl: disabling
[ 4.553128] ALSA device list:
[ 4.553130] #0: tegra-hda at 0x3518000 irq 392
[ 4.553131] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.067760] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 5.078987] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 5.595479] EXT4-fs (mmcblk0p1): 20 orphan inodes deleted
[ 5.601719] EXT4-fs (mmcblk0p1): recovery complete
[ 5.618675] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.628356] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.638306] devtmpfs: mounted
[ 5.642362] Freeing unused kernel memory: 1128K (ffffffc000fc8000 - ffffffc0010e2000)
[ 5.651734] Freeing alternatives memory: 92K (ffffffc0010e2000 - ffffffc0010f9000)
[ 5.707991] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.729307] systemd[1]: Detected architecture arm64.
[ 5.746218] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.861406] systemd[1]: Reached target User and Group Name Lookups.
[ 5.876932] systemd[1]: Created slice User and Session Slice.
[ 5.892908] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.908892] systemd[1]: Listening on udev Kernel Socket.
[ 5.924881] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.944839] systemd[1]: Reached target Swap.
[ 5.956862] systemd[1]: Listening on Journal Socket.
[ 5.968824] systemd[1]: Reached target Encrypted Volumes.
[ 5.984935] systemd[1]: Listening on Journal Audit Socket.
[ 6.000894] systemd[1]: Created slice System Slice.
[ 6.028896] systemd[1]: Mounting Debug File System...
[ 6.040904] systemd[1]: Reached target Slices.
[ 6.054917] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.072987] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.109112] systemd[1]: Started Braille Device Support.
[ 6.128070] systemd[1]: Starting Load Kernel Modules...
[ 6.141886] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.156930] systemd[1]: Listening on udev Control Socket.
[ 6.172880] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.192839] systemd[1]: Reached target Remote File Systems.
[ 6.208862] systemd[1]: Listening on Syslog Socket.
[ 6.237070] systemd[1]: Starting Journal Service...
[ 6.249000] systemd[1]: Created slice system-getty.slice.
[ 6.265040] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.301830] systemd[1]: Mounted Debug File System.
[ 6.316975] systemd[1]: Started Journal Service.
[ 6.527566] systemd-journald[223]: Received request to flush runtime journal from PID 1
[ 6.648710] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 7.662983] xhci-tegra 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 7.664807] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 7.664825] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 7.665619] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 7.665641] xhci-tegra 3530000.xhci: irq 54, io mem 0x03530000
[ 7.665747] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.665750] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.665752] usb usb1: Product: xHCI Host Controller
[ 7.665753] usb usb1: Manufacturer: Linux 4.4.15 xhci-hcd
[ 7.665755] usb usb1: SerialNumber: 3530000.xhci
[ 7.666014] hub 1-0:1.0: USB hub found
[ 7.666032] hub 1-0:1.0: 4 ports detected
[ 7.684792] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 7.684802] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 7.684918] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.684921] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.684923] usb usb2: Product: xHCI Host Controller
[ 7.684924] usb usb2: Manufacturer: Linux 4.4.15 xhci-hcd
[ 7.684926] usb usb2: SerialNumber: 3530000.xhci
[ 7.685149] hub 2-0:1.0: USB hub found
[ 7.685164] hub 2-0:1.0: 3 ports detected
[ 7.901019] cfg80211: World regulatory domain updated:
[ 7.901022] cfg80211: DFS Master region: unset
[ 7.901022] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.901026] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.901028] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.901029] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.901031] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.901033] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.901035] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.901037] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.901038] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.988769] usb 1-2: new low-speed USB device number 2 using xhci-tegra
[ 8.123291] usb 1-2: New USB device found, idVendor=1a81, idProduct=1002
[ 8.123296] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.123300] usb 1-2: Product: Wireless Dongle
[ 8.123303] usb 1-2: Manufacturer: G-Tech
[ 8.123521] usb 1-2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 8.123538] usb 1-2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 8.123886] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 8.127568] input: G-Tech Wireless Dongle as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:1A81:1002.0001/input/input4
[ 8.181084] hid-generic 0003:1A81:1002.0001: input,hidraw0: USB HID v1.11 Keyboard [G-Tech Wireless Dongle] on usb-3530000.xhci-2/input0
[ 8.188376] input: G-Tech Wireless Dongle as /devices/3530000.xhci/usb1/1-2/1-2:1.1/0003:1A81:1002.0002/input/input5
[ 8.240923] hid-generic 0003:1A81:1002.0002: input,hidraw1: USB HID v1.11 Mouse [G-Tech Wireless Dongle] on usb-3530000.xhci-2/input1
[ 9.332511] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 9.341656] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 9.972457] gk20a 17000000.gp10b: railgate is disabled.
[ 10.069265] CPU1: shutdown
[ 10.073571] psci: CPU1 killed.
[ 10.080777] CPU2: shutdown
[ 10.087667] psci: CPU2 killed.
[ 10.268082] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.338033] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 10.339211] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.395278] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.492884] rate get on compclk 30666015
[ 11.493138] PD DISP2 index4 DOWN
[ 11.506201] tegradc 15210000.nvdisplay: unblank
[ 11.506211] PD DISP2 index4 UP
[ 11.506554] rate get on hub 408000000
[ 11.506834] Parent Clock set for DC plld2
[ 11.508364] dc clk 154128046
[ 11.511459] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 11.511464] rate get on compclk 154128046
[ 11.527239] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 11.543907] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 11.560574] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 12.605789] tegradc 15210000.nvdisplay: unblank
[ 12.947860] tegradc 15210000.nvdisplay: blank - powerdown
[ 13.051090] rate get on compclk 30666015
[ 13.051333] PD DISP2 index4 DOWN
[ 14.072789] tegradc 15200000.nvdisplay: unblank
[ 14.322085] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.323376] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.242422] tegradc 15210000.nvdisplay: blank - powerdown
[ 16.247857] tegradc 15210000.nvdisplay: unblank
[ 16.247871] PD DISP2 index4 UP
[ 16.248328] rate get on hub 408000000
[ 16.248667] Parent Clock set for DC plld2
[ 16.250550] dc clk 154128046
[ 16.253235] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 16.253239] rate get on compclk 154128046
[ 16.268995] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 16.285675] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 16.302316] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 16.646336] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.695252] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.734827] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.774668] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.777384] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.781602] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.813394] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.816166] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.823390] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 16.886029] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 17.426279] tegradc 15210000.nvdisplay: unblank
[ 21.124284] tegradc 15210000.nvdisplay: blank - powerdown
[ 21.226159] rate get on compclk 30666015
[ 21.226413] PD DISP2 index4 DOWN
[ 21.239507] tegradc 15210000.nvdisplay: unblank
[ 21.239518] PD DISP2 index4 UP
[ 21.239871] rate get on hub 408000000
[ 21.240168] Parent Clock set for DC plld2
[ 21.241969] dc clk 154128046
[ 21.246700] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 21.246705] rate get on compclk 154128046
[ 21.278171] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 21.294885] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 21.311499] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 21.377409] tegradc 15210000.nvdisplay: unblank
