e-CAM130A_CUXVR not initializing on Jetson AGX Xavier
I have followed the installation instructions in the Getting Started manual, but when I run the command:
$dmesg | grep -i “Detected ar1335 sensor”
nothing is printed, similarly
$ls /dev/video*
doesnt find any cameras. I have attached the kernel logs.
Any ideas?
Many thanks,
Al
klog.txt (78.5 KB)
Hello @user87673,
It seems like the sensor driver is not loaded. Please repeat the Software quick setup procedure given in getting started manual document.
Also, Could you share the release package name you are using?
