I am building an early architecture called **EdgeAI Forge** to explore local-first AI-assisted engineering for machine vision, ROS 2, robotics, and industrial edge deployment.
The target design separates:
- a control plane for orchestration, memory, artifacts, APIs, approvals, and observability; and
- a compute plane for local LLM/VLM inference, vision workloads, TensorRT optimization, and robotics models.
One planned workflow begins with a request such as:
> Build a ROS 2 object-detection pipeline, generate the nodes and launch files, test it, benchmark FPS/latency, optimize it, and prepare a reviewed Jetson deployment.
The repository currently contains a FastAPI/Next.js platform scaffold and a small Ollama-backed Planner/Vision/ROS proof of concept. Jetson, Isaac ROS, TensorRT, and production deployment features are roadmap work rather than completed capabilities.
I would appreciate technical guidance from the NVIDIA developer community on:
1. A sensible simulation-to-Jetson workflow for generated ROS 2 vision packages.
2. Where Isaac ROS components provide the most leverage for an initial MVP.
3. Reliable ONNX/TensorRT export and validation patterns across workstation and Jetson targets.
4. Benchmark methodology for end-to-end latency, FPS, power, memory, and thermal behavior.
5. Practical local VLM/LLM serving options when the control and compute planes are separate.
6. Safety and rollback boundaries for agent-assisted deployment.
Project: GitHub - afridali123/EdgeAI_Forge · GitHub
Architecture background: EdgeAI Forge: My Journey Toward a Local Agentic AI Platform for Industrial Automation
This is a request for architecture feedback, not a claim of production readiness. Concrete references, sample projects, and lessons learned would be very helpful.
